20 Most Recent
LG Dle2301r Front Load Dryer dle2301r Questions & Answers
Why does high limit switch keep blowing?
Check for lint build up inside the machine, especially around the air exit duct as any restrictions can cause the machine to build up heat higher than normal. The high limit safety is a fire preventative device.
My LG dryer keeps blowing the high limit fuse. All ducts are clean and clear. Changed the cycling thermostat and high limit fuse and it blew after a day.
This is likely the result of an air flow problem if you are sure the heater is working properly. Ensure you are not running the dryer in a small closed room which would starve the dryer of air dramatically reducing the air over the clothes even if the full length of your vent is brand new. Next, remove the vent hose from the rear of the dryer and check for strong air flow at the outlet. If it seems strong enough then run a vent through a window or out into another room and do one load in this fashion. If this resolves your problem the blockage exists in the vent line outside your dryer and disassembling dryer becomes unnecessary.
If not, ensure you have seen and touched every inch of interior dryer piping and hold the lint filter up to the light to be sure you can see through it. Disassemble and clean ANY section of piping you can't get your hand into. The area below the lint filter tends to catch a lot of lint and can only be accessed by removing the housing at the rear on the left side as you face the rear. Ensure the blower wheel turns when the motor turns. (Newer models may have the filter housing at the front)
Remember.....the dyer heater is energized even if no air flows over the clothes. The heat will usually enter the drum overheating the clothing AND the underside of the top until a safety thermostat turns the heater off. This is a fire hazard that MAY ignite lint or clothing.
Having performed all these actions will likely resolve the problem.
LG Dryer won't start beeps twice, it's brand new.
Two beeps is typical door not closed. Make sure the light goes out when you close the door.
Otherwise make sure both Clean Filter and Flow Sense lamps are off.
You can run the installation test. See following URL.
https://www.lg.com/us/support/help-library/how-to-run-and-installationheat-test-on-an-lg-dryer-CT10000011-20152714315153
6/23/2023 2:41:11 PM •
LG Dryers
Answered
on Jun 23, 2023
The dryer light is blinking on my new lg dryer
refer to owners manual. Since you did not indicate what light is blinking here is a link to LG error codes
copy and paste
https://www.lg.com/us/support/help-library/lg-error-codes-laundry-dryer-CT10000011-20152310891742
5/6/2023 8:29:32 PM •
LG Dryers
Answered
on May 06, 2023
