20 Most Recent
Frigidaire 7 Cu. Ft. Stackable Electric Dryer Classic White FASE7074 Questions & Answers
Stackable frigidaire dryer
The motor winding won't have a large resistance but should have some. Be sure and unhook wires and set your meter to the lowest setting and 0 it. Be sure you are checking the correct connections.
Frigidaire fex831fs2 stackable dryer takes too long to dry and leaves clothes damp
Good Afternoon Famties4,
I understand that the dryer portion of your laundry center, model#FEX831FS2, takes too long to dry, even after making sure the vents are clear. First, I suggest checking the exhaust duct, making sure it is at least 4 inches in diameter and made of rigid or flexible metal. Secondly, make sure the duct has no more than two 90 degree bends and must not exceed length listed in the INSTALLATION INSTRUCTIONS. Lastly, make sure your dryer is connected to a 240 volt circuit. Drying time will be 20% longer than drying on a 240 volt circuit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
-Best Regards-
WP
How do I put my Frigidaire Dryer FEQ1442ES0 into diagnostic mode?
To put your Frigidaire Dryer FEQ1442ES0 into diagnostic mode, follow these steps:
- Hold down the Select and Cancel buttons at the same time for six seconds. After one buzzer sound, the two keys will be released.
- Press and hold the Select and Cancel keys for six seconds right away. The display will indicate "r 2" when the buzzer sounds once.
Once you've put your dryer in diagnostic mode, you may run the diagnostic test to find any problems. You can consult your dryer's operating instructions booklet if you require any more help.
I hope this is useful.
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post!
If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website.
Best regards.
Dryer Squeak, Tight Drum, Burning Smell
The loud, constant squeak/squeal from your Frigidaire dryer, combined with a burning smell, indicates a serious problem that needs to be addressed. While replacing the drum bearing kit was a good step, it appears that there may be other issues at play.
One possible cause of the squeaking could be a worn or damaged drive belt or idler pulley. If the idler pulley spring came off, it is possible that the belt is not properly tensioned and may be slipping or rubbing against the drum, causing the squeaking noise. Additionally, a slipping belt can generate a burning smell as it heats up from the friction.
Another possible cause of the burning smell could be a malfunctioning heating element, which may be overheating the dryer and causing the burning odor.
It is recommended that you stop using the dryer immediately and unplug it from the power source. It is not safe to continue using a dryer that is producing a burning smell.
I have a Frigidaire Dryer and the outside of dryer It was hot to the touch and hadn't been used in couple days ?
f the outside of your Frigidaire dryer is hot to the touch and the heating element appears to be glowing red hot when the knob is not in the off position, it is likely that there is a problem with the dryer's heating element. It could be shorted, burnt, or damaged in some other way.
It is also possible that there is a problem with the dryer's thermostat, which regulates the temperature inside the dryer. If the thermostat is not functioning properly, it could cause the heating element to stay on for too long and overheat the dryer.
It is recommended that you stop using the dryer immediately and unplug it from the power source. It is not safe to continue using a dryer that is overheating or has a malfunctioning heating element. It is best to have a qualified technician inspec
