Whirlpool... • Posted on May 29, 2017
Whirlpool... • Posted on May 20, 2017
Whirlpool... • Posted on Apr 08, 2014
Whirlpool... • Answered on Jan 27, 2014
Whirlpool... • Answered on Jun 08, 2013
Whirlpool... • Posted on Feb 12, 2013
Whirlpool... • Posted on Jan 25, 2013
Whirlpool... • Answered on Jul 21, 2012
Whirlpool... • Answered on Jul 04, 2012
Whirlpool... • Answered on Jun 14, 2012
Hi
If the water inlet
valve is fine and it fills with water then the issue seems to be with the float
switch assembly that is bad and should be replaced. Float assembly is found
inside the dishwasher's tub, on the bottom. The water that fills the dishwasher
lifts the float, and when it reaches a certain level, it acts as a trigger for
the float switch. The float triggers the float switch to shut off, thereby
shutting off the flow of water into the dishwasher. A defective switch may
interfere with dishwasher's filling and/or draining ability. Use voltmeter to
test the switch. Set the device to the ohms setting x 1. Take each probe and
touch them to one switch terminal each. This should produce a reading of either
zero or infinity. Continue to touch the probes to the terminals, and press down
on the switch's button. The reading should change to the opposite extreme. If
the switch fails either of these tests, you should replace it. Hope this helps...please post back for
further assistance.
Daniel
Whirlpool... • Answered on Aug 27, 2011
Whirlpool... • Answered on Aug 13, 2011
Whirlpool... • Answered on Aug 09, 2011
Whirlpool... • Posted on Jun 26, 2011
Whirlpool... • Posted on Jan 07, 2011
Whirlpool... • Posted on Nov 28, 2010
Whirlpool... • Answered on Oct 29, 2010
59 questions posted
918 Questions
493 Questions
219 Questions
129 Questions
99 Questions
