20 Most Recent Discovery Channel Animal Planet Dog Or Cat Auto-flow Bubbling Pet Fountain Waterer Questions & Answers
We had the same problem. My husband took a small black plug out of the pump hose. He said it should have been punched out of the fitting, but it wasn't. When we took it out, our pump started to work beautifully. Good luck.
Discovery... | Answered on Aug 03, 2015
You can find the manual at this site:
http://www.mscustomercare.com/
I have a different model that overflows. My model was not listed, but yours was. Hope this helps.
Discovery... | Answered on Dec 01, 2013
Maybe it was not made or designed to be used as a water dish for pets then. Or it could be a bad pet dish that you had purchased and you should return it and get your money back.
Cats | Answered on Jan 28, 2021
Short answer. You can't. Cats are the Masters. But you could try to give it something more interesting like a fancy cat scratch tree house. Plus you could be bad and squirt it with water from a spray bottle and say NO! every time it does it. :-)
Cats | Answered on Dec 23, 2020
Check out free calculators online. Just type in calculators and type grams etc. then you can figure it out. :-)
They should only have about 12 per day. They are very fattening. :-)
Eyes are serious and tricky.
You could VERY GENTLY bathe the eye with plain clean warm water. Wiping gently downwards gently making the eyelid close. Then all you can do is leave it up to the cat to apply its own saliva to the injured eye. They do have a form of antisceptic in their salivary glands.
Just keep a close watch and GENTLY wipe away any pus that forms or if the eye sticks shut, with warm water and a cotton ball.
I am sorry you can't take your cat to the Vet, times are hard right now.
I wish you all the best of luck and hugs to you and your cat.
How is it getting into your flat?
It will attack a kitten especially if it is a male. The best thing to do is to keep it out of your flat. Talk to your neighbour.
Also, cats take a while to get used to strangers. This would be fine in your own household, but not in this situation.
It sounds like the neighbours cat was allowed to come into yours and if you have been petting it and feeding it, naturally it will resent the kitten You will just have to keep them apart.
Good luck.
Contact the maker direct. They will know the fault and what needs replacing. It is probably the small stepper motor.
Multi-Cat Self-Cleaning Litter Box ' Nature's Miracle
www.naturesmiracle.com > litter-boxes-and-accessories
Your cat's litter can now be clean all day, every day with the Nature's Miracle Multi-Cat Self-Cleaning Litter Box! Equip with smart-detection motion sensor and removable automatic rake for a convenient cleanup. This litter box automatically scoops itself after every use for a clean, fresh start every time.
Cats | Answered on Dec 08, 2020
Tip
What to look for when buying a cat toy?
When buying a toy for your cat there are three important things you should look for. First, you need to look for a sturdy toy, fi it can get tossed, thrown, clawed, batted, kicked, licked and repeatedly pounced on without coming apart, it's a quality cat toy. Catnip-filled toys encourage play, but most cats like to eat catnip and will always try or lick or chew their way to that scrumptious herbal filling. Second, you need to look for toys without removable parts. Catnip mice with yam tails; crinkly cater-pillars bug eyes and plastic mesh balls with tantalizing little bells inside are the most popular cat toys although they have are potentially dangerous parts that come off. If you can pull a part of decoration off a cat toy do it to all of your cat's toys; it's better to have some catnip mice without tails than frequently visit you vet to get the tails out of your cat's stomach. Third, you should look for something fun for your cat. Cat owners often disappointed and frequently annoyed to find that the 80$ worth of custom cat toys get passed over for a piece of crumpled paper. Cats like games that involve climbing, running, leaping and pouncing. Pick toys that encourage those behaviors and your cat will defiantly use them. Furthermore, cats see moving edges better than stationary object, so toys that wiggle or weave fascinate them and trigger their hunting reflexes.
on Oct 24, 2020 | Cats
Cats are obligate carnivores, which means their natural diet is strictly raw meat ONLY. Cats biologically need the complete amino acid chain that is supplied in animal protein. Vegetables have amino acids but are missing certain parts, dogs and humans have the biological ability to synthesize the missing amino acid in vivo but cats can not. So long story short, no vegetables are not good for cats, however my cat loves pumpkin and canned beetroot. It is very hard to find cat food that contains no vegetables, the only way to give your cat the correct diet nature intended is to make it yourself.
Cats | Answered on Oct 24, 2020
Tip
Dry food vs. canned food for cats
The two most popular types of cat food are dry and canned food. Choosing which type to buy can be confusing, but I'm here to point you the benefits of each type, as well as the disadvantages. Let's start off with dry cat food. Most cat owners will agree that this is a better choice of the two. Why you ask. Well it's definitely more economical (than canned food), can be stored for a long period of time (unlike canned food), does not leave a mess,and even if it pours on the floor, it is really easy to clean. The main con of dry cat food is that it contains a large amount of carbs and fillers. Carbs are not really necessary for cats because they have a hard time converting it to energy and fillers are low quality ingredients. Regarding canned food, its main benefit is that it contains a lot of protein, which is the main source of energy for cats. Lack of protein and the cat will quickly begin to lose weight and its immune system will be weaker. Another benefit is that contains a large amount of water, keeping the cat dehydrated. The cons of canned cat food are that they are expensive, have to be refrigerated once opened, have a short life time, and can easily leave a mess. Whether you choose dry or canned food for your cat,make sure it is a high quality product with all the important nutrients.
on Sep 29, 2020 | Cats
The bestselling dry cat food on Amazon is The Goodlife Recipe Chicken and MerrickChicken. For a complete list of the top 20 sellers in Amazon, check out thiswebsite: http://www.amazon.com/Best-Sellers-Pet-Supplies-Dry-Cat-Food/zgbs/pet-supplies/2975266011
Cats | Answered on Jul 27, 2020
I was asking myself the same question when I saw my cat's reaction to catnip. She loves the stuff, but I was a little concerned that it could be addictive or harmful. After doing some research I found an article on Friendly Claws that discussed catnip at full length. It was useful to find out that catnip can be used to encourage cats to scratch their own posts as opposed to furniture!
It also mentioned that catnip is completely safe and not at all harmful to cats. It's not like a **** or anything, it's just a plant from the mint family that cats have a strange reaction to. As far as I can tell, there's nothing much to worry about when it comes to catnip. According to the article I read, some cats are not even affected by catnip so it's probably not as potent as it may seem.
Cats | Answered on Apr 24, 2020
NO!
Cats | Answered on Apr 01, 2020
4009dl
Cats | Answered on Feb 04, 2020
I re-roped my scratching post. Get 3/8 sisal rope. The hardest part was getting the post off the base and wrapping the rope tight. You will need a staple gun. Round staples are best but I think you can work with flat ones. Only use them at the ends and bury them well.
Cats | Answered on Oct 15, 2019
talk with a vet
maybe you are not using the correct food for baby parrots
Cats | Answered on Oct 12, 2019
The cat will be fine as long as the meat is ok.
Cats actually like raw chicken and many people feed their cats almost entirely with it.
Cats | Answered on Oct 04, 2019
Cat food is easily more expensive than dog food, due to dogs being biologically capable of processing vegetable proteins whereas cats cannot. This means cat food SHOULD only contain animal protein and is thus more expensive.
Cats | Answered on Aug 26, 2019
Discovery Channel Animal Planet Dog Or Cat Auto-flow Bubbling Pet Fountain Waterer Logo
2 questions posted
Top Discovery Channel Cats Experts
Ruth summersides
Tom Chichester
David Payne - Geek
David Payne - Geek
Are you a Discovery Channel Cat Expert? Answer questions, earn points and help others
View Most Popular
  • Discovery Channel Cats
Most Popular Question
animal planet auto flow pet fountain
  • Cats
