20 Most Recent Simplicity 38in Regent 21hp Briggs Questions & Answers
How can I reinstall mower deck?
reverse order of how you took it off
1/2/2019 5:48:20 PM • Simplicity 38in... • Answered on Jan 02, 2019
Hi. I have a
swap the stators
1/2/2019 5:47:47 PM • Simplicity 38in... • Answered on Jan 02, 2019
PTO won't engage after replacing mower blades
you've routed the belt incorrectly.
9/13/2017 2:23:24 PM • Simplicity 38in... • Answered on Sep 13, 2017
Cant disengage tranny manualy
Hydrostatic Drive Problems?? - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
May 30, 2006 - I can't seem to get it disengaged to mave it manually. ..... I have aSimplicity 4212 Hydro drive that will not move under its own ... avisk8 - would think so - if the manual sez it's purpose is to let you disengage the tranny so that ...
10/14/2015 1:09:03 AM • Simplicity 38in... • Answered on Oct 14, 2015
My riding mower will start up and I can run it for about 3 minutes. Then it sputters and stops. It won't start again for 10 minutes or so.
Most likely, your fuel is stale or otherwise contaminated. Also, check the OIL LEVEL to be sure the crank isn't binding due to lack of oil or overheating.
5/14/2015 10:57:21 PM • Simplicity 38in... • Answered on May 14, 2015
How do I tighten my drive belt on my simplicity lawn tractor because it keeps slipping off when I make left turns?
Check air pressure in your tires, and if you look around your deck pulleys you may find 1/4" adjustment bars that you can loosen and move in towards your pulleys. These bars, if you have them there, keep the belt from falling off. But my first suggestion should help you. GOOD LUCK FRIEND.
9/22/2014 12:23:14 AM • Simplicity 38in... • Answered on Sep 22, 2014
Need wiring diagram schematic for simplicity mower
simplicity website support-manuals-model
12/29/2013 1:07:57 PM • Simplicity 38in... • Answered on Dec 29, 2013
Need wiring schematic for simplicity 38"
go to simplicity web site -support- manuals - model i got mine there no problem
12/29/2013 12:58:25 PM • Simplicity 38in... • Answered on Dec 29, 2013
What year is simplicity model 1693920 serial no 06613
Need the code no, One after serial No. First no. is the year.
12/29/2013 12:53:39 PM • Simplicity 38in... • Answered on Dec 29, 2013
What year is model 1693920 seriaj\l no 06613
The third groud no, If 06613 is the no. 2000, june
12/28/2013 5:24:25 PM • Simplicity 38in... • Answered on Dec 28, 2013
Year of manufacture for regent 1693920
2001, JULY
12/28/2013 5:19:45 PM • Simplicity 38in... • Answered on Dec 28, 2013
Pto clutch intermittantly engages
set the air gap to .010
1/2/2019 5:52:02 PM • Simplicity... • Answered on Jan 02, 2019
Whats the deck belt size on a simplicity 38 inch mower?
call a simplicity dealer with the model number
1/2/2019 5:48:58 PM • Simplicity... • Answered on Jan 02, 2019
How do i fix sloppy simplicity hydro steering?
replace the worn out parts.
10/1/2018 2:30:40 PM • Simplicity... • Answered on Oct 01, 2018
HELP
seat switch may be bad.
10/1/2018 2:29:38 PM • Simplicity... • Answered on Oct 01, 2018
Simplicity 38in Regent 21hp Briggs Logo
Popular Tags
15 questions posted
Top Simplicity Garden Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
goneforever.
Are you a Simplicity Garden Expert? Answer questions, earn points and help others
View Most Popular
Simplicity Garden
  • Simplicity Garden
Most Popular Question
tighten drive belt simplicity lawn
  • Garden
