20 Most Recent Acer Aspire 1804WSMi Notebook Questions & Answers
Try to use an external monitor just to check if you are getting the same thing. If no problem using external monitor then the problem is already the LCD of your laptop. If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Acer Aspire... • Answered on Jun 07, 2012
From what you describe it sounds like you have some kind of hardware problem possibly related to the hard-drive connection. Try starting it with the hard-drive removed it should at least show the bios screen. If it doesn't then you should start removing hardware(CD-ROM, RAM, etc) using a process of elimination. If you don't want to go though all that you could just sell it on eBay for part.
Acer Aspire... • Answered on Jul 14, 2010
Connect it to another screen using the vga connection, which is the blue connector on the laptop. If it comes up the same it could be your video card. If it is fine on the other screen then it is your LCD, which might cost you around 400$
Acer Aspire... • Answered on Jun 22, 2009
That I know of there is no 100% security. If these laptops are wireless, then I would suggest making every effort to hard wire these. If they are already hardwired then someone probably has your IP address. A way around this is to contact your ISP and get their help in giving you a dynamic IP address. Then I would look at your firewall, i.e. is it on? At this point, again with your ISP's help you can limit your connection to only specfic IP addresses. This should narrow your window considerably. A data collection program may have been installed on your computer. The only way to remove it is to format or replace the hard drive. Using what I said above and replacing your present hard with a new one and making your present one an external, non-bootable drive should just about get you to as close to 100% as possible.
Acer Aspire... • Answered on Jan 05, 2009
This maybe a case of a bad boot sector on the hard drive. On boot up try pressing F8 to get you in safe mode, right click on your 'C' drive>properties>tools>error check. and let it do a disk check. If unable to get in safe mode you will need a copy of Windows to enable you to do a repair by setting your pc to boot from cd in the bios and will ask you to press enter to boot with cd. When Windows has installed all set up files, press 'R' for repair and 'NOT ENTER' as this will install windows again formatting the drive. When prompted press enter when it asks for admin password(as there won't be one). Look down the list for 'Repair MBR', press enter and also 'SCANNOW' as this will scan your drive for errors, press enter. Good luck Your
Acer Aspire... • Answered on Nov 24, 2006
Can you give more infomation, like what program your using?
Acer Aspire... • Answered on Aug 12, 2006
acer aspire es1-331 is the proper way to ask...correct spelling is a must. and depends on if your in USA or what your country is required.
Acer Aspire... • Answered on Feb 12, 2021
ALL THOSE PEOPLE OUT THERE SUFFERRING FROM THIS. THERE IS AN SIMPLEST SOLUTION AND THAT IS JUST DOWNLOAD ACER LAUNCH MANAGER VERSION 8 FROM GOOGLE. https://softfamous.com/acer-launchmanager/ THIS IS THE LINK AND INSTALL THIS AND BLUETOOTH ICON WILL APPEAR IN THE TASK BAR. IT WAS SO SIMPLE PLEASE TRY THIS
Acer Aspire... • Answered on Dec 03, 2019
first confirm that your touch pad is working or not. yor touch pad may be disabled or it may be dead. you can enable your touch pad in it's setting. you can connect an external mouse to your laptop to check that. or you can enable mouse keys in control panel.
Acer Aspire... • Answered on May 13, 2019
You'll need to be more specific. Acer makes several Aspire 3 notebooks. Many of their manuals are available here: https://www.acer.com/ac/en/US/content/drivers . In the drop down menus, choose Notebook, Aspire and look for the model number. Current Aspire 3 notebooks have model numbers that start with A315. The user manual for the A315-21 is currently here: https://global-download.acer.com/GDFiles/Document/User%20Manual/User%20Manual_Acer_2.0_A_A.zip?acerid=636564340054411702&Step1=NOTEBOOK&Step2=ASPIRE&Step3=ASPIRE%20A315-21&OS=ALL&LC=en&BC=ACER&SC=PA_6 . You'll need to extract the contents of the file to read the manual. I hope this helps. Cindy Wells
Acer Aspire... • Answered on Feb 10, 2019
Drivers for Acer computers can be found here: http://download.driversupport.com/lp/bppc/alt?tid=US-OEM-BroadMatch-Search&oemid=23419&odmid=&utm_source=bing&utm_medium=PPC&utm_term=Acer_Driver_Download&utm_content={creative}&utm_campaign=US-OEM-BroadMatch-Search&m=Acer&s_kwcid=AL!4343!10!79989529365436!29392071285&ef_id=Wr5aCAAABddrJ9PD:20190107151930:s
Acer Aspire... • Answered on Jan 07, 2019
Allen Bolderoff wants answers to this question hyjackes, 2013 post in 2018? no time stamp, who knows? but you ask because, Acer has no service manuals. remove what cover to reach what? what is bad? the battery ? Acer Aspire Z3771-UR30P do mean the ALL-in- ONE PC? that? with missing full partnumber as in the example above?>]\ yes then here is your support page. https://www.acer.com/ac/en/US/content/support-product/3993?b=1 the manual has only one line with remove in it. and is useless. so off to youtube we go. or google all week (not me) 1st ****** hit. https://www.youtube.com/watch?v=52qIGI0aVBg RTM fail. Google, not me. youtube BINGO.
Acer Aspire... • Answered on Dec 21, 2018
if you installed it from a disc it should have come with a code,when you go on line and it asked you to register it there should be some were on that page were you put the code. some times when you load it from a disc it should let you put the code in there. or if some one gave you the disc and its been registerd before you might end up having to pay for it.
Acer Aspire... • Answered on Jun 15, 2018
Acer Aspire 1804WSMi Notebook Logo
10 questions posted
Lee Hodgson
Lee Hodgson
Steve Sweetleaf
Steve Sweetleaf
Gustavo Ortiz
Gustavo Ortiz
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
picture corrupted thru middle screen
  • Computers & Internet
