20 Most Recent
Whirlpool GGX9868J Gas Dryer Questions & Answers
The dryer will not operate.
unplug dryer, remove back panel, look for a white part with 2 connectors on the blower housing and remove one, using a continuity or ohm meter put across the leads and if you hear no sound or see no reading in meter replace that part. is the thermal fuse. this is the most common problem for that failure.
2/12/2011 10:38:43 PM •
Whirlpool...
Answered
on Feb 12, 2011
The dryer will not operate. you can press the
go to the back of dryer,remove the back panel,look at blower housing and you see a white thermostat like part with 2 cables. that's the thermofuse. use a multimeter on continuity(beep sound) and disconnect one wire and put leads at the 2 connector of fuse. if no sound then replace it. this is the most common problem. after replacing part check vent at wall that is clean of obstructions.
2/12/2011 10:10:52 PM •
Whirlpool...
Answered
on Feb 12, 2011
MY 6yr old Whirlpool gas
It appears your thermistor or gas valve solenoid has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
10/1/2010 2:11:46 AM •
Whirlpool...
Answered
on Oct 01, 2010
Dryr starts to crank up than just stops and wont turn on any more
Hi there, this is motor failure. the actual motor windings are in bad condition at this moment. they are separating and this can ultimately start an electrical fire. the automatic shut off prevents the fire form occurring. you will have to remove the motor and tanke it to an electrialc motor shop for a re thread.
2/17/2009 4:21:07 AM •
Whirlpool...
Answered
on Feb 17, 2009
Igniter Works, but Gas won't fire up on Sensor Dry, Will on Timed Dry
PLEASE do not use this dryer until it is fixed. it may be a saftey hazard. From the sounds of it. Your ignitor is only getting a signal every now and then. Now either is a coupler in there to tell the ignitor when to fire and when not to fire. It seems that it is going out only alloweing the dryer's ignition to come on only when a new cycle is started. That is where i would start... check with an appliance repair shop and find out if it will be something you can do your self or if it is something they have to do....
Now I do STRONGLEY recomend that you have a service technicion come on and service your dryer do to the fact that it is a GAS dryer. if something inside the dryer where to get pinched or broken it could cause a bigger problem....
so please take this advisment under consideration....
Thank you.
8/4/2008 3:46:35 AM •
Whirlpool...
Answered
on Aug 04, 2008
Dryer
Derf, E1 means an open thermistor. If this is a front loader, remove the lower panel by removing the 3 screws on the bottom panel. The thermistor will be sitting right behind the blower housing next to a white thermal fuse. The thermistor is the black one. If this is a standard model the lower panel should open by sliding a puddy knife on the two clips and pulling foward. The thermistor is in the same place as a front loader. Your part number should be 3976615. An easy job. Don't forget to kill the power to the unit when repairing...Good luck.
5/19/2008 3:49:41 PM •
Whirlpool...
Answered
on May 19, 2008
Whirlpool WGD4800XQ1 Dryer-- Replaced burner coils and it worked great. The next day no ignition again.
There are about seven different possiblities and the prospective solution in each case appears to be replacement of a different part! I suppose if you have the proper testing equipment for assessing each of those parts, you might be favored with a relatively inexpensive fix. I would be embarassed to suggest you replace all in sequence until the dryer works.
Thermal Fuse: The thermal fuse is a safety mechanism that prevents the dryer from overheating. If it blows, the dryer won't heat. Check if the thermal fuse is intact and replace it if necessary.
Cycling Thermostat: The cycling thermostat regulates the temperature inside the dryer drum. If it's faulty, the dryer may not heat properly. Consider checking and replacing the cycling thermostat.
Igniter: The igniter is responsible for lighting the gas burner. If it's defective, the dryer won't ignite. Inspect the igniter for any signs of damage or malfunction.
Gas Valve Coils: Although you've already replaced them, double-check the gas valve coils. Sometimes, even new parts can fail. Ensure they are securely connected and functioning correctly.
Ventilation: Poor ventilation can lead to longer drying times and affect ignition. Make sure the dryer vent is clean and not obstructed. A clogged vent can cause overheating and affect ignition.
Door Switch: The door switch ensures the dryer doesn't operate when the door is open. If it's faulty, the dryer won't start or heat. Verify that the door switch is functioning properly.
Timer and Controls: Check if the timer advances correctly during the drying cycle. Malfunctioning controls can impact ignition. Inspect the timer and control board for any issues.
Whirlpool Dryer WGD4800XQ1 - OEM Parts & Repair Help - PartSelect.com
On a cabrio whirlpool dryer what does E4 and F4 codes mean
A "F4E4" (Low or No Line Voltage) code indicates there may be a problem with your home power supply, keeping the dryer's heater from turning on. The dryer will continue to run when this diagnostic code is present. Touch any pad to clear the code from the display and return to the estimated time remaining.
