20 Most Recent Teac Dw 224E-R Disk Drive CD-RW / DVD-ROM Combo 24x24x24x/8x IDE Plug-in Module 5.25" Slim Line DW22... Burner Questions & Answers
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html
http://download.cnet.com/usb2-external-win98se-zip/3000-18493_4-168107.html
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
SlimDrivers automatically updates PC drivers with real-time scanning and cloud technology. The first cloud-based utility for updating and maintaining drivers, SlimDrivers provides instant optimization of the interaction between a computer and its system components and periperhals, such as printers, graphic and sound cards, motherboards, USB ports, game controllers and other devices and hardware. SlimDrivers scans a PC, identifies the correct drivers needed, and retrieves them from the cloud, automatically installing the most current, precise drivers for each individual PC. SlimDrivers features a one-click, start scan button on its product homepage, which begins the process automatically to scan a PC and identify out-of-date or broken drivers. Then, seamlessly, SlimDrivers creates a personalized driver profile of that PC, and accesses the online cloud database for the most up-to-date, customized driver software.
hope this helps you
Teac Dw 224E-R... | Answered on Sep 07, 2011
Hello sanhill665, try "Updating the Drivers"
Go to this "Website," and "Fill-in" or {Choose} any information needed to get the "Drivers" you need. Than you'll be able to "Download the Drivers."
!Attention: The 'Part No." is a "letter off. ie: "Yours= [R] Theirs = [V]. "I will say. its 'safe' to try!"
"Please let me know if you 'need' further assistance, or the 'solution' helped?
"By posting a 'Comment" or 'Rating' the solution.
Thank you; your 'response' is important to me!"
paul7of9
Click here: http://www.teac.co.jp/dspd/index.html
Teac Dw 224E-R... | Answered on Mar 02, 2011
Hello.
First try a disk drive cleaner.
If still a problem, the only solution is to replace the drive.
Hope this helps.
Teac Dw 224E-R... | Answered on Oct 15, 2010
hi no its only a CD RW, and not a CD/DVD-RW its just a CD writer and a dvd( rom )..read only memory which means it only reads dvd's but does not write them...hope this helps
Teac Dw 224E-R... | Answered on Jun 14, 2010
Go to
1-my computer
2-then properties
3-then device manager
4-then look for your cd-rom
5-uninstall the driver (only if you have the cd-rom installation program from the manuf.) and restart your PC
If you don,t then find any conflicts in the device manager "like a yellow symbol" and if you find any try to "update driver".
Keep posting!
Teac Dw 224E-R... | Answered on Feb 22, 2010
the fault is from the lens of your CD/DVD drive. The lens is weak and that's why its selecting disc.
How long have you been using this drive? I think its due for replacement.
You can try cleaning it with a lens cleaner. If this does not work, then you will have to manage the drive pending the time you get another one.
Take care.
Teac Dw 224E-R... | Answered on Feb 04, 2010
this might be that your lens is weak and weak lens cannot write ... try reinstall your operating system and see if it works .. if it does not work please change your lens or the drive
Teac Dw 224E-R... | Answered on May 13, 2009
Hi Albert, for what you say, COM ERROR, corresponds to an internal communication problem, try disconnecting the TEAC, from the power outlet, wait a couple of minutes and reconnect it, the problem should be solved
This is indicated on page 26 of the User Manual
If not, you would have a more complicated problem and I suggest you consult a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Albert, por lo que comentas, COM ERROR, corresponde a un problema de comunicacion interior, prueba desconectar el TEAC, del toma corriente, esperar un par de minutos y volver a conectarlo, deberia resolverse el problema
Asi esta indicado en la pagina 26 del Manual de Usuario
Si no es asi, ya tendrias un problema mas complicado y te sugiero consultar a un servicio tecnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
https://www.teac-audio.eu/downloads/2/2/8/1/6/CD-RW890_EFS_.pdf
Teac Computers &... | Answered on Aug 26, 2019
What operating system are you using?
NOTE: A usb floppy drive will not work when plugged into a USB 3.0 socket, you need to plug it into USB 2.0 if you have one.
Teac Computers &... | Answered on Aug 17, 2019
Teac Dw 224E-R Disk Drive CD-RW / DVD-ROM Combo 24x24x24x/8x IDE Plug-in Module 5.25" Slim Line DW22... Burner Logo
Popular Tags
13 questions posted
Top Teac Computers & Internet Experts
Ekse
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
DW Teac
  • DW Teac
Most Popular Question
teac dw 224e r wont burn dvd dvd
  • Computers & Internet
