20 Most Recent Fujitsu MHV2040BH 40 GB SATA Hard Drive Questions & Answers
Have Fujitsu MVH 2040 BH
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
4/10/2011 9:48:55 AM • Fujitsu... • Answered on Apr 10, 2011
How to connect toshiba MHV2040BH hard disk
I think you're looking for an external drive enclosure, like this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16817729011
They're quite easy to use and almost all of them are compatible with Mac OS X.
You put the drive in the enclosure (usually only takes a few screws) and then plug the enclosure into your computer with the included USB cable. Easy!
3/1/2011 8:42:00 AM • Fujitsu... • Answered on Mar 01, 2011
I need Fujitsu Siemens Amilo V2000 Laptop troubleshoot pdf?
It is always good to know the situation you are trying to troubleshoot? Broadly speaking, help and manuals in the link. https://www.google.com/search?q=amilo+v2000+troubleshooting ..
3/29/2024 6:48:29 PM • Fujitsu... • Answered on Mar 29, 2024
5answers
I cant find the apostrophe button on the keyboard. there is one but does not work on my fujitsu laptop
https://forum.ts.fujitsu.com/forum/viewtopic.php?f=103&t=23184
3/11/2024 8:50:28 PM • Fujitsu... • Answered on Mar 11, 2024
How can I fix my Fujitsu laptop when its turns on with a blank screen, no display and a blinking Num Lock light?
Question edited for clarity. Re: E744 - NumLock flashing Remove the battery and the ac adapter and press the power button again for a view seconds. After that connect the ac adapter first an try again if you can start your device. If you are facing the same problem again you should contact a service partner regarding a repair of your notebook. May 5, 2015
E744 - NumLock flashing - Fujitsu Support Forum
5/14/2023 5:09:59 PM • Fujitsu... • Answered on May 14, 2023
How can i fix my laptop Fujitsu when i turn it on its turns on whit no display and the num lock light keeps blinking ?
Try this first Disconnect from the mains. Remove the Laptop battery. Wait 30 minutes. Press and hold the On button for 2 full minutes. Replace the battery and boot up. But I fear that the screen inverter has failed. It provides the power to light the screen. https://www.google.com/search?q=fujitsu+laptop+screen+won%27t+turn+on
4/9/2023 4:37:29 PM • Fujitsu... • Answered on Apr 09, 2023
Sir I have problem Bluetooth missing/not showing in Fujitsu Lifebook AH530/2b on device manager of Windows 8.1. Sir plzz help me or give me a solution for this?
You have to FORCE the computer to look for the Bluetooth Device, and you have to FORCE the Bluetooth Device to search for the computer. When they find each other, they shake hands and connect. https://www.fixya.com/support/r26362721-pairing_bluetooth_devices
How to connect bluetooth device on LIFEBOOK AH530 - Fixya
Fixya https://www.fixya.com > support > t12499384-connec... Open the PC Bluetooth manager. Select seek all devices when connected. Make sure to check that option. Turn on your device making sure that it is also set to ...
Where To Find Information About Bluetooth - Fujitsu LifeBook ...
ManualsLib https://www.manualslib.com > ... > User manual Bluetooth device. To access the Help file, click [Start] > All Programs, and click on Bluetooth, then select User's Guide. For additional information about ...
Desktop out. LifeBook in. - Fujitsu
Fujitsu https://www.fujitsu.com > AH530_Factsheet PDF The LifeBook AH530 and A530 feature a 1.3 mega pixel camera, built-in digital microphone, built-in stereo speakers, Bluetooth® v2.1 and.
3/21/2023 1:03:34 AM • Fujitsu... • Answered on Mar 21, 2023
Fujitsu FI-4990C -- First time scanning error
You need a service call or take it to a service centre https://www.google.com/search?q=%22frontside+background+changeover+function+overrun%22 ..
10/25/2022 6:25:58 PM • Fujitsu... • Answered on Oct 25, 2022
Can I make Screenshots with the Fujitsu S-4546?
Yes by pressing "ctrl+prntscrn" buttonOr Func+Ctrl+PrntScrnOr Func+Alt+PrintScr
7/15/2022 9:43:45 PM • Fujitsu... • Answered on Jul 15, 2022
2answers
For the Fujitsu Q555, how do,I get BIOS to recognize new battery
coin cells fail at 5years. on some. 550 here, 555 maybe the same 555-undefined-undefined-0_0.jpg
6/18/2022 3:58:49 PM • Fujitsu... • Answered on Jun 18, 2022
2answers
PC Fujitsu Siemens DESKTOP PC mobo. dead.
Apply new turmal compound to your cpu and try to start again
6/18/2022 3:21:09 PM • Fujitsu... • Answered on Jun 18, 2022
2answers
HOW TO RESET THE BIOS PASSWOrD FOR FUJITSU LH532
THERE ARE 3 LEVELS STATED IN THIS 2012 MANUAL BIOS. SUPERVISOR (ADMIN) USER AND BOOT PW. 1,2,3 Three kinds/ and 2012 PC is w8 ready meaning the old COIN pulled way is now useless, as the manual told you, page 10 if ADMIN is set , bios screens are locked out. on purpose boot pass word blocks windows from booting. not entered correctly. if TPM was set the PC is locked out, hard. by design. TPM set and then cleared using ADMIN login, all data is lost. gone by DESIGN TPM rules and laws there of. we can;'t see what is set in your bios. so.... now level 4, HDD security page12 if set that too is locked out. we can't see any of this in a text box. if you bought it locked out send it back if from a friend as a handme down, ask them for the PW. or guess. or google backdoor passwords FUJITSU LH532 page 10 says (see photo and learn this) https://www.manualslib.com/manual/829337/Fujitsu-Lifebook-Ah532.html?page=10&term=reset&selected=2#manual see the will not word, that means ONLY HACKING works and we are not hackya dot com. google for hacks if you want. all PC laptops 2012 and newer the rules are strict. next time don't set this junk. or write it down next time. fuj-hell-undefined-undefined-0.jpg
6/18/2022 3:13:13 PM • Fujitsu... • Answered on Jun 18, 2022
2answers
How do I fix bootable device not found on my Fujitsu laptop
You will have to go into your bois and mqke sure your boot priorities is set accordingly. You will have to make sure the hdd is picking up and then set it as a first boot
5/20/2022 11:15:04 AM • Fujitsu... • Answered on May 20, 2022
2answers
I m trying to burn a disc off itunes and am geting
ITunes will not allow you to burn purchased songs to CD/DVD, use a different program--but convert them to another format first--everything can be found for free on the internet.
5/10/2022 3:43:45 AM • Fujitsu... • Answered on May 10, 2022
Boots up on the 4th time (?)
Fujitsu , now that is a rare PC, 2007 MADE, 15 YEARS OLD TODAY, not good that. intel Celeron M 550 1 x 2 GHz, Merom ERA. Graphics adapter" HORROR ! SIS Mirage 3+ 672MX SIS is a dead maker of chips now and A huge PROBLEM. OS = VISTA THE LOWEST RATED PC ON EARTH THEY SAY. no matter what OS you try , no OS on earth runs on bad hardware if you run tests correctly you'd see
  1. huge battery no good, remove it run on AC power , even forever.
  2. RTC CMOS coin cell is bad, not one ever lasted 15 years. .
  3. replace that COIN BAT. now and can not be ignored.
  4. next is hdd bad, run smart tests on it,and it will fail as no OS on earth ever runs on any bad HDD. never. ASK HOW.
  5. last is , CCFL back lamps will go dead , and means zero future for this PC but by magic yours work, (a kinda trap that).
  6. The SIS chips have zero support but for VISTA from OEM direct but Fujitsu ended support long long ago. ask Linux folks for help finding relic SIS GPU support, good luck there, now.
  7. It came new in the box NIB with Include Knoppix4 Linux CD !
  8. Siemens dropped out so only Fujitsu remains if at all.
I see one hit https://forum.ts.fujitsu.com/forum/viewtopic.php?p=139199 the folks there burned the ISO wrong. or do no know how to use boot order in BIOS. it must result with CD full of files. or was done wrong.!!! diagnostics. on CD (iso) ask how to burn ISO it's easy . learn too that if PC is super bad, hardware even DIAG fails. most these PC are in the land fill now, (15 years old and dead) RIP
2/13/2022 11:10:59 AM • Fujitsu... • Answered on Feb 13, 2022
2answers
Fujitsu Siemens Esprimo E5905
16 year old PC (2006) pure junk now. .DO NOT UPDATE FIRMWARE BIOS or did you mean this. OR DID "UNABLE TO UPDAT"E BIOS MEAN I CAN NOT SAVE SETTINGS IN BIOS. and bios dates are wrong too. ANSWER , RTC CMOS COIN CELL is DEAD. sure it is , not one lasted 16 years ever so this is legacy PC sold in garage sale for $1?????? https://support.ts.fujitsu.com/indexdown... leave BIOS firmware code alone or brick this PC you will, BIOS code in EEPROM does not leak out like rusty old bucket of water. the battery is bad. support ended https://support.ts.fujitsu.com/IndexProd... seen here as proof. 5905-undefined-undefined-0.jpg
2/12/2022 1:28:27 PM • Fujitsu... • Answered on Feb 12, 2022
Remove hdd from e8310 fujitsu seimens laptop
The Fujitsu folks are really working hard to win your support. Look at their website. https://support.ts.fujitsu.com/IndexProdSupport.asp?lng=en there should be a little tray, probably on the right side. It will be held in with 2 screws. Remove the screws and gently slide out the tray. The HDD should automatically disconnect from the buses so be gentle. from there, 4 screws on the bottom and you are ready to install a new drive.
2/11/2021 12:06:31 AM • Fujitsu... • Answered on Feb 11, 2021
2answers
I have a Fujitsu desktop My model is D581 Serial number :fal132133 Memory 8192mb 1 error code 00410001 2 error code 0x8007045d 3 error code 0x80070057 Hi please help me fix my computer it keeps on crashing i keep on getting the same error codes above please tell my how to fix them .
From the error message you're receiving, your computer's hard drive either has a problem or has gone bad. If your computer is still under warranty, I would recommend contacting the manufacturer. If it isn't under warranty and you don't have much experience with computer repair, I would recommend taking the computer to a local repair shop fro a repair estimate OR depending on the age of the computer, possibly consider purchasing a new computer.
11/15/2020 12:20:24 PM • Fujitsu... • Answered on Nov 15, 2020
My fujitsu LH531 laptop camera is upside down
Try to find on the settings of your camera which have flip the image or mirror in this you can check if it will return to normal.
9/28/2020 2:00:46 AM • Fujitsu... • Answered on Sep 28, 2020
Fujitsu MHV2040BH 40 GB SATA Hard Drive Logo
2 questions posted
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Fujitsu Computers & Internet
Most Popular Question
fujitsu mvh 2040 bh
  • Computers & Internet
