20 Most Recent Alcatel 356 Prepaid Unlocked Phone Questions & Answers
0answers
I did software update on 7Black Alcatel 1T and while installing it went blank.When i switched on again it does not gp further the the screen with phone logo. and i cant even reset phone at all.
In this case, it is likely that the software update failed and caused the phone to become unresponsive. You may need to try and manually reset the phone by pressing and holding the power button for a few seconds. If that does not work, you may need to contact the manufacturer for assistance.
4/2/2023 4:00:34 AM • Alcatel Cell... • Answered 6 hours ago
My Alcatel one touch asking for Network key when I insert my simcard,how do I get it
The network key is a code that is used to unlock your phone's SIM card for use with a specific network carrier. If your Alcatel one touch is asking for a network key when you insert your SIM card, it means that your phone is locked to a particular carrier, and you need to get the unlock code from the carrier or a third-party provider. To get the network key, you will need to contact the carrier that the phone is locked to and request the code. If you have completed your contract with the carrier, they may provide you with the code for free or for a fee. You will need to provide them with your phone's IMEI number, which is a unique identifier for your phone. If the carrier refuses to provide the network key or you don't want to pay the fee, you can also try third-party providers. These providers can unlock your phone for a fee, and they may provide you with the network key. However, be cautious when choosing a third-party provider and make sure they are reputable and reliable. Once you have the network key, you can enter it into your phone when it prompts you to unlock the SIM card. To do this, go to the phone's settings, then to the network settings, and look for the option to enter the network key. Enter the code, and your phone should be unlocked and ready for use with your SIM card.
3/11/2023 6:59:33 PM • Alcatel Cell... • Answered on Mar 11, 2023
Why won't the back button work on my Alcatel pxi theatre
I admire this information for the well-researched content and excellent wording. I acquired so involved in this material that I couldn't stop reading. I'm impressed together with your work and skill. Thanks so much. wedding flip flops for guests
3/11/2023 1:04:14 PM • Alcatel Cell... • Answered on Mar 11, 2023
2answers
Forgot password on alcatel one touch p310
Hi there again. Epson lx350.i replaced main board only to find out later the one pin not working is actually in a fired position until when I switch machine off is when the pin goes back.please assist If I understand correctly, you are saying that after replacing the main board in your Epson LX350 printer, you have found that one of the pins is not functioning properly and it only resets when you switch the machine off. In this case, it's possible that there is an issue with the connection between the pin and the main board or the pin itself may be damaged. Here are some steps you can take to troubleshoot the issue:
  1. Check the connection between the pin and the main board. Make sure that the pin is securely connected to the main board and that there are no loose connections.
  2. Inspect the pin itself for any physical damage or signs of wear and tear. If the pin is damaged, it may need to be replaced.
  3. Check if the pin is properly aligned with the other pins on the main board. If it is misaligned, this could cause the issue you are experiencing.
  4. Check if there are any firmware or software updates available for your printer. Sometimes, updating the firmware or software can fix hardware issues.
If none of these steps resolve the issue, you may need to contact Epson support for further assistance or consider consulting a professional technician to diagnose and fix the problem. My seca 813 only showing STEP OFF AND STOP massage cannot reset ?? If your Seca 813 is only showing the "STEP OFF" and "STOP" messages and is not responding to any commands, it is possible that there is a problem with the scale's sensors or the internal circuitry. Here are some steps you can take to troubleshoot the issue:
  1. Make sure that the scale is on a flat and stable surface. If the scale is on an uneven surface or is wobbling, it may not be able to take accurate readings and could display error messages.
  2. Check the scale's batteries. If the batteries are low, this could cause the scale to malfunction. Replace the batteries with fresh ones and try turning the scale on again.
  3. Reset the scale. Some scales have a reset button or function that can be used to clear any errors or malfunctions. Refer to the user manual for instructions on how to reset your specific model of scale.
  4. Check the scale's sensors. Over time, the sensors on a scale can become dirty or worn, which can affect their accuracy. Clean the sensors with a soft cloth or brush and see if this resolves the issue.
  5. If none of the above steps work, you may need to contact Seca support or a professional technician for further assistance. They may be able to diagnose the issue and recommend a repair or replacement if necessary.
Forgot password on alcatel one touch p310 - Alcatel Cell Phones If you have forgotten the password for your Alcatel One Touch P310 phone, you can try the following steps to reset the password:
  1. Turn off your phone.
  2. Press and hold the Volume Up button and the Power button at the same time until the recovery mode screen appears.
  3. Use the Volume buttons to scroll down to "wipe data/factory reset" and press the Power button to select it.
  4. Scroll down to "Yes" and press the Power button to confirm.
  5. Wait for the reset process to complete. This may take a few minutes.
  6. Once the reset is complete, use the Volume buttons to select "reboot system now" and press the Power button to restart your phone.
  7. Your phone will now be reset to its factory settings, which means that all data and settings, including the password, will be erased.
Note that this process will erase all data on your phone, so make sure to backup any important data before proceeding. If you are unable to reset the password using this method, you may need to contact Alcatel support or a professional technician for further assistance.
3/6/2023 7:50:46 AM • Alcatel Cell... • Answered on Mar 06, 2023
Water inside the alcatel screen
Total loss as water will have also damaged the battery and all the electronics inside.
2/24/2023 10:33:44 PM • Alcatel Cell... • Answered on Feb 24, 2023
On Alcatel A206G flip phone, the screen shows INSERT SIM! error code with SIM installed.
Yes, you can try to back up your contacts from the phone before replacing it. You can use a third-party software such as dr.fone - Phone Backup & Restore to back up your contacts from the phone. This software is available for both Windows and Mac computers.
2/22/2023 10:52:33 PM • Alcatel Cell... • Answered on Feb 22, 2023
Help codes for Alcatel modem
Unfortunately, I cannot provide you with the RCK and NCK codes for your Alcatel modem. These codes are specific to your device and are not publicly available. You will need to contact your service provider or the manufacturer of the modem to obtain these codes.
2/22/2023 10:32:33 PM • Alcatel Cell... • Answered on Feb 22, 2023
Hi, my incoming calls are going to messages and volume on incomings calls is very low
If your incoming calls are going to messages and the volume is lower than usual, it could be due to a problem with the phone settings. Try checking the volume settings on the phone, and make sure the volume is not turned down too low. Additionally, you may need to check the settings for your phone's voicemail, and make sure that your voicemail is not set to kick in after a certain amount of time. If these settings don't help, then you may need to contact your phone's manufacturer for further assistance.
2/4/2023 5:52:23 AM • Alcatel Cell... • Answered on Feb 04, 2023
Does my Alcatel GO FLIP 3 have do not disturb? Something happened and my phone will not ring anymore. I must have changed something and I don't know what?
Question edited for clarity and correct name of the phone. Question moved from Land Phones to Alcatel Cellphone. The A3 has Do Not Disturb, but the Flip doesn't. Your phone is very basic. Here is the manual https://www.metrobyt-mobile.com/content/dam/mpcs/faqsandsupport/alcatel/Alcatel-GO-FLIP-3-UserGuide.pdf So not ringing is likely caused by turning the volume down to off. https://www.google.com/search?q=alcatel+go+flip+3+not+ringing ..
10/19/2022 11:16:28 PM • Alcatel Cell... • Answered on Oct 19, 2022
Why does my alcatel phone flash enjoy.now and wont turn o
Enjoy.now is the essential app for Alcatel smartphone users. notes for :if doing an update After update phone asks to do restart Let it When it comes back on it shows enjoy.now flashing Leave it flash till it natural goes into power down mode Leave for another 5 minutes Then power on as normal and all should be ok It was on mine
10/11/2022 10:06:30 PM • Alcatel Cell... • Answered on Oct 11, 2022
2answers
Sim locked sos only
What is Alcatel Model,which network,country it's locked now?Get the Unlock code from the siteTheunlockarena.com/supported-phones/rs13wp7/ and Unlock it from network lock easily...
8/18/2022 6:18:28 PM • Alcatel Cell... • Answered on Aug 18, 2022
I need help putting in the pin number
Hello Michael Add the Alcatel model number to this Google search query, or you can also Google 'make model manual'. There are videos in the link that may help. https://www.google.com/search?q=alcatel+%28model%29+phone+enter+pin+code ..
8/18/2022 4:33:50 PM • Alcatel Cell... • Answered on Aug 18, 2022
How do I add minutes to an alcatel flip phone? What is the website to go to?
Contact the SIM card provider for prices and details.
8/2/2022 2:38:52 PM • Alcatel Cell... • Answered on Aug 02, 2022
Alcatel 356 Prepaid Unlocked Phone Logo
9 questions posted
Top Alcatel Cell Phones Experts
ADMIN Eric
ADMIN Eric
NADARK
NADARK
nexrad_chris
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Alcatel Cell Phones
  • Alcatel Cell Phones
Most Popular Question
virgin mobile open lock model haier hc
  • Cell Phones
