20 Most Recent
Toshiba Satellite P105-S6207 Laptop Questions & Answers
Color lines and dark parts
I had a Toshiba Satellite and it developed the same colored lines problem. It will continue to deteriorate until you cant see any thing behind the lines. I found it to be a bad video card.
Problem is....the video card (in most if not all Toshiba's of those days) is integrated into the mother board and can not be replaced separately. You must replace the mother board to correct the video card problem. Due to the expense, I'd rather buy a new PC and have the data trans'd to the new PC.
------------------------bp
6/2/2014 1:23:58 PM •
Toshiba...
Answered
on Jun 02, 2014
Vertical lines in my laptop screen
There could be three different possibilities why you would get a line on your lcd display.
First, it could be a missing signal from the controller IC to LCD driver IC
Second it could be a defective LCD driver IC itself
Third it could be a dry contact in the tape carrier package ( TCP).
Attach an external monitor to your laptop and make it your primary display unit to see if you are still getting the lines if not its you TCP if you still get lines it will need to have either the LCD IC or the controller IC checked and possibly replaced.
6/2/2014 1:11:31 PM •
Toshiba...
Answered
on Jun 02, 2014
How do i get f8
This is not enough information to answer. What exactly are you trying to do?
10/14/2013 8:06:22 PM •
Toshiba...
Answered
on Oct 14, 2013
I have a Toshiba Satellite
If you hav enot changed any software on the pc (like the drivers or new video software) the video controller may be bad an need replacement. If you are not familiar with doing it, try a repair shop, it may be more close to the cost of / or more expensive than replacing the laptop.
9/4/2013 7:30:52 PM •
Toshiba...
Answered
on Sep 04, 2013
How to restore my inspiron
THERE IS NO SHORTCUT TO RESTORE A PC LIKE MOBILE DEVICES.BUT YOU CAN UNINSTALL THE UNWANTED THINGS BY GOING TO CONTROL PANEL>PROGRAM AND FEATURES AND THEN CHOOSE THE PROGRAMS YOU DON'T NEED.
2)OR YOU CAN SIMPLY REINSTALL OPERATING SYSTEM .THIS WILL MAKE YOUR SYSTEM A FRESH NEW SYSTEM LIKE YOU BOUGHT IT NOW.
7/22/2011 5:24:25 AM •
Toshiba...
Answered
on Jul 22, 2011
Toshiba L30-101 i want to
Press F8 as it boots, that will give you access to the rescue/restore start up system; assuming it has not been deleted from your partition.
2/13/2011 12:29:19 PM •
Toshiba...
Answered
on Feb 13, 2011
I have a problem with
Consult the MFR of the game - they may provide a patch file. You can also re-install Directx from the Microsoft Update website.
10/28/2010 12:56:45 AM •
Toshiba...
Answered
on Oct 28, 2010
How to reset my dell
Do you have problems with a Dell inspiron or with a Toshiba Sattelite?
You'll have to use the CD/DVD that was shipped with your laptop.
Put it in your drive and boot up with it.
Some models have a recovery program and you'll have to burn the CD or DVD first.
9/22/2010 7:01:23 PM •
Toshiba...
Answered
on Sep 22, 2010
My laptop keep shutdown by
Try to take the battery out
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
If it works for you than its great else it is a hardware problem with your laptop. Your laptop turns off due to high heat.So, if the above solution doesn't work then take to a hardware shop.
Good Luck!
6/26/2010 3:28:14 AM •
Toshiba...
Answered
on Jun 26, 2010
What do i do to restore my inspiron 1501 to
You can restore to factory setting by follow these step
- Restart your laptop
- Press f5 or f6 button much times (rapidly) to run recovery wizard in recovery wizard ,select and click on recover c: driver
note :
DO NOT click on "
restore completely my system" because all data in youre hard disk will be deleted (delete all partition's) & not complete restore
. Only click on restore c: drive
hope it help and hav a nice day
regards
4/15/2010 1:08:26 PM •
Toshiba...
Answered
on Apr 15, 2010
Restore to factory settings
Shut down the system, restart the system when system rebooting type F8 fallow screen direccions
11/17/2009 6:59:36 PM •
Toshiba...
Answered
on Nov 17, 2009
