20 Most Recent
Belkin (F5D7050) (F5D7050VSNPDQ) Wireless Adapter Questions & Answers
Belkin f5d7051 not detecting
ivegot the same problem, it worked previously and then randomly it stopped working. I have reinstalled windows 7 and it is still the same, i cant install itand cant detect the usb adapter. Have you found the solucion? Please email me to
[email protected]
Belkin Wireless USB Adapter not detected!
This device is well known for the high level of current draw that it requires in order to work. I would suggest that you remove all other unnecessary USB devices and try the device again. It is more than likely that your system will find the device.
The quickest way of ensuring continued usage, when you have numerous USB devices, is to purchased a powered USB hub and ensure that the Wireless adapter is connected to one of the powered USB ports on the hub.
Hope that helps.
It's as if the card isn't even trying to connect
Since you did not say what operating system you are using it makes it difficult to pinpoint your help.
Let us assume you are using Windoze.
This is a typical windows problem with any hardware. Sometimes the fault lies in your operating system, sometimes the fault lies in your software drivers.
The first thing you need to do is uninstall the hardware and uninstall the drivers. Then restart your computer. Then turn off your computer and reinstall the hardware and the drivers. This usually solves the problem.
If it does not solve the problem,
1. look for updated drivers for your hardware and install the updated drivers.
2. Make sure your windows OS is updated with all high priority updates.
3. Try hardware on another computer to make sure hardware is working properly.
My software says it doesnt detect the adapter
first power on your wireless switch then insert software cd of your wireless adapter. then restart your system. okay
if it doest not work then go to device manager and under network adapter update your driver software for your adapter via internet. okay
Hi I have a belkin wireless G network adaptor. My
Typically these devices come with software that not only installs the drivers, but also installs some software that takes over the role of connecting to the network. In my experience, this belkin software fights with the default windows wireless networking function. Windows will connect and then the belkin software will try to connect and it disconnects the windows connection. I found that not using the manufacturers software and sticking with the Windows default works best. Simply disable the belkin software and remove if from Start>Programs>Startup. If the drivers are all installed properly then Windows should automatically connect.
If this doesnt solve it let me know.
Mtv music generator detecting directx 7
ok... so I've now installed this on my new pc that i built... first in order to get it to install at all you must download DirectX 7.0 and right click to "--(edit compatibility settings to windows 98/Me and run as administrator)--" remember this as well be doing it a few times. once you do that install DirectX 7.0 and say yes to all. now that this is installed take the .iso file you have and burn it to a cd or DVD-r, once burned you need to go to my computer and right click on the cd/DVD drive, select open (NOT open autoplay), inside the disc menu i want you to go to 2 files... "setup" and "start" need to also have their compatibility settings changed to the above settings. now that these are set stay in the cd menu and double click "setup" this will take you through the setup procedure. after the setup procedure is finished do not view the notes, and continue back to the desktop. now from your start menu load the game and it should run
I cannot connect to the
you need more than a wireless adapter to connect to the internet......
you need a wireless network to connect to. in cafe's and pubs the owner sometimes sets up a WiFi network that their patrons can connect to, however most people have to provide their own.
to get to the internet , you will need.
A broadband connection (ADSL / Cable) this normally comes with a standard NON wifi modem
A WiFi Router (including ADSL / Cable Modem) depending on what you have already.
then to link a remote PC / Laptop to this network, A suitable wireless adapter ( like your belkin adapter)
it is a common misconception that a wireless adapter is all you need (advertising is vague)
Blue light flashing
Do a hard reset,usually there is a button on the back of the router.With power plugged in,press and hold reset button 15 sec. then without releasing button remove power plug and hold an additional 15 sec.,then plug power cord back in and hold an additional 15 sec. After that release the reset button and it should reset to default.You may need to do this a few times but it should solve your issue.
How do I Reset my Belkin wifi Extender?
Using the reset button
The location of your range extender's reset button will vary depending on its model. The reset begins once you
press and hold thereset button for
at least 10 seconds while the range extender is powered
ON. The
Status Light on the the range extender will momentarily flash and will then begin to blink. When the light becomes solid again, the reset is complete.
Using the web-based setup page
If using the physical button does not work, you can access the range extender's web-based setup page and do the reset from there.
Before you begin:
- Make sure that the wireless computer or device you're using to access the web-based setup page is connected to the same network as the range extender.
- You need to identify the IP address that your router has assigned to your range extender. Locate this by accessing your router's DHCP Client table. Once you have the range extender's assigned IP address, use it to access your range extender's web-based setup page.
- Alternatively, you can enter "http://192.168.206.1" in the web browser's Address bar if your range extender has NOT detected a DHCP server in your network.
Step 1:
In the web-based setup page of the range extender, go to
Utilities and select
Restore Factory Defaults.
QUICK TIP: You may be prompted to log in with your range extender's administrator password. If you have not set any, simply leave the field blank and click on
Submit.
Step 2:
Click on the
Restore Factory Defaults button.
Your Belkin range extender should now be restored to its factory default settings.
Drivermax
Routers are very important for setting up an internet connection. As we all know, the Internet is the most important network, which connects us to the world. There are various companies exist in the market, which offers routers. But Belkin is the top market-leading company for routers. Advance features, technology is the attributes of the Belkin router. For a new router user, installation is a big challenge, and in case the user doesn't.have installation CD then it becomes more difficult. So in this blog, we are going to discuss
How to Setup Belkin Router Without CD. Now, you do not need to worry about the installation process, There are 2-3 ways to set up Belkin Router Without a CD.Now one question comes to your mind, How? So Tech Support Experts are here to answer all your queries. Our team is experts in technology and here we will elaborate on the steps to Setup Belkin Router Without CD.
How to uninstall belkin security
Scroll down and select your
Belkin device's setup utility. This varies by product, but begins with "
Belkin" followed by your device type. Click "
Uninstall" and enter your
Windows administrator password if prompted. Click "OK" to confirm that you wish to
uninstall.
How to Uninstall a Belkin Utility
