20 Most Recent
LG DLE7177WM 7.3 Cu. Ft. Electric Dryer - White Questions & Answers
LG Dryer won't start beeps twice, it's brand new.
Two beeps is typical door not closed. Make sure the light goes out when you close the door.
Otherwise make sure both Clean Filter and Flow Sense lamps are off.
You can run the installation test. See following URL.
https://www.lg.com/us/support/help-library/how-to-run-and-installationheat-test-on-an-lg-dryer-CT10000011-20152714315153
6/23/2023 2:41:11 PM •
LG Dryers
Answered
on Jun 23, 2023
The dryer light is blinking on my new lg dryer
refer to owners manual. Since you did not indicate what light is blinking here is a link to LG error codes
copy and paste
https://www.lg.com/us/support/help-library/lg-error-codes-laundry-dryer-CT10000011-20152310891742
5/6/2023 8:29:32 PM •
LG Dryers
Answered
on May 06, 2023
LG DLE7100W DRYER detached something?
It's difficult to determine exactly what may have fallen behind the panel of your LG DLE7100W dryer without a visual inspection. However, it's possible that you may have accidentally detached a small part or screw that was holding something in place.
The rolling sound that you're hearing when the dryer is turned on could be a loose part or screw that has fallen behind the panel and is now moving around inside the dryer. This could potentially cause damage to other components if left unaddressed.
I would recommend stopping any further attempts to disassemble the dryer and instead, contact a professional technician to inspect and repair the dryer. They can determine what may have fallen behind the panel and take the necessary steps to fix it safely and properly.
3/18/2023 5:43:26 PM •
LG Dryers
Answered
on Mar 18, 2023
What does this symbol mean on my LG TD-C70080E condenser dryer?
Unfortunately, without a picture of the symbol you are describing, it is difficult to give a precise answer. However, based on your description of the symbol and the accompanying burning plastic smell, it is possible that the symbol is indicating an issue with the dryer's motor or belt. The symbol you are describing with the oval and arrows could indicate a rotating part, such as a drum or belt, and the smell of burning plastic suggests that something in the motor or belt may have overheated and melted.
It is important to immediately stop using the dryer and unplug it from the electrical outlet until you can determine the cause of the issue and make any necessary repairs. It may be best to contact a professional technician or LG customer service for further assistance and to avoid causing any further damage to the dryer.
2/28/2023 5:24:02 AM •
LG Dryers
Answered
on Feb 28, 2023
How do I change the bulb on my 2006 model LG f harbor breeze ceiling fan 69 inch air span
To change the bulb on a 2006 model LG f harbor breeze ceiling fan, 69 inch air span, follow these steps:
- Turn off the power to the fan by flipping the switch or circuit breaker.
- Locate the bulb cover on the fan, which is typically located near the base of the fan or on the underside of the fan's motor housing.
- Remove the bulb cover by pressing the tabs or pulling the cover down.
- Carefully remove the old bulb from the socket and dispose of it properly.
- Insert the new bulb into the socket and make sure it is securely in place.
- Replace the bulb cover and turn the power back on to the fan.
Note: Make sure to use the correct type and wattage of bulb for your specific fan model. Check the user manual for the recommended bulb.
1/19/2023 5:09:16 PM •
LG Dryers
Answered
on Jan 19, 2023
