20 Most Recent Dell Inspiron™ E1505 PC Notebook Questions & Answers
To turn up the master volume on most dell laptops, use
Fn + PageUP
the FN key is usually blue.
To turn it down use Fn+PageDown
Dell Inspiron™... • Answered on Nov 07, 2013
Link for downloads.
Dell Inspiron™... • Answered on Jun 29, 2013
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode Safe Mode with Networking Safe Mode with Command Prompt Enable Boot Logging Enable VGA mode Last Known Good Configuration (your most recent settings that worked) Directory Services Restore Mode (Windows domain controllers only) Debugging Mode Start Windows Normally Reboot Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed http://wiki.ljackson.us/Control_Userpasswords2 if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password
Dell Inspiron™... • Answered on Feb 17, 2013
"definiton"? I'm not sure what your question is?
Dell Inspiron™... • Answered on Dec 28, 2012
overheating?did you do any hardware upgrade befor this problem?
Dell Inspiron™... • Answered on Nov 15, 2012
windows and type 32 bits or 64 bit i have driver but i need to know the system
Dell Inspiron™... • Answered on Oct 03, 2012
To restore the computer to the Original Factory settings perform the following steps:
Turn off the Computer
connect it to the Power outlet with Adapter
Turn on the laptop
The moment you see the Dell Logo, Press the Ctrl Key and start tapping the F11 key. You will get a screen which will give you options to restore the computer. Select the option which says Restore to Original Factory Settings. It will run the restore and your computer will be restored to Factory setting within 15 - 20 minutes.
Note: you will lose all the programs and applications that you have installed and also the files and documents stored in your computer (including the email in Outlook). You computer will be as it was when you first Purchased it.
P.S: You can restore the system to Factory settings only if you have not formatted or replaced the Original Hard Drive.
Hope you find this information helpful.
We highly appreciate your comments and ratings. Please do not forget to leave your feedback and ratings.
Thank you for choosing Fixya
Dell Inspiron™... • Answered on Sep 21, 2012
Should this be a Bios password, you will need to have this taken into a shop, Should it be a windows password Google password recovery CD.A windows password can be hacked, A bios password will take some time. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dell Inspiron™... • Answered on Aug 31, 2012
Hi there.
As far as i know there is no CMOS jumper in the dell E1505, but what you can do is remove the motherboard battery for an hour to hopefully reset the bios.
Take the main battery out of the laptop as well as the AC power supply so the laptop is receiving no power at all. Push the lid back as far as it will go and remove the hinge cover like this >>>>
Now you have to lift the keyboard, there are 2 screws at the top of the keyboard so unscrew them and gently lift the keyboard up like this >>>>>>
You will see in the illustration the motherboard battery, just take it out for an hour and then put it back in, please be careful with the keyboard as there is a delicate ribbon cable, if you have to, remove the keyboard from the motherboard.
To release the keyboard cable from the keyboard connector on the motherboard, rotate the plastic bar on the keyboard connector toward the front of the computer.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
Dell Inspiron™... • Answered on Jul 21, 2012
Hi there,This error refers to an expansion card having an issue. If you've got any cardbus, wifi, bluetooth, etc cards take them out and see if that resolves the issue. More info here: http://www.techsupportforum.com/forums/f217/i-o-card-parity-interrupt-at-f000-e1ad-417586.html
Dell Inspiron™... • Answered on Jun 07, 2012
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine. If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs. In windows xp you get to the dos command prompt by selecting R for repair when the options appear. In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Dell Inspiron™... • Answered on Jun 06, 2012
make sure all lead connections are secure and dust free usb and electricalYou might have to uninstall the printer restart your computer then reinstall your printer click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver disable uninstall or select properties again you will have the similiar options also you can troubleshoot the device
if you dont have the driver on a disk you will need to download onehttp://download.cnet.com/hp-4500-all-in/3000-2116_4-75213057.htmlHP PRINTER DRIVER PACKAGES
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=25523
you will need to select a language
you will have to select an operating system 32 or 64 bit
hope this helps you
Dell Inspiron™... • Answered on May 13, 2012
There may not be a fix your machine may not handle the requirements necessary to run this graphics game high end. You can always upgrade more memory and a better video card just a suggestion. Some games just are hard to load and maintain quality and speed while glitching or freezing up that is lack of resources or to many open programs while playing the games. Stuff in the background may be running you do not need running all this has its factors in keeping a game on track. It could also be that your machine needs a good cleaning or defrag. There are so many different reasons when I play a game I use a gaming computer which is basic and no other software is installed but games period and the operating system to run the games. I do not use my PC or laptop for both. One thing at a time unless you have a good gaming laptop or PC you will have these issues every time. That has been my experience............John
Dell Inspiron™... • Answered on Apr 25, 2012
Try uninstalling the Bluetooth audio driver and then install the audio driver using the Service tag number.You can download the device drivers from Dell WEB site,the support download page. Make sure you select your model desktop or laptop,better still, type in the Service Tag number, it is printed on the label on thebottom of the laptop and on the back or sides of a desktop. (If the Service Taglabel is missing then go into the BIOS setting and on one of the BIOS pages,the Service Tag number will be displayed). This will open the page where thespecific drivers for your model computer are located. Also make sure you selectthe Windows of the drivers for your Windows operating system. Click on thislink to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Dell Inspiron™... • Answered on Mar 25, 2012
Dont try over it your self, take it to the nearest Dell service centre
Dell Inspiron™... • Answered on Sep 14, 2011
Go to this site:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRONI6400/E1505&os=WW1&osl=en&catid=&impid=
Under the audio section, select the second driver to install.
Hope you get some sound back!
Dell Inspiron™... • Answered on Jun 14, 2011
Dell Inspiron™ E1505 PC Notebook Logo
120 questions posted
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
restore factory defaults
  • Computers & Internet
