20 Most Recent Electrolux ICON Designer E30EW75GSS 30" Single Electric Wall Oven with 4.2 cu. ft. CustomConvect3 Convection Oven, 3 Smooth-Glide Racks, Temperature Probe, Halogen Lighting and Wave-Touch Control Panel Questions & Answers
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post! I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
9/5/2014 2:48:56 PM • Electrolux ICON... • Answered on Sep 05, 2014
2answers
Electrolux Icon Wall oven off, wakes, beeps once as waking and goes back to clock after a couple of minutes? Whats up with it ?
Probably the clock and/or control board could be failing at random. The erratic oven start-up could present a safety hazard.
8/28/2022 9:37:36 AM • Electrolux Ovens • Answered on Aug 28, 2022
How do I bypass the automatic shutoff feature on my Electrolux builtin oven, Model #EOH6421X
You mean the thermocouple safety device. This is how you do it. https://www.insauga.com/five-years-ago-today-natural-gas-explosion-in-mississauga-killed-two-rocked-neighbourhood/ A VERY BAD idea. fix it, never bypass safety devices, they are there for a reason. The power of a gas explosion is incredible. In that road, three houses were demolished and rebuilt. some residents didn't get their homes back for 3 years.
6/3/2022 2:43:54 PM • Electrolux Ovens • Answered on Jun 03, 2022
2answers
What is the meaning of the error code EFAn in Electrolux Air-o-steam oven?
The exhaust fan is not working correctly. There could be several things causing this.
4/21/2022 8:26:06 AM • Electrolux Ovens • Answered on Apr 21, 2022
How to reset and adjust the clock in electrolux AOS201ECA2 electric convection oven 20 GN 1/1 LW?
This article will show you how to reset and adjust the clock in an Electrolux AOS201ECA2 electric convection oven. The first step is to locate the clock. It is usually found on the front panel of the oven. Next, locate the buttons that adjust the time. There are usually two or three buttons that control this function. Press and hold the button(s) until the time resets to 00:00.
3/17/2022 4:54:09 AM • Electrolux Ovens • Answered on Mar 17, 2022
How long should it take the oven to light?
within 30 seconds if it takes long u may have bad igniter ignitor glowigniter-undefined-undefined-0_0.jpg fuse location oven fuse_ranger_17-undefined-undefined-2_0.jpg gas set up xey69-s-undefined-undefined-5_0.jpg ignitor connectia_04-undefined-undefined-9.jpg
8/21/2021 9:02:38 AM • Electrolux Ovens • Answered on Aug 21, 2021
How to stop convection fan from hitting heating element in Electrolux oven?
I would replace the fan assembly as it sounds like the blades have moved on the shaft unless there is damage to the element fixings caused by ramming a cooking utensil into the oven that is too big of course.
8/14/2021 6:24:40 AM • Electrolux Ovens • Answered on Aug 14, 2021
Electrolux oven model E130GF55GSG remove racks message but there are no racks in the oven
Possibly control board or sensor failure
12/11/2020 2:40:21 PM • Electrolux Ovens • Answered on Dec 11, 2020
2answers
I have oven electrolux MODL. .EW30IS65JSA ..its has problem error .E35 how I can salve this ??
Hello Awad, thanks for your inquiry! From what you have described your Electrolux range is displaying an error code of E35. I am not showing that as a valid error code, maybe a digit or the panel is misreading. I would suggest performing a reset on your range to see if that would help clear any faulty codes. You can reset the range by disconnecting the power cord for at least ten minutes. If you continue to experience an issue with your range I would recommend seeking additional assistance from a professional technician. I hope this information is helpful to you. -Matt
11/16/2020 1:52:38 PM • Electrolux Ovens • Answered on Nov 16, 2020
2answers
Electrolux oven error code f130.what to do?
Hey Luciano, I appreciate your inquiry! From the information you have provided your Electrolux oven is displaying an error code of F130. I have researched possible error codes and it appears that this error code is invalid. I would recommend performing a reset on your oven and you can do that by unplugging the power cord for roughly ten minutes. If you restore power and continue to receive the error code can you please comment? I would be happy to assist you further. -Matt
6/2/2020 10:51:28 AM • Electrolux Ovens • Answered on Jun 02, 2020
I have an Electrolux Oven EVEP6155A. I have a fault Code F239 showing on the screen Can you please help
this is a error for the touch controls its normally caused by moisture getting on it, theres an upgraded part you can order from electrolux which is basically just a strip of foam you fit under the touch controls to prevent moisture getting in
2/7/2020 7:22:54 AM • Electrolux Ovens • Answered on Feb 07, 2020
Can I get electrolux oven EMI17EG80WH manual?
Of course. You can contact your supplier
10/26/2019 2:52:02 AM • Electrolux Ovens • Answered on Oct 26, 2019
Electrolux icon oven door: after cleaning finished, how long til the oven door unlocks? Self unlocking? How to unlock if not self unlocking after 3.5 hours
It should unlock once the temperature has dropped to a safe level. If its still locked after that time, I would say the safety lock has failed to release and will need replacing. I think it will need accessing through the top to manually release the door latch mechanism.
6/16/2019 7:36:15 AM • Electrolux Ovens • Answered on Jun 16, 2019
Electrolux ICON Designer E30EW75GSS 30" Single Electric Wall Oven with 4.2 cu. ft. CustomConvect3 Convection Oven, 3 Smooth-Glide Racks, Temperature Probe, Halogen Lighting and Wave-Touch Control Panel Logo
2 questions posted
Top Electrolux Ovens Experts
Geoffrey White
Geoffrey White
mark warfield
mark warfield
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
View Most Popular
Electrolux Ovens
  • Electrolux Ovens
Most Popular Question
address f14 code convection oven not
  • Ovens
