20 Most Recent Toshiba Satellite R25-S3503 Tablet PC Questions & Answers
2answers
On boot up it displays and asks for a password on Laptop
1. At the BIOS password prompt ("PASSWORD = "), press and release the following keys, one after another:
Ctrl, Tab, Ctrl, Enter
The computer's response should be:
PC Serial No.= XXXXXXXXX
Challenge Code= XXXXX XXXXX XXXXX XXXXX XXXXX
Response Code=
2. Get response code from your local toshiba support center
Then follow the instructions the support guy will give you to unlock the laptop
10/24/2020 12:34:13 PM • Toshiba... • Answered on Oct 24, 2020
2answers
Restoring deleted files
You could try an in place reinstall.. this will "Replace" ya windows & leave (hopefully) ya system intact.. From below the first one, the winnt32.exe method I have used B4 and it works very well. http://www.jsifaq.com/SF/Tips/Tip.aspx?id=8127 http://support.microsoft.com/kb/315341
12/3/2013 7:58:34 AM • Toshiba... • Answered on Dec 03, 2013
My Toshiba R25-S3513 will not
Hi raffael,
If your Toshiba R25-S3513 does not automatically change when you rotate the screen to tablet position, it is caused by a missing or corrupted driver. You need to keep checking the Toshiba web site to see if they've released any drivers for your specific model. You can go here. To refine the search, please select your operating system and Categories. If you can't find the accurate driver, you need to wait until Toshiba releases new upgrades and updates for their drivers.
Hope it helps.
Thank you for using FixYa.
4/13/2011 5:24:29 PM • Toshiba... • Answered on Apr 13, 2011
4answers
This makes (4) four of us only on this site here ...I have R25 S3503 model and got this morning same problem :(
I did strip the tablet appart and remove the battery plus cleared up the motherboard via reset..and still the same problem :(
Will try last atempt with parallel port procedure loopback procedure
I think we have a case for class action lawsuit here angainst the manufacturer...you can reach me @ [email protected]
8/31/2010 4:58:39 AM • Toshiba... • Answered on Aug 31, 2010
N0 SounD 0n my R25 T0Shiba Laptop even thouqh new
toshibe
8/11/2010 1:14:44 PM • Toshiba... • Answered on Aug 11, 2010
I need a Response Code to remove a CMOS Power On
No, unfortunately you need to have it reset and this process requires an advanced skilled tecnician to do this. Try asking your computer manufacturer if they provide these kind of service.
3/7/2010 6:37:05 PM • Toshiba... • Answered on Mar 07, 2010
How do I Install my memory in my Toshiba R25-S3503?
ur laptops memory slot is located under the keyboard, u have to carefully remove the thin cover from the top of ur keyboard to reveal the 2 screws, then un screw them to reveal the RAM cover. unscrew the two screws on that to reveal the RAM. be sure to take out ur battery b4 u do this.
8/4/2009 3:38:53 PM • Toshiba... • Answered on Aug 04, 2009
"D:\ is not accessible" message
If the cd is in the drive then you have a problem with the drive itself. It might work on a cd but won;t on a dvd. That indicates the heads have gone out of alignment.
Usually means you need to replace the drive.
7/9/2009 8:02:01 AM • Toshiba... • Answered on Jul 09, 2009
AC Port shorting out
That definatly sounds like you need to replace the jack for sure....I have fixed two toshiba's with the same problem myself. To get it done in the store you are probably looking at $150-300. Least that is what it was here. So i decided to buy the part i needed off ebay, take the laptops apart and resolder the jack on.
3/8/2009 10:07:45 PM • Toshiba... • Answered on Mar 08, 2009
Adding memory
chek your laptop first if it can accept the 1gig memory. if so then ask the supplier of your 2 pcs 512 memory to replace with 1 pc. 1gig memory. and also ask assistance to replace it.
1/8/2009 4:08:22 AM • Toshiba... • Answered on Jan 08, 2009
Lost data n unable to restore to past date
You could try searching your computer for the songs by going "start--->search" and type in the name of the songs one by one and see if anything comes up.
11/3/2008 8:03:59 PM • Toshiba... • Answered on Nov 03, 2008
My display is not working well
Not displaying well?...change the resolution to highest setting in display properties!
3/2/2008 8:17:33 PM • Toshiba... • Answered on Mar 02, 2008
How can i factory reset my toshiba tablet modle wt10-a
There should be a little hole somewhere on the tablet. Stick a pin in it then it should factory reset it. Or if you can, create a new user then go to settings and factory reset it from there.
10/7/2019 2:49:20 AM • Toshiba Tablets... • Answered on Oct 07, 2019
How do I connect a Samsung tablet to a Toshiba PC?
have tried connecting with usb cable
5/13/2019 7:04:39 PM • Toshiba Tablets... • Answered on May 13, 2019
How do I pair up my tablet to my Toshiba tv
Miracast is the only way with an android device unless your Toshiba TV has file sharing/media sharing apps on it.
1/10/2019 5:57:23 AM • Toshiba Tablets... • Answered on Jan 10, 2019
On my toshiba tablet,I forgot my pass word.how do I reset it?
Not sure about specifics on toshiba tablets, but wanted to suggest that on other tablets you can hold the up volume(sometimes others its volume down) and power button at sane time for about 10+seconds and a menu will pop up for a rebooting, safe mode, and factory restart(which erases and reboots from scratch) worth a shot.. Yet, be careful what you select if it works.. Don't want you to erase stuff if you don't want to.... And btw most tablets have a little pin size hole either under the camera lense or on side that something like a paper clip can push a reset button... But don't think that helps with password.. Just if it freezes up and won't shut down... Good luck.. Sorry if this doesn't help...
12/24/2017 9:07:03 AM • Toshiba Tablets... • Answered on Dec 24, 2017
Toshiba Satellite R25-S3503 Tablet PC Logo
Popular Tags
24 questions posted
Top Toshiba Tablets & eReaders Experts
David Shaub
Steve
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Tablets & eReaders
Most Popular Question
install memory in toshiba r25 s3503
  • Tablets & eReaders
