Hi Yadira,
Yes it has a bluetooth capability Tony. Based on the article about 2004 Nissan Maxima: The extensive list of high-tech options offered includes a navigation system and Bluetooth integration. The iPod interface is probably the most praised feature by consumers.
I have this video for you on how to bluetooth pairing. Also I have a site about 2004 Nissan Maxima.
2004 Maxima Nissan
This could be due to several reasons such as a faulty battery, a problem with the charger itself, or an issue with the connection between the charger and the battery. Here are some general steps you can take to troubleshoot this issue:
Check the Battery: Ensure that the battery you're trying to charge is not faulty. If possible, try charging a different battery with the same charger to see if the problem persists.
Check the Charger: Make sure the charger is functioning properly. If you have another charger, try using it to charge the battery.
Check the Connection: Ensure that the connections between the charger and the battery are secure and clean. Any dirt or corrosion could interfere with the charging process.
Reset the Charger: Unplug the charger, wait a few moments, and then plug it back in. This can sometimes resolve minor technical issues.
https://www.manua.ls/stanley/bc15bs/manual
If unresolved, you might contact Stanley customer support.
Are you sure you aren't the daughter trying to get around the code? The onus is on your daughter to remember her access code. Your parental code allows you to make restrictions to the phone.The only way to fix it is by doing a Factory Reset. Scrub it clean and start again.https://www.google.com/search?q=hisense+f22+hard+reset..
Unlocking your Telstra Oppo A38 can be done using the International Mobile Equipment Identity (IMEI) number. Here are the steps you can follow:
Check if Your Phone Is Locked:
Insert a SIM card from a different provider into your phone.
Allow a few minutes, then turn your phone off and back on.
If the different provider's name appears in the status bar, your phone is unlocked. If it's locked, you'll receive an error message asking you to insert a valid SIM card, and you won't be able to make calls, send texts, or browse the internet.
How do I unlock my phone from the Telstra network using IMEI? - Telstra
https://whatphone.com.au/telstra/how-to-unlock-telstra-phone-for-free/ They must have been kidding.
How do I reset my cash power meter?
Reset your meter by pressing I, BLUE or # button, this is needed to ensure the 2 parts of your meter initiate connection again. This action should reset your meter. Please note, this error is not a technical error and you should never insist a technician comes out for this.
More information please. What is this number from? Is it a serial number? A model number? What company made it? That number comes up as too many things when googled to know what you need help with.
'Make model (what it is)' in all question please first 3 words.
You posted to the category 'Cell Phones' so let's assume it is a phone.
When you are actually in a call use the buttons on the side of the phone to increase the volume. It is usually the upper button, and can only be done when you are on a call.
There doesn't seem to be anything online to suggest how to do a reset or recalibrate the screen.
You could try three things
Look for a tiny Reset hole in the back.
Connect it to a computer and in Windows Explorer see if the is any useful right click commands?
Or leave it running until it runs out of power, wait 24 hours before recharging.
There is usually a feature with bluetooth devices where you can force them to reconnect to your computer. Go into the computer settings and 'forget' this device. Then force the keyboard to re-pair with the computer. This should do the trick!
This can't be done. If the phone is powered off or the battery dies, the GPS isn't working and it can't be tracked. If you go into 'Find my Phone' you can see the last position it was located, but you won't be able to get a current position if the power is off or dead.
I would check 2 things. First, make sure the phone doesn't have a 'sound off' button on it. Many phones have a button on the outside that turns off any rings, beeps, etc. Make sure if that exists that its not turned on. If you either don't find one or its not engaged, then I would call Straight talk and have them ensure that the cell service is properly 'provisioned' for your Mom's phone. Sometimes the cell companies screw up and the phone won't ring. Either of those will hopefully do the trick!
