20 Most Recent Joy Toshiba M105 S3002 Notebook Questions & Answers
Hello.
• 1
Clean the area around the affected key. Use a damp cloth to clean the surface of the key (and surrounding keys) and then use a dry cotton swab to clean under the stuck key. Be careful not to pry the stuck key up with the cotton swab, as this could break the stuck key.
• 2
Press firmly on the stuck key. Sometimes after small dust or particulates are removed, the stuck key will pop back into place. However, if this is not the case, continue on with Step 3.
• 3
Pull out the fingernail cleaner extension of your fingernail clippers. This is the flat extension with a little hook on the end. Place the small hook under the left corner of the stuck key. A common reason that keys get stuck is that the collapsible spring becomes off-center. Gently push the key from side to side until it clicks into place. If this does not happen, you will need to disassemble the key completely.
• 4
Lift the top part of the key with the fingernail cleaner. You will see a collapsible plastic hinge (this is known as the Key Retainer) as well as a little rubber piece. Take both of these out. You will see a flat surface. Run the cotton swab across this surface to remove any dust.
• 5
Place the key components back in the keyboard. Place the rubber part on top of the metal circle you just cleaned with the cotton swab. Then place the key retainer (big side down) on top of it, and "click" it into place. It is very important to be careful with this step as these small parts break easily. Then place the stuck key on top of these parts and then give it a solid tap to click it into place. Your key should work now.
Hope this helps.
Joy Toshiba M105... | Answered on Aug 02, 2011
The windex may have seeped up into the screen. It should dry in a few weeks.
Joy Toshiba M105... | Answered on Oct 03, 2009
try : start-control panel -mouse and keyboard, if nothing weird appear,try to reinstall the driver for the keyboard,you'll find it here:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1311513&rpn=PSMA0U&modelFilter=M105-S3002&selCategory=3&selFamily=1073768663&selModel=1311513%7CPSMA0U
If it doesn't work you will have to change the keyboard and hopfully, there is nothing wrong with the motherboard
Joy Toshiba M105... | Answered on Jan 01, 2009
Check for a clogged fan or other type of overheating.
Joy Computers &... | Answered on Oct 31, 2018
What TV do you have? Some have it built in but most do not.
If its not a smart TV then you can buy a Roku box that will support Netflix and other channels.
Joy Computers &... | Answered on Dec 23, 2017
Joy Toshiba M105 S3002 Notebook Logo
4 questions posted
Top Joy Computers & Internet Experts
Lee Hodgson
Lee Hodgson
john h
Andrew Taylor
Andrew Taylor
Are you a Joy Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Joy Computers & Internet
Most Popular Question
spilled water toshiba satellite notebook
  • Computers & Internet
