20 Most Recent
EnGenius ECB350 Wireless-N Indoor AP/Bridge with Gigabit ECB350 Questions & Answers
How do I set up the ecb350 as a repeater. I have an xfinity wifi that doesn't reach the whole house but I can connect with an Ethernet cable to the back of the ECB350 out in the area I need wifi acce
What are you using for your main router (xfinity wifi)? The best way is to set the ecb350 in AP Router Mode not a repeater since you have a rj45 cable long enough to go from one of the ports on the xfinity wifi router and hook it into the ecb350. You will need to know what your ip address range is for example if the xfinity is 192.168.1.1 then you want to assign a static address for the ecb350 to be 192.168.1.100 (assigned IP Address) You will also need the Subnet mask, Default Gateway IP Address, and Primary DNS and Secondary DNS of the xfinity wifi router. Then on the ecb350 you will need to configure the following with the info you go off the xfinity router:
Static IP
Internet Connection Type
Select Static IP to begin configuration of the Static IP connection.
Account Name
Leave Blank
Domain Name
Leave Blank
MTU
Auto
IP Address
ie: 192.168.1.100 (assigned IP Address)
IP Subnet Mask
Specify the subnet mask of your Xfinity Router
Gateway IP Address
Specify the gateway of your Xfinity Router
Primary DNS
Specify the primary DNS server's IP address of your Xfinity Router
Secondary DNS
Specify the secondary DNS server's IP address of your Xfinity Router
Discard Ping on WAN
Check to Enable to recognize pings on the ECB350 WAN interface or Disable to block pings on the ECB350 WAN interface. Note: Pinging IP addresses is a common method used by hackers to test whether the IP address is valid. Blocking pings provides some extra security from hackers.
Accept / Cancel
Click Accept to confirm the changes or Cancel to cancel and return previous settings.
Note: Clicking Accept does not apply the changes. To apply them, use Status > Save/Load
Hope that this help you.
Setting linksys wireless access point security
Reset the Linksys to "factory settings", including the default logon-ID and password. Login to the router, and enable wireless security, and set a password for your wireless network.
5/28/2015 1:00:20 AM •
EnGenius...
Answered
on May 28, 2015
Cant change router password
If your on windows from a command line type ipconfig /release and reboot..not sure how to call 225-290-5733
1/29/2015 8:29:07 AM •
EnGenius...
Answered
on Jan 29, 2015
