20 Most Recent
Craftsman 3/4 Hp Garage Door Opener System Belt Drive Motorhead Only Questions & Answers
How to fix my garage door opener?
I'm assuming you mean that it won't close, only open? If that's the case then your eye beams may need to be adjusted. The wall button can override the sensors whereas the remotes can not.
Garage door opener won't work
Motor has overheated; the motor unit does not operate or trolleyis stuck on stop bolt = Motor unit hums briefly; RPM Sensor =Short travel 6-8" (15-20 cm).• Unplug unit to reset. Try to operate motor unit, check diagnostic code.• If it is still flashing 5 times and motor unit moves 6-8" (15-20 cm), replace RPMsensor.• If motor unit doesn't operate, motor unit is overheated. Wait 30 minutes andretry. If motor unit still will not operate replace logic board.
Garage door problem
If it went all the way down, then "bounced" and went all the way back up, it's not the sensors. You need to check your limits. For some reason the door is going past the limits then the force is telling it that it is pushing too hard so it runs back up when it hits the ground. Clean your eye beams and the bottom of the door (some times leaves will stick and cross the eyebeam as it gets almost closed) just to make sure, but I would try resetting the limits or verify the limit switches are not broke, which can sometimes happen.
Learn
press the learn button on the motor, then you have 30 seconds to set the button you wish on the remote. make sure to do it within 30 seconds
