20 Most Recent GE Profile PFS22MBS Bottom Freezer French Door Refrigerator Questions & Answers
0answers
2answers
I am having a problem with my GE side by side. It isnt working and when i plug it back in the back is making a clicking sound. Any ideas?
More then likely a bad mainboard it's common problem in this unit. It will need to be replaced by a technician.
11/17/2011 1:27:06 PM • GE Profile... • Answered on Nov 17, 2011
0answers
0answers
Will not cool properly
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
1/17/2011 2:14:31 AM • GE Profile... • Answered on Jan 17, 2011
All the food in my refrigerator is freezeed. The
The defrost control board is bad and needs replaced
12/23/2010 1:38:05 AM • GE Profile... • Answered on Dec 23, 2010
Our GE Profile Ice maker is not making ice,and
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
8/28/2010 4:35:47 AM • GE Profile... • Answered on Aug 28, 2010
My GE bottom freezer, about 4 years old,
yes it is
6/12/2010 7:14:15 PM • GE Profile... • Answered on Jun 12, 2010
How to change the door gasket o a GE Profile
MAKE SURE THAT YOU DO NOT USE TOO MUCH PRESSURE ON THE DOOR LINER, AS IT IS FRAGILE, AND HARD TO GET AND DIFFICULT TO INSTALL. JUST WORK YOUR WAY AROUND WITH GASKET SLOWLY, AND ONCE IT IS SECURED THEN CAREFULLY USE A HAIR DRYER TO REMOVE ALL CREASES AND ROUGH CONTACT EDGES ON GASKET AND LIGHTLY SECURE THE GASKET AS THE LINER IS PLASTIC/PVC. IF UNSURE GET A PROFESSIONAL TO INSTALL.
2/26/2010 8:05:39 PM • GE Profile... • Answered on Feb 26, 2010
We have a GE Profile
you are either low on refrigerant diverter doors are not sending enough cold air to the freezer. I think low on refrigerant.
2/7/2010 4:25:24 AM • GE Profile... • Answered on Feb 07, 2010
The freezer and fridge temperature has been
i've never heard of this, um, try unplugging it for a couple of minutes then plug it back in. not sure if it will do anything but it wont hurt to try it.
11/15/2009 2:04:21 AM • GE Profile... • Answered on Nov 15, 2009
Refrigerator is getting no power
Check the relay and the compressor with a volt meter. Make sure that you are getting proper voltage. 110 - 120 volts at both the relay and the compressor. If nothing happens or everytime you try to test and the circuit keeps popping first check for bad wiring make sure nothing has come loose. If all the wiring checks out including the ground then the only thing that will pop a circuitbreaker is a bad compressor meaning it is drawing to many amp and you will either need to have a company replace the compressor for around 600 dollars or get a new unit
2/21/2009 3:06:11 PM • GE Profile... • Answered on Feb 21, 2009
For a GE refrigerator model GFSF6KEX, how do you remove the ice tray? (Not the freezer drawer, just the tray.)
To remove the ice tray from your GE refrigerator model GFSF6KEX, follow these steps: Empty the Ice: Before removing the ice tray, empty it of any ice cubes. This will make it easier to handle. Locate the Ice Tray: The ice tray is typically located in the freezer compartment, usually near the ice dispenser or ice maker. Grasp the Bottom Edge: Stand in front of the freezer and open the door. Grasp the bottom edge of the ice tray on the sides. Be cautious not to place your fingers near the opening at the bottom front part of the bucket where the crusher blades are located. Lift Up the Front: Lift up on the front of the ice tray so that it clears the stops on the ice bucket rail. Pull the Tray Forward: Pull the ice tray forward and out of the freezer compartment. Reinstalling the Tray: To reinstall the ice tray, follow these steps: Line up the flange pieces on the sides of the tray with the channels in the ice bucket rails. As you push the ice tray all the way back, lift the front of the tray so that it clears the stops on the front of the ice bucket rails. Verify that the tray is properly inserted by pulling it forward. It should hit the stops on the rail and not come out. If it does, push the tray further back. Check for Misalignment: If you're unable to push the ice tray all the way back, it might be due to a misalignment between the back of the auger (located in the tray) and the prongs on the auger motor (mounted in the back freezer wall). To fix this: Remove the ice tray. Close the freezer door. Press the dispenser for cubed or crushed ice; you should hear a snap. Open the door again and reinstall the ice tray. Remember to handle the ice tray carefully, especially if it's full of ice.
3/31/2024 9:43:28 PM • GE Refrigerators • Answered on Mar 31, 2024
GE Profile PFS22MBS Bottom Freezer French Door Refrigerator Logo
25 questions posted
Top Refrigerators Experts
vince
Johnny 1000
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
refrigerator getting no power
  • Refrigerators
