20 Most Recent Kenmore Elite Black 1.5 Cu. Ft. Convection Microwave Oven 67909 Questions & Answers
How can I keep the turntable from revolving when using a dish that is too large to turn?
Try removing the M/W turntable and placing a shallow bowl upside down centered over the rotating device. Then place your plate on top of the bottom of the bowl. The device will still rotate but will not be in contact with anything.
12/2/2015 8:19:19 PM • Kenmore Elite... • Answered on Dec 02, 2015
How to set clock
Press Clear (or Cancel). Press the CLOCK key (or the key that shows a picture or icon of a clock). Type in the time and press Enter/Start. If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
1/25/2015 6:49:47 AM • Kenmore Elite... • Answered on Jan 25, 2015
Kenmore microwave model 721.85033010 works fine except the exhaust fan comes on just out the blue for no reason and wont shut off without unplugging.
It turns itself on
  1. Interlock switch If your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control board If your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
But before throwing parts at it give these folks a call... https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Microwave/74-6-878350-/New/Kenmore-Microwave-Turns-On-By-Itself-721-85033010 Best to you
9/2/2023 9:10:40 PM • Kenmore... • Answered on Sep 02, 2023
Looking for manual for a Kenmore Viking 851.8250800 Microwave.
It looks like it is too old. Nothing in Kenmore or Viking. https://www.google.com/search?q=Kenmore+Viking+851.8250800+manual ..
8/7/2023 7:31:34 PM • Kenmore... • Answered on Aug 07, 2023
Kenmore over the range microwave tripping breaker
You've found the proper location if you're seeking for the fuse for your Kenmore microwave. The fuse is often found in the microwave's or behind the control panel. You must take off the microwave's exterior cover in order to reach it. After you've identified the fuse, you may see if it has blown. If so, you'll have to swap it out for a new one. It might be preferable to seek professional advice if you are unsure on how to proceed.
4/18/2023 8:31:03 PM • Kenmore... • Answered on Apr 18, 2023
2answers
When trying to use convection with Kenmore hood combination it stars then stops and the display says F-5. What does that mean
If you are getting an F-5 error code on your Kenmore hood combination, it typically indicates a problem with the temperature sensor. This error code may occur when you are trying to use the convection feature, as you have described.
To troubleshoot this issue, try the following steps:
Turn off the power to the unit and unplug it from the electrical outlet.
Wait a few minutes, then plug the unit back in and turn on the power.
Try using the convection feature again and see if the error code reappears.
If the error code persists, you may need to replace the temperature sensor. You can consult the user manual for your Kenmore hood combination or contact Kenmore customer service for assistance with this.
If the unit is still under warranty, it's recommended to contact Kenmore customer service for repair or replacement options.
4/5/2023 7:13:24 AM • Kenmore... • Answered on Apr 05, 2023
Need a replacement display board for a Kenmore Microwave Model No. 318279601B
These are all the top suppliers, but that model number is not showing. If the display has gone dim, you can get an electronics technician to replace the capacitor that runs the display. https://www.google.com/search?q=Kenmore+Microwave+318279601B+parts ..
3/11/2023 7:20:22 PM • Kenmore... • Answered on Mar 11, 2023
My Kenmore stove timer started going off every 45 seconds
It sounds like you may be experiencing an issue with your Kenmore stove's timer function. Here are a few steps you can try to resolve this issue:
Check the timer settings to make sure that the correct time and alarm settings have been entered.
Try resetting the timer by turning it off and back on again, or unplugging the stove and waiting a few minutes before plugging it back in.
Make sure that there are no buttons or knobs stuck on the stove, as this could cause the timer to activate repeatedly.
If these steps do not resolve the issue, it may be necessary to contact a professional appliance repair service for further assistance.
2/1/2023 2:26:53 AM • Kenmore... • Answered on Feb 01, 2023
I have a Kenmore over the range microwave oven and it is not powering on after a power outage. What could be causing this please?
Question edited for spelling of Kenmore and typos. Question moved from Kenmore Washing Machines. All about repairing microwave ovens https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
1/22/2023 1:47:03 AM • Kenmore... • Answered on Jan 22, 2023
I need user manual for Godrej 20E 08 SLGX microwave oven
I have a godraj 20E 08 SLGX MICROVIEW OVEN .Can you plz tell me can I bake in this if yes then how i preheat it for baking
1/12/2023 3:13:10 PM • Kenmore... • Answered on Jan 12, 2023
From top to bottom, what should be the types of door interlock switches on a Kenmore microwave 790.803.
Maybe get the part here? https://www.partselect.com/Models/790803/
12/30/2022 6:16:41 PM • Kenmore... • Answered on Dec 30, 2022
Where can I find the specs for a Kenmore oven model # 326B1016P001.
That is the strangest model number for a Kenmore and doesn't follow the normal 3 dot 7 ***.******* format of others. Just measure the front of what you have. They come in standard sizes. https://www.google.com/search?q=kenmore+%22326b1016p001%22+installation+manual ..
12/10/2022 8:00:48 PM • Kenmore... • Answered on Dec 10, 2022
Kenmore microwave model 401.85053010 won't heat or cook anything.
Unfortunately, this is not something that can be diagnosed from a distance, unless you had access to a "Kill-a-Watt" meter or equivalent. It could be caused by a bad door switch, a bad relay on the main board, a bad magnetron, or a bad HV diode. (The HV capacitor is probably OK, because if it were bad [shorted], it would blow fuses.)
10/28/2022 6:00:32 AM • Kenmore... • Answered on Oct 28, 2022
Kenmore Elite Microwave 721.79209010 Open Door and Microwave starts running;
Yes, a bad door interlock switch would cause this; either the top switch or the bottom switch. (The middle switch is called the Monitor switch. If it were bad, you microwave would blow fuses as soon as you press Start.)
10/28/2022 5:57:10 AM • Kenmore... • Answered on Oct 28, 2022
What does an F=1 code mean?
Convector element has failed. Time for a repair.
7/25/2022 5:30:59 PM • Kenmore... • Answered on Jul 25, 2022
Kenmore Microwave light doesn't work with new bulb
The sockets don't go 'bad'. They get damaged replacing the bulb or the bulb could be faulty.
6/26/2022 12:34:58 PM • Kenmore... • Answered on Jun 26, 2022
Kenmore Microwave model Fan running and light on when door closed.
This is normal. Kenmore microwaves will stay running with fan and light on for a short time after food is cooked. The reason is to air out the microwave after cooking. Things like pop corn, Bacon etc. have strong smells after cooking. The ventilation helps to remove odors.
6/3/2022 1:44:23 PM • Kenmore... • Answered on Jun 03, 2022
My sears kenmore counter top microwave model 99896 now takes 5 or 6 times for the start button to work.
It is from 1981, it is time for a new one. You are unlikely to get parts for one that old. It may be the button, but is more likely to be the contactor that the button activates. Take to a service centre and ask for a quote. Too dangerous to fix yourself. https://www.google.com/search?q=sears+kenmore+%2299896%22 ..
3/24/2022 8:18:55 PM • Kenmore... • Answered on Mar 24, 2022
Kenmore Elite Black 1.5 Cu. Ft. Convection Microwave Oven 67909 Logo
5 questions posted
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Microwave Ovens
Most Popular Question
keep turntable from revolving when using
  • Microwave Ovens
