20 Most Recent Fitbit Ultra Wireless Activity/Sleep Tracker color: Plum Questions & Answers
what to di if fitbid flashes FITBID 414
Fitbit Ultra... | Answered on Oct 14, 2014
Contact Trotter to inquire.
Exercise &... | Answered 14 hours ago
A weight belt, also known as a weightlifting or powerlifting belt, is used to help with exercises that involve lifting heavy weights. Basically, it protects your back to stop you from straining anything as you lift something really heavy above your head. At the same time, it squeezes the abs to create the tension required to lift heavy weights. This makes it great for beginners as it helps to train them to use their muscles properly while promoting good posture.
If you're wondering what exercises to use weight belt for, then it depends on the type of belt. Powerlifting belts are best for deadlifts and squats but weightlifting belts help with clean and jerk movements. You can also use a weight belt when doing bench presses and overhead presses. If you want to find out more about exercising with a weight belt, visit Muscle Lead's website.
Exercise &... | Answered 2 days ago
To factory reset your tracker:
  1. Attach the charging cable to your tracker and plug the other end into a USB port.
  2. Press and hold the button for approximately two seconds and without letting go of the button:
    1. Remove the charging cable from your tracker.
    2. Wait about seven to nine more seconds after removing the charging cable.
  3. Let go of the button and hold it down again.
  4. After "ALT" and a white screen flash, let go of the button and hold it down again.
  5. After you feel a vibration, let go of the button and hold it down again.
  6. After you see "ERROR," let go of the button and hold it down again.
  7. After you see "ERASE," let go of the button. The tracker will turn off.
  8. To turn your tracker back on, press the button or attach the charging cable (make sure to plug in the other end of the cable). If the time on your tracker reads 0:00, the reset was successful.
  9. Next you'll tell your Fitbit account that you're setting up a new device.
    1. If you use the Fitbit app, tap or click the account icon and choose Set Up a Device. Follow the instructions to replace your device.
    2. For fitbit.com instructions, see How do I set up my Fitbit device?
Exercise &... | Answered 3 days ago
Hi There,
This error leads to excessive current according to this .pdf.....
http://gymstore.info/manuals/upload/Cybex/cybex_error_codes.pdf
This mentions checking the motor, and certainly could be generated from the lower control board. I recall these controllers as quite large with maybe 4 to 8 large storage capacitors on them, which do fail over the years, and could cause this. Does the tread run at all? Error right away or move the belt then error?
Exercise &... | Answered on Nov 18, 2020
I would try the manufacturers web site.
Exercise &... | Answered on Nov 16, 2020
Overheating normally. You just have to find out why?
Google
make model, treadmill stops
Exercise &... | Answered on Nov 13, 2020
OPEN MOTOR SHROUD INSPECT THE COMPARTMENT ON THIS INSTANT I BELIEVE THAT THE SENSOR IS AT THE OPPOSITE END OF THE MOTOR THE LEADS GO INTO MOTOR CONTROL BOARD I WOULD FIRST UNPLUG AND PLUG THE CONNECTOR THIS WOULD CLEAN ANY OXIDATION OFF. IF NOT YOU SHOULD BE ABLE TO DO THE REPAIR
Exercise &... | Answered on Nov 12, 2020
Request the manual from Roger Black.
Exercise &... | Answered on Nov 11, 2020
You likely have a bad motor control board. Give CircuitBaordRepair.net a call. They may have a replacement or be able to fix yours.
Exercise &... | Answered on Nov 10, 2020
Fitbit Ultra Wireless Activity/Sleep Tracker color: Plum Logo
33 questions posted
Top Fitbit Exercise & Fitness Experts
ray gallant
Joseph Coppeto
Joseph Coppeto
Are you a Fitbit Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Fitbit Exercise & Fitness
Most Popular Question
mean when fitbit flashes 414
  • Exercise & Fitness
