20 Most Recent Samsung ML-1860 A4 Mono Laser Printer Refurbished Mfr P/N ML-18 Questions & Answers
Go to service mode and rest counter
Samsung Office... | Answered on Sep 14, 2020
Try factory rest your printer and try printing again
Try cleaning the transfer belt and the four drums. Use a soft cloth to wipe the drum
try going to service mode on the printer, go to service function & select parts replacement alert and disable the notification on OPC so that it doesn't show toner reading.
try going to service mode and turn off the notification for the toner
The latest driver for your scanner needs to be installed on your PC.
In order for the print out to be clear, the paper path, drum and the transfer belt should be clean & the waste toner container should be empty. If doesn't work replace the drum.
Test the power cable on another printer and sees if it powers it..check the power supply if it is up to or not more than the required output voltage to power the printer..if problem persist check power board of the printer and read if their is still continuity on the fuse ..read the fuse with multimeter..the fuse if the printerust have been discontinued
Samsung Office... | Answered on Sep 09, 2020
reset Samsung SL-M2070/M2070W Samsung SL M2070 M2070W
Samsung Office... | Answered on Sep 08, 2020
The fusing element is broken. It heats the toner and fuses it to the paper.
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk02jcI4A-TdxYFTqk5Ujobg5RMgKvg%3A1599407288802&ei=uARVX6uvMK3AytMPhKGIiAU&q=samsung+scx+3201printer+replacement+fuser
Samsung Office... | Answered on Sep 06, 2020
This could be a bad or loose switch or interlock. This unit may use a photo type of switch and it can fail or become obstructed.
Samsung Office... | Answered on Sep 04, 2020
For me it was a standard paper jam. I pulled out the paper tray, reached under and pulled out a jammed sheet, then reinserted the paper tray and it worked.
Samsung Office... | Answered on Aug 10, 2020
Samsung ML-1860 A4 Mono Laser Printer Refurbished Mfr P/N ML-18 Logo
2 questions posted
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
samsung scx 3201printer print page but
  • Office Equipment & Supplies
