20 Most Recent Samsung LE37R72B 37 in. HD-Ready LCD Television Questions & Answers
Lcd manuel
download user manual from>>
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/LE37A656-_1
or download from>>
http://www.usersmanualguide.com/samsung/tv__lcd
please rate this solution.
Thanks for using FixYa.
11/27/2019 1:03:54 AM • Samsung LE37R72B... • Answered on Nov 27, 2019
Looking Manual for samsung tv le37r88bdx
Samsung LE37R8 LCD TV Owner's Instructions: Download Samsung LE37R88BD Deutsch English Espaol Franais Italiano... Samsung LE37R72B LCD TV Owner's Instructions: Download Samsung LE37R72B English user manual in PDF .
9/10/2018 9:43:42 AM • Samsung LE37R72B... • Answered on Sep 10, 2018
Colour is not normal, sometimes the picture is too dark, football pitches bright green, peoples faces very orange.
that would be a failing tcon board on the back of the screen.you would need to replace this part but they are available on ebay the part number is on the tcon board. match the numbers a version number to get the matching board for the screen. tcon board is the board were the main wire cluster goes to the screen board this is the tcon board.
7/3/2017 5:46:27 PM • Samsung LE37R72B... • Answered on Jul 03, 2017
I have a Samsung LED 37
that would be the screen driver failing, the shadow is the memory on the screen control its self the board is on the back of the screen with a lead going to it from the main av board, the board has to be replaced with the same part number, as different ares put different screen in when made you will need the part number from the board and replace it this board with same part number.
6/21/2017 11:20:09 AM • Samsung LE37R72B... • Answered on Jun 21, 2017
Tv
MY TV WILL NOT ACCEPT POST CODE
7/7/2013 11:27:16 AM • Samsung LE37R72B... • Answered on Jul 07, 2013
The picture on my samsung 37inch tv has gone dark, i have tried to change on the setting but cant get it much lighter
The back light CCFL tubes, and the back light inverter board to your TV need a thorough checkup. Seek expert tech support.
6/21/2012 10:17:54 AM • Samsung LE37R72B... • Answered on Jun 21, 2012
Connect i pod to tv
You have to be a but more descriptive pal, your not going to get a answer because we need to know what type of iPod. If it's a iPod touch, you need to buy a Apple TV Adaptor.
1/31/2012 5:34:31 PM • Samsung LE37R72B... • Answered on Jan 31, 2012
Lines are flikering across the
This image defect is typically caused by a "clock" failure within the Digital Video Display Board.
You can replace the board with this part. Or have someone do it for you.
http://www.discounttvparts.com/BP59_00087A_p/td-1068.htm
8/23/2011 11:07:18 PM • Samsung LE37R72B... • Answered on Aug 23, 2011
Tv wont connect to the dvd properly
HI,YOU MUST CHECK THE CABLES MAYBE TS BROKEN
8/16/2011 8:57:02 AM • Samsung LE37R72B... • Answered on Aug 16, 2011
Well we pluged the cables
Are you using component cables for the video? If so make sure the colours match up between the plugs and the connectors on both the TV and whatever you are using as the video source (DVD player, digital cable or satellite box).
The green plug on the cable must go into the green jack on the TV, blue plug into blue jack etc. It sounds like you might some of them mimatched.
5/5/2011 4:36:00 PM • Samsung LE37R72B... • Answered on May 05, 2011
We have a samsung series
One of these should work: 004 005 009 015 104 105 106 109 133 172
5/3/2011 6:38:34 AM • Samsung LE37R72B... • Answered on May 03, 2011
The remote fails to turn off television
Please test your remote in the first place if there is IR emission. You can focus the remote to your phone camera and see if there is a sparkle of light( Infra red) .
If not please have your remote checked specially the off button.
check the link for tips:
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
2/8/2011 11:44:56 AM • Samsung LE37R72B... • Answered on Feb 08, 2011
Require tv code to use remote
For the V+ remote control (Virgin Media have a picture of it here - http://www.virginmedia.com/images/types7-8n.jpg ) - the code is 0079.
To enter the code, hold down Volume+ and Mute on the V+ remote until it flashes red twice, then enter the code.
1/12/2011 12:23:26 AM • Samsung LE37R72B... • Answered on Jan 12, 2011
JUST BOUGHT A NEW SAMSUNG
U have a roof or a good antena like a Digital antena?Take that antena wire hook up to the tv hole that said ANT.Now,turn on the tv.Push the button said menu on the tv remote,go to SETUP,go down to CH. push and pick AIR Not CABLE push it again.Now the tv will auto searching for all the DVTV free air stations in ur area.After this ur tv should getting all the free air DTV broadcasting signal in ur area.
10/27/2010 8:49:21 PM • Samsung LE37R72B... • Answered on Oct 27, 2010
My Samsung LE37R8 TV always wants to go into
Unplug the tv about an hour,the tv should reset itself.U should able do,what u want to than.Still have the same problems,than the Tuner board itself,have problems.
7/19/2010 12:26:19 PM • Samsung LE37R72B... • Answered on Jul 19, 2010
Samsung LE37R72B 37 in. HD-Ready LCD Television Logo
40 questions posted
 Grubhead
Grubhead
View Most Popular
LE Samsung
  • LE Samsung
Most Popular Question
looking manual samsung tv le37r88bdx
  • Televison & Video
