20 Most Recent
LG Revere VN150 Verizon Wireless CePhone Questions & Answers
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
