20 Most Recent
Sova Digital DST207-S37C Television Questions & Answers
SOVA 30" HD READY WIDESCREEN LCD TV DISPLAY DS203-S30
Do not buy anything from LCDPayless. They are crooks. I order power supply for Protron 32". Their web page showed the same model as mine and they sent me some garbage that was not working. I returned it and they refused to reimburse me full amount. I contacted my credit card company and then they claimed they didn't receive it at all. STAY AWAY FROM THEM THEY ARE THIEVES.
I have a Sova monitor that I'm trying to hook up
We would be happy to help you with that. The first thing wewant to try is unplugging the receiver for 10 seconds that plugging it back in,it should take about 5 minutes to reset. We also want to ensure that the DISHNetwork receiver is connected to your TV correctly, please visit this link tosee how it should be connected:http://www.dishnetwork.com/SupportSection/setup-receiver. If you are able to,connect another component (VCR, DVD Player, etc.) to the same TV, using samecable, same input, and same channel to see if it works. If it still doesn'twork, the cable needs to be replaced, if it does work with the other componentconnected, give us a call at 1-800-333-DISH (3474) for some additionaltroubleshooting.
We hope these steps get your picture up and running. Thanks for being a valuedDISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Have a sova 32
Possibly. Did the problem start suddenly or did the picture fade (possibly with a pink/red color)? The problem was sudden, it probably was the inverter that drives the backlight. If it slowly faded, the backlight itself failed. Most manufacturers will recommend the entire board be replaced if it is the inverter. The inverter is simple to replace but you must get the right one for your tv. (The replacement is disconnect the wires from the old board (like molex plugs) and unscrew the board. Screw in the new board and connect all the wires.) The backlight is a bit harder since you have to use a rotary tool (Dremel) to remove the old one from the housing.
First open up the TV and remove the shielding. Look for any capacitors that are bulging or leaking. (These are cylinders on tripods.) If you see those, note the part number of the board and order a new one. Match the part number and revision if possible. Universal inverters are available but you may have issues like the contrast and brightness being reversed (press up to reduce brightness). (Depending on the inverter they range from $50-$150). You could alternatively just replace the capacitors and usually the resistor that served as a fuse for the board.
One way check the inverter is with a multimeter that can measure frequency. (You need a high frequency range ~50 kHz, Alternatively an oscilliscope can do this.) Hold the multimeter probes a fraction of an inch apart about an inch above the circuit board with the TV plugged in and on. If the inverter is bad or the frequency is too high for the multimeter, you will see a result near zero. If the multimeter gives a measurement of 1 or a value of 20-60 kHz (depending on the TV), it's probably the backlight.)
I hope this helps.
HI ! I have a problem, maybe is the remote
Hi
If only some buttons work then the remote is failing. There are universal remotes you can buy but they all have limitations. Try to order an original from the manufacturer.
Can't power up TV
your power control board is most likely bad.
enter the PCB # on an ebay search.
eStoreREX rebuilds them for around $100.00
DST206-S32 Sova flatscreen remote needed
The uiversal remote companies pride themselves on working with any
TV. Many of them have an 800 number (should be right on the
package when you buy it) that will give assistance with TVs like this.
Most off brands are actually made by a name brand maker and if
you (tediously) try all the codes you should find one that works at
least the important features.
GREEN LIGHT KEEPS GOING BACK TO GREEN
Hi Jess......I have one of these TV's but in a 30". Could it be the AC Adaptor? Does yours come with one? My problem is the AC Adaptor stopped functioning therefore I have no power going through my TV. It is frustrating not getting any useful help on this TV. I will never buy a noname again. Would you know or have an 800 number or know where I can buy another AC Adaptor for my 30"? I think your problem my well be similar to mine. Hope this helps and thank you in advance for any help you can give me.
