20 Most Recent GE Profile PT956 30" Double Electric Wall Oven with 4.4 cu. ft. Capacity per Oven, Upper Oven PreciseAir Convection System, 4 Heavy-Duty Oven Racks, 1 Heavy-Duty Roller Rack, Glass Touch Oven Controls and Black Gloss Oven Interior Questions & Answers
The hinges are obstructed or the springs have been weakened by heat. Correction of the problem requires removal of he oven and disassembly to gain access to the affected parts. Not an easy job because those parts are enclosed in the outer shell of the oven.
GE Ovens | Answered on Jan 02, 2021
Check that whatever switches the light on and off is making good contact. My GE fridge has a bottle cap glued to the inside of the door, crude but it works. Some are magnetically operated, so you could test with a rare earth magnet.
For a mere $73 you can purchase a new switch.
ZET1PH1SS - Appliance Parts HQ
www.appliancepartshq.ca > lookup
Search by Keyword(s):. Diagram for ZET1PH1SS ... 55, WG02L07803, Badge Monogram Small No Pin, $150.44 ... 132, WG02L03187, G.e. Range Door Gasket, $84.82 ... 608, WG03F03565, G.e. Refrigerator Freezer Light Switch, $73.40
GE Ovens | Answered on Dec 19, 2020
Try checking on Ebay. I seen this one, but i can't answer if it a good match (if it looks close you may be able to patch it in).
https://www.ebay.com/itm/284067140396
GE Ovens | Answered on Dec 08, 2020
The F7 error indicates a stuck keypad error on GE ovens. This actually could be a stuck or shorted key, a problem with the ribbon cable between the keypad and the control board, or a problem with the electronic oven control. On a number of GE ovens, the issue is with the ribbon cable. There could be insufficient insulation shielding the individual conductors in the wiring harness, a broken conductor (single wire) or corrosion at the connection to the control board. Sometimes the keypad or the control board need to be replaced. Make sure to disconnect the power (unplug or turn off at the circuit breaker) before attempting to do any diagnostics.
Some parts for the JKP27WOW2WW are available here: https://www.appliancepartspros.com/search.aspx?model=jkp27w0w2ww . I hope this helps.
GE Ovens | Answered on Nov 25, 2020
Replace defective touchpad or oven.
GE Ovens | Answered on Nov 03, 2020
Your GE combo is way overdue for replacement.
An appliance parts supplier should be able to tell you whether the two assemblies are interchangeable.
Contact GE directly to request the diagram.
The F3 error code indicates temperature sensor failure.
The parts diagram for the JBS07V6 is available here: https://www.appliancepartspros.com/parts-for-ge-jbs07v6.html . The last two characters indicate the color of the range. The bake element (lower) is part 650 on the body cavity parts diagram. This gives the current part number as AP2031061 or WB44X10009 . See https://www.appliancepartspros.com/ge-bake-element-wb44x10009-ap2031061.html . This is a replacement part number and the previous part numbers are listed on the left hand side of the page (second link).
I hope this helps.
GE Ovens | Answered on Oct 20, 2020
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
GE Ovens | Answered on May 12, 2020
Hello. From the symptoms you describe, your main control board(EOC) is damaged.There are relays on the board that handle the heavy amp load of the heating elements(you don't have 400 amps going thru your key switch when you start your car--same applies to your oven) These relays can burn up, have the contacts shorted together, or the main board can become corrupted due to power surges(storm damage).
The F3 error is a temp error. In an oven, NORMALLY, only the main board and the temp sensor control the oven temp. In 98% of oven temp sensors, the proper ohm reading at room temp is 1100 ohms of resistance(+/- 10%).
Did you have a power outage or "brownout" within the last 4-6 weeks? This is not written in stone but USUALLY, if the board was damaged by a current surge, the chips on the board will start to fail in that time frame. If you give me the make and model of your unit, I can look up the part number and price for you. I hope I wasn't too long-winded and helped you!!
GE Ovens | Answered on Apr 27, 2020
GE Profile PT956 30" Double Electric Wall Oven with 4.4 cu. ft. Capacity per Oven, Upper Oven PreciseAir Convection System, 4 Heavy-Duty Oven Racks, 1 Heavy-Duty Roller Rack, Glass Touch Oven Controls and Black Gloss Oven Interior Logo
1 questions posted
Top GE Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Ovens
  • GE Ovens
Most Popular Question
part number replacement lower heating
  • Ovens
