20 Most Recent Whirlpool LGR5644J Gas Dryer Questions & Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,/,./
Whirlpool... • Answered on Aug 13, 2011
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Whirlpool... • Answered on Jun 02, 2010
Yes, that is most likely the problem. Once the glow bar igniter glows so hot, the switch opens & drops power to the igniter.(The radiant sensor has continuity while cold & open when a flame is present.) At the same time, by opening it redirects power to the valve coils allowing them to open & gas flow to the burner assembly. The dying glow of the igniter fires the gas. However, if your igniter glows, the radiant sensor is good. In this case, you'd need to replace the gas valve solenoids.
Whirlpool... • Answered on Aug 01, 2007
You need to check the solinoids on the gas vale. They might work to start but after they heat up some they possibly could break down and shut off. There are 2 coils on the valve. When you first start the dryer you should head a distinctive loud click noise. that is the primary coil opening the valve. When that happens you should also see the glow bar lighting. after the bar lights you should hear one more loud click. Thats the heat sensor opening and allowing the other coil to open to allow gas to flow and ignite. If you do not hear the first click when you start the dryer, look in the back for a small white rectangular fuse with 2 small wires on it. (they may be blue in color) That is a thermal fuse. Use a ohm meter to check if it is pen. If it is replace it.If you heard the first click and the glow bar starts to light but nothing else happens, you eed to check the heat sensor. It is connected to the flame baffle at the end of the gas valve. It will have 2 wires on it. One white and one blue I belive. It is attached by 1 screw. ( 1/4") You will need to check that out with a meter also. If it checks good reinstall it. You will then want to ohm out both coils. Only one may be bad but I recomend you replace the both of them. You will also want to make sure that your vent is not clogged up. That too can cause the dryer to short cycle. Hope this will help you.
Whirlpool... • Answered on Jul 22, 2007
CHECK THE THERMAL CUPLAR ALSO CHECK TO SEE IF THE VENT IS CLOGGED IN BACK OF THE DRYER OR GOING TO THE OUTSIDE
Whirlpool... • Answered on Jul 20, 2007
Dryer are pretty simple. The thing they need most is air flow. Remove the hose from the back, open the windows, and try a load of washing. If it works, airflow is the issue, blocked hose, turns to tight, vent not opening properly. Those are the three main reasons. If you google 'make model parts schematic', you may find that there are three or 4 heat regulating devices, cycling thermostat, high limit thermostat and thermal fuse being three common ones. https://www.partselect.ca/Whirlpool-Dryer-Thermostats.htm ..
Whirlpool Dryers • Answered on Apr 30, 2021
So you have posted a washing machine model number and said you cleaned the dryer venting? That error is for the water level sensor.
Whirlpool Dryers • Answered on Mar 22, 2021
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Can only be a few things high temp fuse high limit thermostat failed element. VIDEO https://www.youtube.com/watch?v=fv2UqRUKnm0 Parts
Official Whirlpool Dryer Parts ' Order Today, Ships ... - PartSelect
www.partselect.com > Whirlpool-Dryer-Parts
The Dryer Thermal Fuse (Thermal Cutoff, Temperature Fuse) is a 2 by ½ inch, white, plastic safety mechanism that stops the flow of electricity to the motor circuit ...
Whirlpool - Dryer Parts - Appliance Parts - The Home Depot
www.homedepot.com > ... > Dryer Parts
Results 1 - 24 of 29 - Get free shipping on qualified Whirlpool Dryer Parts or Buy Online Pick Up in Store today ... WhirlpoolTop Load Washer/Dryer Cover in Gray.
Replacement Parts ' Whirlpool
www.whirlpool.ca > en_ca > services > replacement-parts
Our factory certified parts provide you with a promise only Whirlpool brand can make, that through our safe and genuine quality replacement parts, we will care ...
Whirlpool Dryers • Answered on Mar 13, 2021
if voltage from switch to motor bad motor if no voltage possible bad switch or control board
Whirlpool Dryers • Answered on Jan 24, 2021
Remove the attaching screws at the bottom and swing the cap up.
Whirlpool Dryers • Answered on Jan 10, 2021
The sound comes from a tiny element on the control board. Its volume is fixed and can't be adjusted.
Whirlpool LGR5644J Gas Dryer Logo
Popular Tags
12 questions posted
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
jdthefixer
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
whirlpool gas dryer
  • Dryers
