20 Most Recent Lenovo 3000 N100 0689 Notebook Questions & Answers
Driver wi fi
The WiFi driver can be downloaded from the manufacturer's website in the support area: Lenovo Support Drivers Software US Select your model for the list of drivers. Download and install.
6/1/2014 4:19:49 PM • Lenovo 3000 N100... • Answered on Jun 01, 2014
0answers
Lenovo b470 camera assitance software
i need to get camera driver
11/22/2013 9:49:30 AM • Lenovo 3000 N100... • Answered on Nov 22, 2013
Where is 0689 wi fi key
One way is to check on your keyboard from top F1 to F12 keys if you can see a Antenna sign on any of key then press that key by pressing Fn key together.If the problem still persist then I would recommend you to go on your manufacturer`s website to download the latest driver and update your driver. Good Luck
10/1/2013 1:02:54 PM • Lenovo 3000 N100... • Answered on Oct 01, 2013
Lenovo 3000 n100 notebook monitor turns green
my lenovo 300 N100 when turnned on the laptop from charger and Monitor
11/30/2012 10:47:44 PM • Lenovo 3000 N100... • Answered on Nov 30, 2012
Need cracked screen replacement. Would like to
I have the same lenovo 3000 N100 with a dead motherboard.I could either sell it to you at the price of a screen or perhaps could buy yours with a broken screen.Please let me know,Alex (botpot @ gmail.com)
5/10/2012 1:14:42 PM • Lenovo 3000 N100... • Answered on May 10, 2012
When i turn on my computer its screen works fine, after some time it fades away shows lining pattern on my screen and when i touch the screen it comes to its original form,,, anybody having any inform
If you touch the screen and it comes back to normal this proves the LCD panel display is defective, only option replacement. Go to www.ebay.com Type: make and model of laptop and refine search to screen. Plus! hook a spare monitor to the video output to make sure there is no problem with the video graphics card.
5/2/2012 1:06:00 AM • Lenovo 3000 N100... • Answered on May 02, 2012
I have a lenovo notebook 300 n100. I freshly installed win xp pro. I installed drivers for audio, video, chipset, network, bluetooth. Everything works fine but the wireless. it doesnt show up in the d
Hello, looks like there are 3 different wireless lan drivers on the Lenovo website! Maybe you've installed the wrong one? (Worth looking into anyway)Sorry can't think of anything else atm.Regards,nicam49
2/17/2012 9:00:24 PM • Lenovo 3000 N100... • Answered on Feb 17, 2012
My lenovo 0689 unable to
Welcome to Fixya
Lenovo care button is the One key restore button on your computer. This is usually located right beside or at the top of the power button. This button will restore the computer back to the factory state.
Thank you for using Fixya! If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
9/22/2011 11:59:10 AM • Lenovo 3000 N100... • Answered on Sep 22, 2011
Audio not coming after installing
First, make sure you installed the correct driver.
Then go to the control panel and under "sound" check to see if the speakers are muted. Also, check the speaker volume.
Go to the sounds tab and see if, when you click an event that has a sound assigned to it, the little arrow for preview is dark. If it is dark and the volume is up and not muted, you should hear sound. If it is grayed out, you your computer doesn't recognize the sound card or drivers.
8/30/2011 4:03:56 PM • Lenovo 3000 N100... • Answered on Aug 30, 2011
I didnt find audio drivers
Try to go to the Lenovo website and there at support type the model of the laptop and download the Lenovo update utility and it will update you're laptop's drivers.
8/25/2011 12:21:30 PM • Lenovo 3000 N100... • Answered on Aug 25, 2011
Not coming audio sound
click on start and click on help and support type in the serch bar device manager follow the links and open the page, it will show every item that you pc has scroll down and find sound if theres a ? mark against any double click it and it should serch for the software direct from your computers memory.. try it it worked for me
6/27/2011 2:23:39 PM • Lenovo 3000 N100... • Answered on Jun 27, 2011
I have Lenovo 300 N100
The backlights in your monitor are part of the display panel itself and cannot be changed..
You may need to replace the entire display panel.
However, start by having the inverter which runs the display panel backlighting checked as the fault may lay in it rather then in the panel itself.
Now, you must be VERY careful when handling this inverter as it is more then capable of giving you a nasty electric shock.
To be safe, have the panel and the inverter checked by a professional.
NEVER handle an inverter that is connected to a supply rail..
The inverter is usually located inside the monitor housing of the laptop and care must be taken to open up the housing. Most housings are held together with formed plastic clips and you simply prise the fascia off the front very carefully. DO NOT apply any pressure to the display panel during this.
If the inverter is not in the monitor housing, then it will be under the keyboard and in this case, I would advise you take the laptop to a professional as replacing the wrong screw into the wrong hole can cause serious damage to the mainboard and destroy the laptop.
3/10/2011 1:24:35 AM • Lenovo 3000 N100... • Answered on Mar 10, 2011
I installed window 7 on
Maybe you can find a driver here:
http://www-307.ibm.com/pc/support/site.wss/migr-63572.html
Good luck.
2/24/2011 3:36:01 PM • Lenovo 3000 N100... • Answered on Feb 24, 2011
I have built in integrated
uninstall and install the driver again.
Let me know if you need more information
Thanks
2/18/2011 4:35:30 AM • Lenovo 3000 N100... • Answered on Feb 18, 2011
4answers
Lenovo 3000 N100 power failure
I troubleshot my problem. and this is what I did.
I "overdischarged" the battery.
I took the battery out of the laptop, wiped it down with a clean DRY cloth, blew on the connectors, to eliminate any dust, etc.
Put battery back into the laptop, plugged in the AC adapter let charge for over an hour.
surprise, !!! it all started working again. ;-)
11/6/2010 4:12:41 PM • Lenovo 3000 N100... • Answered on Nov 06, 2010
Not working audio device
Hi. I would suggest that you uninstall the AUDIO driver and install the latest audio driver or High definition audio driver on your machine. You can download the latest drivers for your machine at the Lenovo Driver support website at consumersupport.lenovo.com, just enter the serial no. of your machine and it will give you every software and drivers that you need for your laptop. Hope this helps
6/3/2010 11:02:10 AM • Lenovo 3000 N100... • Answered on Jun 03, 2010
Lenovo 3000 n100 shuts down suddenly ,no warning
cooling isnt working properly
4/30/2010 3:52:59 AM • Lenovo 3000 N100... • Answered on Apr 30, 2010
Lenovo 3000 N100 0689 Notebook Logo
Popular Tags
40 questions posted
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
3000 Lenovo
  • 3000 Lenovo
Most Popular Question
notebook screen 3000 n100 goes dark
  • Computers & Internet
