20 Most Recent
Xerox Workcentre 5325/c 5325 Black & White Advanced Multifunction Copier Questions & Answers
Hello! How to disassemble Toner Dispenser Assembly in Xerox D95?
If the toner dispenser assembly on your Xerox D95 is only coming out a few centimeters and then stopping, there may be something preventing it from fully disengaging. Here are some steps you can follow to try and disassemble the toner dispenser assembly:
1. Turn off the printer and unplug it from the power source.
2. Open the front cover of the printer to access the toner dispenser assembly.
3. Carefully pull the toner dispenser assembly towards you until it stops.
4. Look for any visible obstructions that may be preventing the assembly from being removed. It could be a jammed toner cartridge, loose toner, or any other foreign objects.
5. Use a flashlight to inspect the area and see if anything is blocking the assembly from being removed.
6. If you do see an obstruction, carefully remove it and try to pull the toner dispenser assembly again.
7. If there is no visible obstruction, try gently wiggling the assembly from side to side while pulling it towards you to see if that helps loosen it.
8. If the assembly still won't budge, you may need to contact a qualified technician to help disassemble it safely.
It's important to be careful when attempting to disassemble any parts of your printer. If you're not confident in your ability to do it yourself, it's best to seek professional assistance.
Xerox 7435 error 041-340 how to solve error
Xerox 7435 error code 041-340 indicates a problem with the yellow imaging unit. Here are some steps to solve the error:
- Power off the printer and unplug it from the power source.
- Remove the yellow imaging unit and check for any damage or leaks.
- If the imaging unit appears to be in good condition, reinsert it firmly and make sure it is properly seated.
- Turn the printer back on and check if the error message has disappeared.
- If the error persists, try replacing the yellow imaging unit with a new one.
- If replacing the imaging unit doesn't solve the problem, you may need to call a technician to troubleshoot the issue further.
It's worth noting that error code 041-340 can also be caused by issues with the developer housing, toner cartridge, or other components. If none of the above steps work, it's best to contact Xerox support for assistance.
Are refurbished Xerox 7760 imaging drums safe to use?
Refurbished imaging drums can be a good option to save money, but it is important to purchase them from a reputable source to ensure they are of good quality and safe to use. Some refurbished parts may not be manufactured to the same standards as new parts, which can affect the performance and lifespan of your printer.
When purchasing refurbished imaging drums, look for sellers who offer a warranty or guarantee on the product. This can provide added peace of mind and protection in case the drum fails prematurely. Additionally, be sure to follow the manufacturer's instructions for installation and maintenance to ensure optimal performance and avoid any potential issues.
On a xerox xc1250 what does a status code h3 mean and how do I fix it or reset it.
On the Xerox XC1250 copier, the status code H3 indicates a high-temperature error in the fuser section. This error occurs when the fuser unit gets too hot, and the copier automatically shuts down to prevent damage.
To resolve the issue, try the following steps:
- Turn off the copier and unplug it from the power source.
- Wait for about 20 minutes to allow the fuser unit to cool down.
- Check the fuser unit for any signs of damage, such as cracks or burns. Replace the fuser unit if necessary.
- Check the power supply and make sure it is delivering the correct voltage to the copier.
- Plug the copier back in and turn it on.
If the error code persists after trying the above steps, it may be best to contact a Xerox service technician for further assistance. They will have the necessary tools and expertise to diagnose and fix the issue.
How to solve the LL- 21 xerox wide format 8830
1. Check the user manual for the Xerox Wide Format 8830. This should provide instructions on how to troubleshoot and solve any issues you may be having with the machine. 2. Contact Xerox customer service for assistance. They should be able to provide you with more detailed instructions on how to solve the issue. 3. If the issue is related to a hardware or software issue, you may need to contact a qualified technician to come and repair the machine.
Reset the forgotten Xerox workcentre 3225 admin password
If you have forgotten the admin password for your Xerox WorkCentre 3225, you can reset it to the default factory settings using the following steps:
- Turn off the printer: Turn off the printer and unplug it from the power source.
- Access the control panel: Press and hold the "0" button on the printer's control panel while turning on the power switch. Keep holding the "0" button until "Accessing Service Menu" appears on the display.
- Access the Diagnostics menu: Press the "Up" or "Down" arrow button until "Diagnostics" is highlighted on the display, then press the "OK" button.
- Access the Service Tools menu: Press the "Up" or "Down" arrow button until "Service Tools" is highlighted, then press the "OK" button.
- Reset the password: Press the "Up" or "Down" arrow button until "Reset Password" is highlighted, then press the "OK" button. Enter "1111" when prompted for the password and press the "OK" button.
- Restart the printer: Press the "Up" or "Down" arrow button until "Restart System" is highlighted, then press the "OK" button. The printer will restart and the password will be reset to the default.
Note that resetting the password to the default will remove any custom settings or configurations you have set up on the printer. It's also important to note that some models of Xerox printers may have slightly different steps, so it's always best to refer to the user manual or contact Xerox support for assistance if you're unsure about any of these steps
Xerox Versalink C7025 error code 116-331
This error code could indicate an issue with the drum or fuser. Ensure that the toner cartridge/drum has been seated correctly, and if necessary contact a qualified technician or Xerox support to further investigate and resolve the issue.
A problem with Xerox WorkCentre 7845
The error code 303.777.00 on the Xerox WorkCentre 7845 suggests a problem with the power supply. Since the machine is restarting on its own every 20 minutes, it is likely that the power supply is failing. You should contact Xerox customer support for assistance, and a trained technician should diagnose and repair the power supply to fix the problem.
My printer xerox 6515 showing the errors 062-380 and 386 do you know how to fix this errors
- estart the printer: Turn off the printer, wait a few seconds, and then turn it back on.
- Update the firmware: Check the Xerox website for any available firmware updates for your printer model. If an update is available, follow the instructions to download and install the update.
- Perform a firmware reset: Contact Xerox support to perform a firmware reset, if needed.
Error 386: This error message typically indicates a problem with the printer's communication interface. To resolve this error, try the following steps:
- Restart the printer: Turn off the printer, wait a few seconds, and then turn it back on.
- Check the cable connections: Make sure that the cable connecting the printer to the computer is securely connected at both ends.
- Try a different cable: If the cable connections are fine, try using a different cable to connect the printer to the computer.
- Check the computer settings: Make sure that the computer is set up to communicate with the printer correctly.
If the error persists after trying these steps, I would recommend contacting Xerox support
