20 Most Recent KitchenAid Superba® (KTRP22KRWH) Top Freezer Refrigerator Questions & Answers
0answers
I have kitchenaid refrigerator , model #
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
11/27/2010 12:02:38 AM • KitchenAid... • Answered on Nov 27, 2010
The freezer unit will not produce ice.
Best approach is to follow a step by step procedure, which I've included. However, if it's turned off and water is still feeding, then the first step is to replace the valve on the bottom rear of the machine.
Then......
Take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
4/11/2010 4:46:36 PM • KitchenAid... • Answered on Apr 11, 2010
Oven does not heat up when we try to bake.
no element ... there is an ignitor, u might need service prob worth repariing, if not turn if gas unplug and remove inside cover on bottom and get acess to ignitor,, u can find one locally or online at sears or repairclinic.com u dont have to get the kithenaid part it is only more expensive it could be a 12400035 or an sgr403 depending if its a round or square ignitor those are less expensive... hope this helps let me know
4/8/2010 5:01:08 AM • KitchenAid... • Answered on Apr 08, 2010
Can I trigger the KitchenAid Superba KTRS25Q ice maker to fill?
THERE IS A WAY TO (JUMP) THE ICE MAKER BUT I DONT RECOMEND IT BECAUSE IF YOU JUMP THE WRONG WIRES YOU CAN DAMAGE IT. TAKE THE COVER OFF THE ICE MAKER AND LOOK IN THERE IT MAY SAY HOW. OR WAIT If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
1/15/2010 10:53:50 PM • KitchenAid... • Answered on Jan 15, 2010
Kitchenaid kmhs120ess-10: The bottom handle bracket is loose. How can I disassemble the door to tighten the bracket screw?
Hi, Please remove any facades on the microwave first. This should expose the screws the keep the door on the microwave. Once you remove the door then you can achieve your goal. You might also call kitchenaid to get schematics for the microwave to help you when removing the facades. Thank you.
10/31/2022 10:46:58 PM • KitchenAid... • Answered on Oct 31, 2022
Lights out in kitchenaid frige after power outage
Not knowing all the details I am just guessing here I have seen this happen more then once, when power goes off and comes back on sometimes there is a power search causing too much electric in one spot and burning out the component such as a light bulb but that is a easy fix, you can buy an appliance 40 watt bulb just about anywhere and replace it
8/12/2022 6:19:13 AM • KitchenAid... • Answered on Aug 12, 2022
2answers
KSRP22FSBL01 not making ice
I would say more than likely the small tube carrying water to the ice maker probably needs to be blown out small air blower or through or through same tube by mouth
4/8/2022 10:12:24 PM • KitchenAid... • Answered on Apr 08, 2022
Model KRFC300ESS. How can I get french door hinge to close?
hinge damaged /bent or worn and the hinge has adjustments on it --if low make a bushing from plastic-washers not cardboard
4/5/2022 10:50:34 PM • KitchenAid... • Answered on Apr 05, 2022
KitchenAid dutch door water dispenser on outside, intermittently working
Sounds something is loose in the filter, have you tried a replacement .
3/12/2022 4:57:12 PM • KitchenAid... • Answered on Mar 12, 2022
I need the KitchenAid KSRG25FKSS05 wiring diagram. Please help.
This is going to be the best you get.... https://www.partselect.com/Models/KSRG25FKSS05/
1/16/2022 5:43:13 PM • KitchenAid... • Answered on Jan 16, 2022
2answers
How do I adjust doors on KSCS25INSS00?
The doors are supposed to be offset by the thickness of a quarter. To adjust, use a 5/16" or adjustable wrench to adjust the bolt at the bottom hinge of either door. The doors should be closed when you do this. To raise the height, turn the bolt to the right. To lower it, turn the bolt to the left. Sears Parts Direct has the manuals for the KSC25INS00 here: https://www.searspartsdirect.com/installation-guide/2nnzp1gmgc-000593/kitchenaid-kscs25inss00-side-by-side-refrigerator-parts . See page 9 of the Installation Guide for the information on the door height adjustment. The current link to this manual is https://c.searspartsdirect.com/pd-content/is/content/Sears/L0406508 . I hope this helps. Cindy Wells
1/13/2022 12:45:36 AM • KitchenAid... • Answered on Jan 13, 2022
My kitchenaid refrigerator is not working
no info generic answer was the circuit board your problem was your mystery fridge diagnosed --thermostat --compressor -defrost timer if has one--wiring -and or connectors tested
12/21/2021 6:42:29 PM • KitchenAid... • Answered on Dec 21, 2021
KitchenAid Superba® (KTRP22KRWH) Top Freezer Refrigerator Logo
6 questions posted
Top KitchenAid Refrigerators Experts
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Refrigerators
Most Popular Question
  • Refrigerators
