20 Most Recent KitchenAid Kitchen Aid KESK901SSS Electric Slide In Ranges Questions & Answers
That is probably the SAbb code; the Sabbath mode has been set. This mode allows you to heat a meal while fulfilling the "no work" requirement for strict observance of the Sabbath. The oven will stay at the programmed temperature until you change the temperature or end the Sabbath mode. To end the Sabbath mode, open the oven door and press and hold 6 for 5+ seconds. Then close the oven door.
Searching Kitchenaid's support site, https://www.kitchenaid.com/service-and-support/manuals.html , I found the manual for the KESC307 ranges here: https://www.kitchenaid.com/content/kitchenaid/en_us/searchresult.html?term=KESC307&tab=clp&plp=&plpView=grid&clp=kesc307 . The direct link to the manual is https://www.kitchenaid.com/content/dam/global/documents/200308/owners-manual-9754287-RevC.pdf . See page 18-19 for the information on the Sabbath mode. You can completely disable the option on the range by following the steps in the manual.
I hope this helps.
KitchenAid... | Answered on Aug 26, 2020
Try unplugging for 15 minutes. Then plug back in. That may reset the board. If not, control Board is bad
KitchenAid... | Answered on Dec 10, 2019
I didn't see an operator manual using https://www.google.com
There were several diagrams and parts lists.
An installation manual and a toll free number to call for support is at the link below:
https://www.partselect.com/Models/KESH307HBS4/
KitchenAid... | Answered on Oct 04, 2019
Have you unplugged the appliance I reset it see if that clears it
KitchenAid... | Answered on Sep 15, 2019
Same here. I am in trouble like that. Need to find a solution!
Best,
http://giaydankinhgiahuy.com/
KitchenAid... | Answered on Sep 07, 2019
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Aug 07, 2019 | Kitchen Ranges
Good Morning, An E1-f2 E1F2 error indicates a faulty touchpad. Fixyourboard.com offers replacement Ledgestone Technologies touchpads for Kitchenaid oven models. Reach out to them for more information 512-355-1108 or [email protected]
KitchenAid... | Answered on Jun 19, 2019
Odds are that element is bad and needs replaced some minor testing needs to be done to know for sure. I have attached a picture of the elements as they are different depending on position. #12 is the part. Sears parts direct can get you the part numbers.
KitchenAid... | Answered on Feb 09, 2019
Have you tried running the exhaust fan when using the stove? Also you might try using the back burners. It sounds like the microwave is sitting too low and this may cause more issues as the time goes on.
Is it an electronic unit or piloted unit
KitchenAid... | Answered on Feb 05, 2019
Do you mean the KGSS907SS01? Kitchenaid ranges usually don't have three letters before the last two digits in the model number.
If so, all you need to do is press the Clock Set/Start keypad (below the 7) and then type in the current time. Then press the Clock Set/Start keypad again. The range uses a 12-hour clock.
I found the Owner's Manual at Sears Parts DIrect: https://www.searspartsdirect.com/partsdirect/user-manuals/kgss907sss01-kitchenaid-parts-manual . The instructions for setting the clock are on page 12. The direct link to the manual is currently https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0809512.pdf . Manuals Lib does list a KGSS907SSS model. The manual is available here: https://www.manualslib.com/products/Kitchenaid-Kgss907sss-30-Inch-Slide-In-Gas-Range-12919.html . The directions for setting the clock are the same.
I hope this helps.
KitchenAid... | Answered on Jan 14, 2019
KitchenAid Kitchen Aid KESK901SSS Electric Slide In Ranges Logo
3 questions posted
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
wp4eld1
Level 1 Expert
gbob59
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Kitchen Ranges
Most Popular Question
kitchenaid range model number
  • Kitchen Ranges
