20 Most Recent Lenovo ThinkPad T21 2647 Notebook Questions & Answers
i thnk maybe you ram is the culprit try to place the ram firmly in th socket to start your Thinkpad.... the beeps represent a hardware fault
you might have to count the beeps and tell me how many are exactly there?
Lenovo ThinkPad... | Answered on Aug 17, 2013
helo
go to the link below to get further assistance
but basically to reset the password, follow these steps.
If the Power-on password (POP) is forgotten and the Supervisor password is known, simply go into the ThinkPad BIOS setup utility and reset the Power-on password, otherwise try the following:
  1. Turn off the computer.
  2. Remove the battery pack.
  3. Remove the backup battery (CMOS battery --size of coin- located on mainboard, requires you to remove the plastic cover on rear on computer)
  4. Turn on the computer and wait until the POST ends. After the POST ends, the password prompt does not appear. The POP has been removed.
  5. Reinstall the backup battery and the battery pack.
    Note: Some ThinkPad systems have the ability to reset the Power-on passwords in the ThinkPad BIOS setup utility if a Supervisor password has been set.
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-59377
if this helps, please rate my service -- if not let me know - i will continue to help
Lenovo ThinkPad... | Answered on Nov 22, 2010
try clicking on this link and choosing Master Boot Record Repair.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-56102
Also, have you tried
Step 1. Make the DVD drive the first startup device in the startup sequence using
the following procedures:
a. Shut down the operating system and turn off your computer.
b. Press and hold the F1 key, and then turn on the computer. When the logo
screen is displayed or if you hear repeating beeps, release the F1 key. The
Setup Utility program opens.
Note:
If the Setup Utility program does not open, shut down the
computer, wait approximately five seconds, turn on the computer, and
then immediately press and release the F1 key repeatedly until the Setup
c. Use the left and right arrow keys to select Startup from the main menu.
From the Startup menu, select Startup Sequence and then press Enter.
d. From the Startup Sequence [Primary] menu, do one of the following to
select the DVD device that you want to use as the first boot device.
Note: When selecting your DVD device as the first boot device, be aware
that internal DVD drives are listed as IDE CD. If you will be using a
supported external DVD drive as the first boot device, select USB
CDROM in the steps below for your choice of DVD device.
v If your choice of DVD device is already listed as the first boot device,
continue with step 2.
v If your choice of DVD device is listed in the startup sequence as any
device other than the first device, select it and press the Plus (+) key
repeatedly until it is displayed as the first boot device. Continue with
step 2.
v If your choice of DVD device is listed as an excluded device, select it
and press the X key one time to add it to the startup sequence. Then,
select your choice of DVD device from the startup sequence and press
the Plus (+) key repeatedly until it is displayed as the first boot device.
Continue with step 2.
e. Press F10 to save and exit the Setup Utility. When the save and exit
message displays, select Yes and then press Enter.
Lenovo ThinkPad... | Answered on Jul 18, 2010
If you mean BIOS update for Lenovo Thinkpad T21, you may refer to this link.
Other means of BIOS update for it can be found here.
Lenovo ThinkPad... | Answered on Oct 26, 2009
It sounds like your system board is gone. It will need to be replaced. A used board goes between 150 -300 dollars. For someone to check it will still need to be disassembled.
Lenovo ThinkPad... | Answered on Jul 12, 2009
the lcd display screen has to be set to 1024x768 60hz refresh rate 1st to be able to send the signal to a tv.
then try the function/monitor on keyboard or boot with it connected.
Lenovo ThinkPad... | Answered on Feb 05, 2009
technoprasan hello,
Yes, it is possible to Dual-boot the two systems.
Please follow the guide here, it is very detailed and good, worked for me 4 times:
http://www.pronetworks.org/forum/about88231.html?sid=c55ecb04e6043f21d876c1ef23c596f0
Lenovo ThinkPad... | Answered on Oct 30, 2008
when you turn on your pc there is normally something that says press whatever key for setup. press that key and then you would have to set the first boot or primary boot as cd and then save and restat the pc. please let me know if anything else is needed and i will be happy to help.
please rate me. thank you.
Lenovo ThinkPad... | Answered on May 28, 2008
Run more programs.. Newer laptop cpus throttle back when not needed. If you want to run notepad at full speed, see if you can set the power saver options for full performance.
Lenovo ThinkPad... | Answered on Feb 16, 2008
hi, as u say when u tap on the lcd it works, means there is a loose contact on the connector strips comming from the MOBO, if u can manage to open the LCD cover, u will find it around, try cleaning all the connectors/contacts, u will b fine.. let me know
Lenovo ThinkPad... | Answered on Jan 10, 2008
all you need is a cd with xpIf you boot with a cd there are recocvery options. If not you will have to install it again if the origional system is corrupt and not booting.
Lenovo ThinkPad... | Answered on Nov 24, 2007
Yes you can download Whatsapp on your Laptop by follow simple steps.it is very easy to download it on your PC by using some emulator WhatsApp FOR PC WINDOWS AND MAC .Download Whatsapp from this link..
Also download fresh Android App on your PC Such as Asphalt 9 from this link.. Asphalt 9 FOR PC WINDOWS AND MAC
Lenovo ThinkPad... | Answered on Jul 31, 2020
Error code 36 means a ley is stuck. Only you can find out which one. Press each key in turn to feel if there is a dodgy key.
Lenovo ThinkPad... | Answered on Oct 09, 2019
remove the battery large.
then run on AC pack only
#1 top failure of all mobile PC is that battery, so unplug it
then test with AC pack only.
work now.? and all vents must be clean, end to end. not just fan.
there i no fuse it uses current regulator, imagine genius magic electronics fuses that never blow out, and bingo.
OK big battery out, an RTC coin cell fresh.
then fan blows.
next is BIOS, do the BIOS screens work if not the mobo is dead.
have 2 RAM stick on the 2 slots>? try one at a time
run the PC with all modules removed, (options)
remove hdd?
remove, dvd drive.
think like this. Get bios working first
learn that modules can short, and when they do the power regs shut down.
so we unplug all things to the mob,
until only 1 ram and cpu remains.
see? (this is called power overload fault isolation tactics)
even the screen only can be dead, you never mention text showing
you can test the mobo with external screen via that rear (?)_ VGA jack what if that worked, did you learn something here, sure.
this pc has tons of modules to pull, even bluetooth. wifi, sound and more. if you look at all parts inside or sold by ebay, bingo. lots
Lenovo ThinkPad... | Answered on Aug 14, 2018
It helps to know what device model and OS you are using though the following steps for changing from pattern lock to slide are for Android OS 4.0 (Ice Cream Sandwich):
1. Unlock your Android device
2. Find the Applications menu and select "Settings"
3. Under the "PERSONAL" group, select " Security"
4. Under "SCREEN SECURITY" group, select "Screen Lock"
This will ask for the security pattern first.
5. The options for screen lock will appear, select "Slide" and you are done!
Hope this helps.
Lenovo ThinkPad... | Answered on Mar 14, 2017
Lenovo ThinkPad T21 2647 Notebook Logo
18 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad Lenovo
  • ThinkPad Lenovo
Most Popular Question
os instalation
  • Computers & Internet
