20 Most Recent ATI RADEON 7500 (64 MB) AGP Graphic Card Questions & Answers
hi hope this link helps http://ati.amd.com/support/driver.html.
ATI RADEON 7500... | Answered on Oct 05, 2008
Try going online to call up the specs on your motherboard. You could also call Acer or check their website.
ATI Computers &... | Answered on Mar 18, 2019
Your heatsink fan on the graphic card is failing and the motor is going down hill, now saying it has completly stopped..,.. that means the fan motor is done for and need to be replaced to avoid further damage to your graphic card. Would reccommend you not using your graphic card until a new heatsink fan is replaced otherwise you can fry your GPU and suffer a complete loss.
ATI Computers &... | Answered on Feb 05, 2019
How did you get your drivers and graphics? Did you install the whole package? What is the Asus model #? How much Ram do you have? I'm going to do a little research but let me know what you have.
Dave
ATI Computers &... | Answered on Feb 03, 2019
Are you certain that your mainboard is PCIE 2.1 and not PCIE 2.0? PCIE 2.1 cards like yours will not work on a 2.0 mainboard (2.0 cards will work on a 2.1 board, however) If this is the case, you will need to get a compatible card.
If this isn't the case, have you tried this card in a different PC? It could also be that the card has a problem.
The last possibility is that there are power issues. A couple of possibilities:
  1. An external power connector (6-pin PCIE direct power to the video card) is unplugged. Check and re-test.
  2. Your power supply (PSU) doesn't provide enough power to your graphics card & the rest of your system. Check your PSU's specs against the specs for your card. HIS recommends a minimum 450W PSU, and I would recommend a good quality Antec, Corsair, or PC Power and Cooling or Cooler Master product in the 500W range for this card.
  3. You got a bad card, or else it shorted out, etc. during setup or installation.
ATI Computers &... | Answered on Feb 01, 2019
It too old just upgrade your card
http://www.3dpchip.com/3dpchip/3dp/chip_down_en.php
this link will provide you a software which will provide you most of the drivers.
ATI Computers &... | Answered on Jun 11, 2018
your card is the gigabyte GV-RX195P256D-RH and you can download the drivers from here https://www.gigabyte.com/us/Graphics-Card/GV-RX195P256D-RH#support-dl-driver-vgadriver
ATI Computers &... | Answered on Jun 03, 2018
my examination of AMD's AMD Radeon HD 5000, HD 6000, and HD 7000 Series CrossFire Compatibility Chart tells me that these cards are not interoperatible in crossfire. See for yourself at AMD CrossFire Compatibility Chart
18.January.2016
ATI Computers &... | Answered on Jan 18, 2016
what is that but if you want a good graphic card take gt 220
ATI Computers &... | Answered on Jan 17, 2016
this made no sense u ******.
ATI Computers &... | Answered on Nov 03, 2015
These schematics are almost impossible to obtain unless you are an employee.
It is a lot easier to buy a used replacement card on Ebay
If the capacitors are leaking, I would check to case cooling fan.
The case is probably running too hot.
ATI Computers &... | Answered on Oct 04, 2015
Chris, let's back up just a second. Before you go for a new graphics card, just what problem are you trying to solve? If you're watching TV, the graphics you already have are likely just fine.
If you feel your system is slow doing regular stuff, more RAM may help, or a faster disk drive.
About the only thing a fancy graphics board will get you is faster screen updates for gaming. If that's what you're after, you may want to consider a full system update, with standard height case, 500 watt power supply and all of that....
ATI Computers &... | Answered on Jul 03, 2015
ATI RADEON 7500 (64 MB) AGP Graphic Card Logo
1 questions posted
Top ATI Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ATI Computers & Internet
Most Popular Question
driver ati radeon
  • Computers & Internet
