20 Most Recent LG RZ-37LZ55 37 in. HD-Ready LCD Television Questions & Answers
Sounds like a main digital board fault.
LG RZ-37LZ55 37... | Answered on Aug 19, 2013
Hi Kulu, Did you end up solving this issue? I have a set with exactly the same problem.
LG RZ-37LZ55 37... | Answered on Feb 28, 2013
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail. Please check on board for DRY SOLDERING JOINTS- if so do a touch up soldering on suspected sections.
http://focus.ti.com/docs/solution/folders/print/387.html
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Check for tips to check the SMPS unit:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using fixya.
LG RZ-37LZ55 37... | Answered on Sep 01, 2011
Tv probally have a dying power supply board.That the board where the power a/c cord plug into it.U have all the tools and understanding basic electronic also can do basic soldering works too?Yes. Take the tv aparts,check the tv power supply board carefully for dying capacitors components parts.These dying soon to be dead capacitors components parts are alway bulged up or puffing up on to it tops.These capacitors components parts are dying and leaking to causes the tv power to unstables and shutdown.Replaced these dying capacitors with same Micro Fared and the voltages higer rating like 5 or 10 voltages higher.These higher voltages rating well help the tv power supply board capacitors components with stand heat better.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
LG RZ-37LZ55 37... | Answered on Aug 02, 2011
may be ur voltage fluctuate or over voltage
LG RZ-37LZ55 37... | Answered on Feb 04, 2011
Tries unplug,replug the tv back like about an hour later.The tv should resetting itself back to the factory setting and should work again.If not the tv Tuner signal board have problems and it is the causes.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
LG RZ-37LZ55 37... | Answered on Nov 24, 2010
BAd you have problem with the back light most of the times caps that are preheated do this problem but some the the inverter its the bad part open it look for bad capacitate if not exchange the inverter and the power board and it will be ok
LG RZ-37LZ55 37... | Answered on Sep 22, 2010
One common part failure in the LG RZ-37LZ55 that can cause the symptoms you are describing is that the IC904 on the power card becomes damaged. In fact it is not uncommon for this part to burn a hole in its middle obscuring the part number! For your reference, the complete part number is STR-T2268 / 5907.
Not that this is the only thing that can go wrong with your TV's power supply - if you are handy I would definitely advise you to start with the power supply board of your set, looking for visible damage.
If you are not experienced with safe practice around the high voltages present in a television, please consider taking your set in for professional troubleshooting and servicing.
I hope that helps.
LG RZ-37LZ55 37... | Answered on Jul 04, 2010
I would be checking the power supply inside the unit. Many LCD have been plaqued with bad eletrolytic capacitors. These capacitors are located on the power supply. Over time,age,use and other issue like heat these tend to just give out. Read my tip on how to have this fixed.
http://www.fixya.com/support/r3565137-lcd_flat_screen_common_problems
Now if you rather not mess with it then a local repair shop can take care of that for ya.
Thanks and please do leave postive feedback and ratings for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
LG RZ-37LZ55 37... | Answered on Jun 14, 2010
http://elektrotanya.com/lg_rz-37lz55.pdf/download.html
Ok above is your service manual. I think that will have both.
LG RZ-37LZ55 37... | Answered on Jun 08, 2010
The wispy dark marks can not be removed. I've seen this problem many times on many models and screen sizes... the only fix is to replace the panel. As for a cause, I can only assume it is caused by deterioration. Perhaps of the polarizer or of the LCD material itself... I don't know. Due to the cost of LCD panels in the repair market, your best option is to use the TV until it can no longer be tolerated... then replace the TV. I hope this was helpful, best wishes.
LG RZ-37LZ55 37... | Answered on Apr 14, 2010
Hey, I have a pdf of the user manual. If you can't find it online, I can email to you
LG RZ-37LZ55 37... | Answered on Apr 12, 2010
LG RZ-37LZ55 37 in. HD-Ready LCD Television Logo
39 questions posted
Ekse
RONALD CARTER JR
View Most Popular
  • LG Televison & Video
Most Popular Question
lg tv about 6 year old until now
  • Televison & Video
