20 Most Recent GE Profile PDS22MBSWW Questions & Answers
Either your defrost is set wrong or it's not working,
try this , totally defrost the fridge ,once this is done turn it on , a small fan should be running in the freezer section , if it's not then this is the primary cause, if it is then your defrost is not working in which case you will need a new one. There is only one more thing to check and that is the thermostat .
once the fridge has reached temp or close to it, try turning the thermostat to a lower number then back again , if it turns the comp on and of or at least makes a click sound then it's ok, if it does nothing then this could be the issue.
GE Profile... | Answered on Jan 15, 2014
sounds like a main control...check the fans ... unplug each on at a time to check if the relay will stop clicking...
GE Profile... | Answered on Sep 21, 2009
I had the same problem. The cause is the digital display is not communicating with the motherboard. What had happened in my case is the plug connection between the door's digital display and the motherboard had become unplugged. The wire running from the motherboard runs below the fridge, and connects via plug located along the bottom of the fridge below the freezer door, connecting to the wire running from the display to the bottom of the freezer door. I just reconnected it and that reset the display. Glad for it too, I thought I needed a new $130 motherboard! Hope this helped!
GE Refrigerators | Answered on Nov 29, 2020
BEHIND A GRILL IN THE FREEZER SECTION
GE Refrigerators | Answered on Nov 22, 2020
Hello. The water inlet float is broken/inoperative in the freezer compartment of your refrigerator. This causes a overfill/flooding condition.
GE Refrigerators | Answered on Nov 21, 2020
If you are talking F then that is too low at -10, F? is what is required.
If C then the FF (whatever that means) at 40C is too hot and -20 is about right for a freezer.
GE Refrigerators | Answered on Oct 31, 2020
I need someone to feel the top of the compressor. Is it cool, hot or too hot to keep your hand there? Usually on GE models like yours the=> WR55X11072 Main Control Board is the problem along with the start relay, overload and run capacitor. GE Refrigerator Model GSH25JSDD SS Parts
I'm here should you have question, Thanks, Sea Breeze
GE Refrigerators | Answered on Oct 06, 2020
The freezer controls the fresh side temp by letting the cold air through the divider. Make sure that the passage is not blocked or iced over. Also check the cooling coils to make sure they are clean.
GE Refrigerators | Answered on Sep 28, 2020
Hold Energy Button & Light Button for 10 seconds!! No repairs needed. Solution is not in manual.
GE Refrigerators | Answered on Sep 20, 2020
I don't know - I would describe the noise as being like the wind blowing across a chimney. I have never owned a fridge that didn't make such a noise as it grew older - while it was on a cooling cycle and afterwards it sounds like water trickling. It doesn't seem to affect the performance though and I manage to ignore it.
GE Refrigerators | Answered on Aug 14, 2020
the magnet seal arount the door needs to be replace, ypu can purchsase this and simply remove the old and and glue on the new one.
another quick fix method is to use a hax and staple type lock and screw the stape on the frodge and the hax on the door sor sfter you puch in the door simply staple it shut.
GE Refrigerators | Answered on Jun 19, 2020
GE Profile PDS22MBSWW Logo
4 questions posted
Top Refrigerators Experts
gbob59
Marvin
Marvin
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
temperature
  • Refrigerators
