20 Most Recent Gateway MP8708 Notebook Questions & Answers
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally. Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter). Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion: Restore Windows XP MBR without Windows XP disc Alternatively, review my search results for other instructions: fdisk mbr windows xp Google Search
12/20/2017 10:49:00 PM • Gateway MP8708... • Answered on Dec 20, 2017
2answers
Hi, I'm having a number
I am not an expert but if I had your problems I would format the drive and load Windows 7 and add any drivers needed from appropriate websites. I don't trust recovery discs and have never had any luck with them, certainly not when loading onto a clean drive. If it works ok you could load XP home or pro in a partition if you really need it or alternatively try Linux. A friend has stopped Using Windows completely and has found Linux is able to meet all his needs...
2/28/2017 6:27:40 AM • Gateway MP8708... • Answered on Feb 28, 2017
Update bios gateway MP8708
Why?Gotta know. ONE tiny little mistake, and you don't have a computer anymore.Post back in a Comment.Regards,joecoolvette
1/9/2013 8:04:18 PM • Gateway MP8708... • Answered on Jan 09, 2013
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck Related: windows won't start
9/18/2012 10:01:13 AM • Gateway MP8708... • Answered on Sep 18, 2012
Mp8708 won't light up or go to bios
The your mobo doesnt support the cpu.Try put the old cpu and if is good then the new one doesnt support for the mobo.
5/1/2012 2:51:23 AM • Gateway MP8708... • Answered on May 01, 2012
I have a gateway mp8708
One of two things are likely your problem:
1) The battery is so dead that it's preventing any power from reaching the rest of the PC. Try pulling the battery out, plugging the laptop in, and turning it on.
If that doesn't work,
2) The motherboard power converter is burned out. If this is the case, unfortunately you will need a replacement motherboard or a replacement laptop.
Good luck, and hope this is helpful!
5/18/2011 7:37:06 PM • Gateway MP8708... • Answered on May 18, 2011
Cannot find my recovery disk
Gateway has a site on the topic
http://support.gateway.com/s/software/medialess/faq/suppage01su44.shtml
If your system is intact, you can create the recovery CDs, following the instructions.
If not, you need to order a new set.
There is no legal place to download recovery CDs, since they contain copies of the Microsoft OS.
4/19/2011 6:05:07 PM • Gateway MP8708... • Answered on Apr 19, 2011
Modem usb dosen t work
2/20/2011 2:36:40 PM • Gateway MP8708... • Answered on Feb 20, 2011
My son bought a Gateway
The reality is, Best Buy will only swap parts. there are other vendors on the internet that will replace discrete components. Google for "laptop power jack replacement" to find options. it takes decent skills to do this kind of repair, so research well.
2/11/2011 1:57:28 AM • Gateway MP8708... • Answered on Feb 11, 2011
2answers
I can't find the connector for my bluetooth module
Get the service manual of your laptop, if not possible try websites like: http://www.insidemylaptop.com/ they have a lot of disassembly guides.
10/26/2010 7:17:56 AM • Gateway MP8708... • Answered on Oct 26, 2010
3answers
Where is the bluetooth-cable connector on the
I believe he's asking where to add the aftermarket modules: GABU-MP8708-0001 MODULEGACA-MP8708-0038 CABLE
1/12/2010 6:23:00 PM • Gateway MP8708... • Answered on Jan 12, 2010
I have a Gateway MP8708 lappy. While surfing the
Take the battery out and try to boot it on AC power only, if the machine boots but can't load the operating system then the ticking sound could be and sounds like the hard drive has possibly failed.
Good luck.
6/29/2009 7:14:11 PM • Gateway MP8708... • Answered on Jun 29, 2009
No bootup-only has electrical power
hmmm..not too good...nada on the screen? Can you boot from a cd?
4/29/2009 12:17:39 AM • Gateway MP8708... • Answered on Apr 29, 2009
Gateway MP8708 Motherboard replacement instructions
Hi
the link to order mother board for your notebook
http://product.pelltechnology.com/Gateway_MP8708_Notebook_Motherboard_Replacement.asp
thanks for using fixya .....rate this solution.....
2/9/2009 5:09:59 PM • Gateway MP8708... • Answered on Feb 09, 2009
System restore
give your sels full prilages in user acount cheask run spyware cleaners noadware and trendmicro and cc cleaner free junk tool
1/19/2008 5:58:37 PM • Gateway MP8708... • Answered on Jan 19, 2008
I RECEIVED MY NEW TELSTRA GATEWAY 2 MODEM TODAY EVERYTHING IS WORKING FINE BUT THE PHONE LIGHT IS NOT ON I CAN'T USE MY LANDLINE PHONE. WHAT CAN I DO?
wow last land line on earth? in what country? to use any dial up hardware modem it takes special dial up application, that can talk to the modem is this USB modeM????????? GW sold all this to you why not ask them for the manual and the CD disk with the dial up app there. or is this DSL or ASDL modem? are you DOWN under, ? https://crowdsupport.telstra.com.au/t5/modems-hardware/gateway-max-or-gateway-max-2-modem/td-p/623537 the modems have full and real model numbers nobody can guess modems , must be clear. dad what's a land line?, answer , the're long long gone now .
1/11/2022 7:00:48 PM • Gateway... • Answered on Jan 11, 2022
Where can you buy a GATEWAY LT20 NETBOOK setup disk
not problem told at all, just asking for vague disks (lost?) windows install disk or BIOS setup (there is no bios disk) gateway CD with all driver for the LT20, ask them yet. no oS told are you running old OS? LT20 is called NETBOOK at GW. and all data for it is there at GW, I see it now./ XP a is only supported by GW. (w7 up is dead there) age is 2010, so is 12 years old the COIN cell is dead this old and means can not be ignored, it will fail to boot , dead coin and worse. ask them for XP install disks for XP, and this PC. only they have that if at all, most maker now ban all XP support of any kind due to MS zero support 2014 ended, and XP is virus magnet so they do not want to perpetuate that. (nasty stuff) im reading your user guide now at GW. and reading the recovery page what you call RESET, ( i guess) index states page 46 RECOVERY.. on most PCs there are 3 ways to recover, now. 1-the disks set lost from DAY 1, NEw PC, xp GW installer 2-you made you own mirror backups day 1. and or lost now. 3- and last the XP image restore. page 46 says do step 2 above. then it says Reset your system to its factory condition., page 48 then it says If you cannot run Windows and your original hard drive is still working, see "Recovering from the hard drive during startup" on page 48. then it says Recovering from the hard drive during startup To reinstall Windows and all pre-installed software and drivers: 1. Turn on your computer, then press Alt+F10 during startup. Gateway Recovery Management opens. 2. Click on Restore system from factory default. Caution: Continuing the process will erase all files on your hard drive. there I read your manual to you, most PCs made have the same words, in chapter RECOVEY. (OS) if the HHD is bad all the above will fail never seen 12 year old good hdd me,but still looking for 50 years. click 4.7MB uses guide here https://www.gateway.com/gw/en/US/content/drivers-downloads next time tell what rest means to you. or stated a problem and if there is UNBACKED UP DATA there. and if expensive apps loaded, PAID. bios can be reset windows can be reset inside or reloaded fresh. or upgraded. HDD can be erased that to is a reset for sure infected. Power on can be reset hold power button 10 seconds and release. and more, billions of bits to reset. endless.(geek land)
1/11/2022 6:51:27 PM • Gateway... • Answered on Jan 11, 2022
Gateway MP8708 Notebook Logo
25 questions posted
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Jessie Goss
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
cannot find recovery disk
  • Computers & Internet
