20 Most Recent Sony CRX320EE-88B CD-RW/DVD-ROM Combo Drive Questions & Answers
Hello there Alex is on your service tonight :)
Well, this is common laser faliure, after working for several years they just go mailfunctioning and you can't fix them. I highly advice you to keep that one for reading what it can read now, and to buy new device since they are really cheap nowdays, you can get them from ebay or amazon.com under 25 bucks.
Thats the situation, I wish you best of luck snake :)
Please rate my solution if you can that would be nice :)
And enjoy your remaining hours of this day :) Alex
Sony... | Answered on May 05, 2011
make sure that the cdrw/dvd rom is getting enough power test all leads that are attached to the cd/dvd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Sony... | Answered on Apr 04, 2011
try to find a tiny hole on the drive( near LED or eject button) and insert a niddle or some kind of hard pin which can go inside of it push little bit hard (drive will open) , dont keep your drive empty if not in use put any useless DVD ROM in it so that it will get open when you want to use
Sony... | Answered on Apr 24, 2010
Check device manager in control panel under hardware to see if you have a problem with anything (a big yellow check). The most likely casue is that your DVD burning software (not the microsoft programs) did not install properly. Find out the exact info about yours by downloading a freeware program called Belarc Advisor (Googe it), Oddly enough, you don't need drivers for the CD/DVD drives. They aren't even recognized unless you have a non-microsoft burning program. After you find out what burning software you have-- you have to seek a download at the computer manufacturer's website, if it came with the computer, as it may be a special program not related to the burning software if you purchased from the software manufacturer---go to their website for downloads or upgrades,and that should get you going.
Sony... | Answered on May 12, 2009
Heres Your Answer:- Supported DVD Formats DVD-ROM • DVD-Video.
Mike @ compurepair.
Your Drive Does not support DVD+R Only -R.
View Here:- http://www.aprmedia.com/product.php?pid=3974
Sony... | Answered on Jan 22, 2009
Try playing with VLC Player . It works great
Sony... | Answered on Sep 15, 2008
Reinstall nero and search google for removing nero scout
Robert
please rate the solution.
Sony... | Answered on Sep 13, 2008
just wondered if you got it from office depot?
also does this thread help you?
http://club.cdfreaks.com/f44/ativa-18x-internal-lh-1h18a-217118/
Sony... | Answered on Apr 09, 2008
get the filtercheck 4.6 and remove all filters .. restart.. done
www.cdr-zone.com/forum/about4719.html&highlight=filtercheck
Sony... | Answered on Mar 23, 2008
This is because the model you mentioned is just a combo drive. It is not a dvd burner. You can watch dvd's with it but not burn them. The way manufacturers word the advertising leads some people to believe that they have a dvd and cd burner. All you have is a cd burner / dvd player. What you want is a dvd-rw / cd-rw drive. Sorry! I hope this helps.
Sony... | Answered on Dec 05, 2007
the capacitors in side on the amp have gone weak. it has noticed the fault and is telling you. check the capacitors look for any sight of problems look for the end being popped up and brow-black gunk on the board around them tackie to the touch and change them. also give the boards a good clean out using a new paint brush sweep the dust out.
Sony CRX... | Answered on Oct 20, 2013
This should help if it is a legitamate copy.
https://www.magix.com/int/support/my-service-center/product-registration/
Sony Computers &... | Answered Yesterday
I have usually found it is better to format the hard drive and reload the operating system.
Sony Computers &... | Answered on Sep 30, 2020
the problem has to be from the display inverter board. The display inverter board is responsible from bringing display on the screen. Now since is no longer display, then it mean it has become defective.Get a philips screw driver, disassemble the unit in order to get to the display screen. You will see a kind of flex or wire connected to the screen. The board where the wire/flex is coming from into the screen is the display inverter board. The board is rectangular in shape.Remove the board, take it to an electronics parts store within your vicinity for exact replacement and the unit should display again.
Sony Computers &... | Answered on Aug 24, 2020
https://www.sony.com/electronics/support/televisions-projectors/kf-60we610/articles/S1Q0084
https://translate.google.com
Le voyant de la lampe clignote
Si l'?cran s'assombrit, que la couleur semble inhabituelle ou que le t?moin LAMP ? l'avant du t?l?viseur clignote, il est temps de remplacer la lampe par une nouvelle (non fournie).
Utilisez uniquement un Sony XL-2100U ou XL-2100 de remplacement pour votre t?l?viseur. L'utilisation de toute autre lampe peut endommager votre t?l?viseur ? projection LCD. Contactez votre revendeur Sony pour une lampe de rechange.
Cliquez ici pour t?l?charger des instructions ?tape par ?tape pour remplacer la lampe de votre t?l?viseur.
Remarque: Avant de remplacer la lampe, mettez l'unit? principale hors tension. Attendez quelques minutes, puis d?branchez le cordon d'alimentation. (Le ventilateur de refroidissement continuera de souffler pendant environ deux minutes apr?s la mise hors tension.)
Assurez-vous de laisser la lampe refroidir compl?tement avant de la retirer. La surface de la lampe reste extr?mement chaude pendant au moins 30 minutes apr?s la mise hors tension.
Sony Computers &... | Answered on May 03, 2020
Did you blow compressed air into laptop?. It is possible that something got disconnected or dirt stucked in powrr button
Sony Computers &... | Answered on Apr 22, 2020
Hi
You can read more such errors and their solution from the given link. This blog will help to analyze the Lotus Notes problems and give you the easy approach to resolve them smartly. This will enhance your knowledge about IBM and the tips to fix them.
Read more:- http://www.nsfsecurityremover.com/blogs/lotus-notes-error-messages/
Thanks
Sony CRX320EE-88B CD-RW/DVD-ROM Combo Drive Logo
12 questions posted
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
CRX Sony
  • CRX Sony
Most Popular Question
cannot ply dvd but
  • Computers & Internet
