20 Most Recent
Averatec AV7155-EA1 (AV7155EA1REF) PC Notebook Questions & Answers
Does averatec 7100 u have windows 7 drivers
Greetings! I just finished a successful W7 build on a 7100. Here's the driver set..., https://dl.dropbox.com/u/17664826/Apps/Averatec%207100%20%28W7%20Drivers%29.zip
2/4/2013 1:31:12 PM •
Averatec...
Answered
on Feb 04, 2013
Averatec 6200 motherbord specifications ? Compatible procesor upgrade with SSE 2 thanks
The Averatec 6200 laptop was released in 2004 and is powered by an AMD Athlon XP-M 2400+ processor with a clock speed of 1.8 GHz . The motherboard of the Averatec 6200 is based on the SiS741 chipset. The laptop comes with 512 MB of RAM and a 60 GB hard drive . The laptop's display is a 15.4 inch, 1280 x 800 (WXGA) screen.
As for the processor upgrade, the Averatec 6200 is compatible with processors that support SSE2 2. SSE2 is an extension of the IA-32 architecture, based on the x86 instruction set. Therefore, only x86 processors can include SSE2. The AMD64 architecture supports the IA-32 as a compatibility mode and includes the SSE2 in its specification. This means virtually every modern Intel and AMD CPU supports SSE.
11/19/2023 8:49:05 PM •
Averatec...
Answered
on Nov 19, 2023
Averatec e1200 laptop i think it caught a virus
Hold the delete button when you turn it on and see if it loads BIOS up. If the screen displays the BIOS OK then you can change the boot sequence to CD/DVD or USB first and do a fresh windows installation. You could also try holding F8 at bootup and try loading safe mode. If this doesn't help it could be a problem with your screen or the wiring going to the screen. Possibly also a problem with the graphics card.
11/23/2017 6:51:48 AM •
Averatec...
Answered
on Nov 23, 2017
Find a boot device?
You need to obtain a recovery CD for your operating system. It will give you some recovery options which may work. If not you will probably have to reload the operating system. You might be lucky and there is a hidden recovery partition to set the machine back to factory state. Google your machine for recovery partition option.
12/27/2014 10:03:08 AM •
Averatec...
Answered
on Dec 27, 2014
