20 Most Recent Gateway MX6438 Notebook Questions & Answers
this sounds like your video card and it controls visual functions..have you tried booting direct to the hard drive and bypass the CD? if this does not work looks like its tech time or if you are tech savy and know if your video graphics or GPU is integrated or is separate from the mother board you might be able to get and repair the part yourself...usually they give some indication of getting ready to die when functioning normal screen will fade to white and force you to reboot..this happens on separate GPU systems ...integrated can just wipe out and not reboot..reset your memory sticks as a last ditch effort...If you are uncertain you can look the specs up by googling your model # on any smart phone Good luck GOD BLESS
Gateway MX6438... | Answered on Oct 12, 2017
To turn the wireless radio on or off for this notebook, press FN+F2 at the same time. The wireless status indicator will turn on or off to indicate the status of the wireless
Gateway MX6438... | Answered on Feb 03, 2013
Driverpack solution will do it for you
Click Here for Driverpack solution torrents.
Thanks
Gateway MX6438... | Answered on Jan 03, 2013
use RAMBooster 1.6 . will solve your problem. use registry mechanic to repair the registry errors.
Gateway MX6438... | Answered on Sep 06, 2010
Have you check the battery you are using or better still remove the battery at th back and plug it directly to the power supply and check if it turn on well . if it is positive then change the battery , the battery is at fault.but you can still add the battery when you see that after removing battery and plug it straight it power on then after like twenty minutes you can slot in the battery as well so as for it to be re-boost by the power and get charge up.
Gateway MX6438... | Answered on May 24, 2010
If the system is not accessible even from "Safe Mode", then it sounds like the hard drive may becoming corrupt. Boot from the OS CD, and select the repair option - or try to boot from another boot cd, such as the Ultimate Boot CD at www.ultimatebootcd.com and see if you can run a CHKDSK command to attempt to repair the hard drive. I can give more specific instructions if you tell me which operating system (Windows XP, Vista, Windows 7) you are using.
Gateway MX6438... | Answered on Feb 18, 2010
I'm not sure what happened but we got disconnected somehow. What you want to do, seeing as you are using another laptop, is download the software from Gateway and save it onto a cd-rom. Insert the cd rom into the gateway, open the driver and install the driver onto the laptop. This should work. If it doesn't, let me know!
Gateway MX6438... | Answered on Jan 18, 2010
yes i can,go to this site and download the drivers you need from here http://support.gateway.com/support/drivers/search.asp?st=pn&param=1008901
Gateway MX6438... | Answered on Dec 17, 2009
Is it the correct disk for that machine??
Enter BIOS and ensure first boot is CD.
Ensure there are NO finger prints on CD.
Gateway MX6438... | Answered on Dec 03, 2009
You have to install the driver for the LAN card, you should be able to get the driver from the gateway website driver and support
Gateway MX6438... | Answered on Nov 16, 2009
ok ...first see that you need at least 1G of Ram on a computer for successful installation of windows7...
also need 13G of storage available on a partition of your Hdd...
the windows seven can be downloaded from the Microsoft site ...or bought from an software store...
I understood that until July it was distributed for free as a release and with a free license until Mars 2010 ...but they do not do that anymore ...
anyway it worth trying ...
I understood also that some had problems in buying it from the site and downloading it ...so I recommend to wait until next Mars when it will be a fully functional program ...and until than just prepare your laptop by upgrading Ram memory ...
anyway ...like vista it has issues with driver compatibility ...even if most are the same as in Vista ...some devises do not have drivers available for it ...and you will not be able to use them..
Gateway MX6438... | Answered on Nov 04, 2009
Make certain it is the correct media for the drive. If it is CDR or CDRW media, make sure it is rated for the write speed of the drive. High Speed media for a High Speed drive is labeled with the High Speed logo. If you are testing with an audio CD, play it in your home stereo first to make sure the disc works.
Check also the disc if it has scratches that's why it skips when played. Try a known good CD.
Gateway MX6438... | Answered on Jun 19, 2009
Sounds like a hard drive issue. Take the hard drive out and put it back in again and try it. Hope that helps.
Gateway MX6438... | Answered on May 26, 2009
Depending upon the model laptop, yes the battery is under the keyboard.
Gateway MX6438... | Answered on Mar 22, 2009
Gateway MX6438 Notebook Logo
Popular Tags
47 questions posted
Top Gateway Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
MX Gateway
  • MX Gateway
Most Popular Question
turn wireless connections
  • Computers & Internet
