20 Most Recent Philips 32PF5321 32 in. HD-Ready LCD Television Questions & Answers
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
Philips 32PF5321... | Answered on Nov 29, 2011
look online you can buy a adapter for about 15.00
Philips 32PF5321... | Answered on Aug 03, 2010
your panel is bad you need an LCD sorry
Philips 32PF5321... | Answered on Nov 23, 2009
POWER SUPPLY PROBLEM TRY UPGRADE POWER SUPPLY KIT FROM PHILIPS
Philips 32PF5321... | Answered on Aug 31, 2009
Try replacing the battery in the remote. CR2025 or equivalent.
You need tot perform Autoprogram in TV to store new channels data and TV will show you digital channels too.
On Remote Control, Press Menu >> Installation >> Autoprogram >> OK
TV will store all available channels via Antenna (digital and analog)
Hit "add a comment" button for further query / info.
Thanks.
Philips 32PF5321... | Answered on Apr 22, 2009
Do you have a DVI port on the LCD screen? Please tell me what connections you have on your macbook and your TV. There may be a converter.
Normally HDTVs can only be hooked up through S video or DVI Depending on your video card.
Philips 32PF5321... | Answered on Oct 24, 2008
you can press both volume buttons on the set to bring up the televisions menu. From there you can use channel and volume buttons to navigate the menu.
Philips 32PF5321... | Answered on Sep 15, 2008
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
https://electronicshelponline.blogspot.com/
Philips... | Answered on Jul 11, 2020
It need to be service because the problem is from the display panel
Philips... | Answered on Jun 30, 2020
3 Digits Universal Remote Codes For PHILIPS DVD Player
  • 755.
  • 400.
  • 370.
  • 891.
  • 408.
  • 437.
  • 370.
  • 387.
More items...
Dec 24, 2019
Philips DVD Player Universal Remote Codes - My Universal ...
Philips... | Answered on Jun 19, 2020
Check for faulty parts and replace!
Philips... | Answered on May 29, 2020
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board .
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board .
Philips... | Answered on May 24, 2020
If you are sure you have selected the correct input or channel but still have no picture and sound; Try resetting the TV by unplugging it from the power outlet for 30 seconds. Press the [Source] button to select the correct input source. Check the connection cables.
https://www.usa.philips.com/c-f/XC000010055/what-to-do-if-there-is-no-picture-or-sound-after-connecting-philips-tv
Philips... | Answered on May 22, 2020
According to the Wikipedia, "DVD region codes are a DRM technique designed to allow motion picture studios to control aspects of a release, including content, release date, and price, according to the region. DVD video discs may be encoded with a region code restricting the area of the world in which they can be played.
The DVD Copy Control Association in California, USA, requires that DVD player manufacturers incorporate the Regional Playback Control (RPC) system - according to the Australian government's anti-monopoly watchdog, the ACCC. It is therefore this US Association that is responsible for the RPC system that effectively divides the world into six regions for the purposes of controlling and manipulating distribution within the global DVD market.
There are six different official regions and two informal variations. DVD discs may use one code, a combination of codes (Multi-Region), most codes (Region 0) or every code/no codes (Region All). The commercial DVD player specification requires that a player to be sold in a given place not play discs encoded for a different region; however, region-free DVD players are also commercially available.In addition, many DVD players can be modified to be region-free, allowing playback of all discs."
http://en.wikipedia.org/wiki/DVD_region_code
A brand new DVD player allows you to play DVDs from different regions only five times, locking to the last region watched after these five times. So, you might have used your five region-change permissions and your DVD player is now locked to a different one from that of the DVD you want to watch (even thou you might have watched normally before).
There are some softwares like "DVD Region+CSS Free" from dvdidle.com or "CloneDVD 2" from Slysoft.com that allow you to back up your DVDs without the annoying region code. There are also sites like www.rpc1.org and www.dvdexploder.com that provide firmware or remote control codes to unlock the region of your DVD player.
Hope this information helps you understand why your DVD player is behaving like that and how to bypass that pitfall.
Philips... | Answered on May 21, 2020
When you performed the power cycle did you make sure all accessories were disconnected?
Also plug the TV directly into a wall mains socket, not through an extension lead or socket!
Repeat this test at least 3 times or until the TV powers up.
Philips... | Answered on May 10, 2020
Philips 32PF5321 32 in. HD-Ready LCD Television Logo
16 questions posted
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
philips flattv problem
  • Televison & Video
