20 Most Recent
Coby TF-TV1901 19 in. LCD Television Questions & Answers
Tv wont pick up channels
Have you been into scanning settings and set to DTV , it seems like you are either on ATV or have a bad Antenna connection. If signal is weak from your Antenna you can add a booster in the section between your wall socket and the TV. You cannot use Satellite dish connections to receive either ATV or DTV signals without a set top box ...
How do you reset the parental code for the coby 19" TFT LED 1926 tv??
If you don't know the current password you can't. If you do then find the LOCK menu under TV function.
Tochangethepassword,inputtheoldpassword-->inputthe Password
newpassword-->verifyagain.
Pleaserememberthepasswordsincethe player'sreset
functionwouldnotrevertthepassword.
The default password is "0000"
If you want to set it back to the factory default you can email Coby support at
[email protected].
the phone number is listed as: 800 727-3592
Coby tv code for fios remote
1. Press and hold the TV key.
2. While holding down the TV key, press OK.
3. Release both keys. The Device Keys will blink twice.
Ideally we do not have code for coby TV. So we need to manually program the remote
TV and Cable box should be both powered on.
4. Press 9 - 2 - 2.
5. Point the remote at the TV.
6. Press PLAY
Press FAST-FORWARD. Every time you press FF the remote sends out a new power-off command to the TV. Keep pressing FF until the TV turns off. (You can press REWIND to go back 1 code.)
8. When the TV turns off, you have found the right code. Press OK to store this code.
9. Press TV and the power should go on. You will now have volume control also.
TIP: Press ff slowly so you know when it powers off and when you need to save the code by hitting OK after it powers off.
TV turns on, but screen goes black after a minute.
The LCD inverter board is dead.That why u not getting a backlight to the LCD screen to get a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter for the replacement.It a long board.
I lost my tv remote
go to this link to find your remote :
1) http://www.remotes.com/
or
2) http://www.replacementremotes.com/
