20 Most Recent Dell Inspiron 9300 PC Notebook Questions & Answers
2answers
My old hard drive stoped working so I go
The preowned hard drive maybe faulty.To test this hard drive, connect this hard drive to an USB hard drive adapter then plug the USB hard drive adapter into the USB port of a working computer. If this computer can see the USB adapter and hard drive as an external storage device and you can view the folders and files on this hard drive the the hard drive is working, if not the the hard drive is faulty and you need a new hard drive.
9/8/2017 6:47:02 AM • Dell Inspiron... • Answered on Sep 08, 2017
Turn on wifi different ways
FN and F8
11/2/2015 5:20:41 AM • Dell Inspiron... • Answered on Nov 02, 2015
2answers
Seven beeps on inspiron 9300 no screen how to fix?
the beeps are a code to tell a technician what has gone wrong take it to a repair shop and have the problem diagnosed and get a quote .
9/19/2015 10:06:07 AM • Dell Inspiron... • Answered on Sep 19, 2015
Dell inspiron 9300 change in blue screen after connecting with iphone
Bluescreen can be caused by a number of things Check all power and data leads from motherboard to hard drive and all of your cd/dvd drives make sure connections are secure dust free and not faulty computers need all power and data to travel through every working device and to finish its cycle so any faulty lead will end in computer error or shutdown / fail to boot or to reboot on a cylce Make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets some motherboards cmos batteries are soldered in might be getting hot check your CPU make sure it has a thermal paste and a dust free and secure seating Could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU you might not have enough RAM random access memory If you get your computer running to get a screen or even do it in safe mode Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu Please select an option: Safe Mode Safe Mode with Networking Safe Mode with Command Prompt Enable Boot Logging Enable VGA mode Last Known Good Configuration (your most recent settings that worked) Directory Services Restore Mode (Windows domain controllers only) Debugging Mode Start Windows Normally Reboot Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. select the safe mode option You might have to many programs trying to or accessing the internet at the same time scroll to bottom toolbar (bottom of screen) right click select task manager applications you will see whats running if you see anything you dont need running select end now and you might uninstall that specific program if you or computer does not require it to run and some unnecessary programs that could be jamming up your computer also under processes see what is ticking over in the background again if you see something you dont need to be running select end now and users you will see who is using your computer you might need to add more computer ram if you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. when purchasing any ram you should always ask if they can guarantee compatibility first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system might be getting hot check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials
2/10/2013 8:26:13 PM • Dell Inspiron... • Answered on Feb 10, 2013
Code #flrg581-595b dell 9300
If you want to know what this is the error code is related toClick start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details hope it helps
11/12/2012 10:24:23 PM • Dell Inspiron... • Answered on Nov 12, 2012
I have an Inspiron 9300 that I need to reset the Administrator password.
Forgot Dell windows password ?Well, take it easy. You can learn 2 partical ways to reset windows password in the article http://www.windowspasswordreset.net/article/reset-password-windows.htmlIt must can help you
7/13/2012 6:51:20 AM • Dell Inspiron... • Answered on Jul 13, 2012
2answers
Can I add memory to a 9300 dell inspiron?
yes u can extend it by external Hard disk.
I think not possible to configure ur hardware configuration
2/1/2012 8:13:12 AM • Dell Inspiron... • Answered on Feb 01, 2012
Dell Inspiron 9300 network modem faild to detect
As a simple step, restore your computer to an earlier date which should easily fix your issue and make sure you are downloading the updates only after reading or checking their compatibility or conflicts from the forums or search engines.If you need online technical support, you may very well contact TheBestPcDoctor. I get my all issues fixed by them and it is a reliable support according to my experience. If you want you can also get in touch with them @www.thebestpcdoctor.com or via 877-407-9229
10/4/2011 6:46:13 PM • Dell Inspiron... • Answered on Oct 04, 2011
The RIBA uses first class on its computer for
Welcome to Fixya
Software validation key may differ depends on the software that you are using. Usually these validation key is being supplied by the software developer when you purchased the computer. May i know the software that is asking for the validation key?
Thank you for using Fixya! If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
6/23/2011 2:51:26 PM • Dell Inspiron... • Answered on Jun 23, 2011
Icuin36.dll is missing on my dell 9300 inspiron
http://www.fix-all-dll-errors.com/icuin36.dll/
Here is the valid link for icuin36.dll.
Go to the link given above and then click the button with the fix option.
4/26/2011 11:31:45 AM • Dell Inspiron... • Answered on Apr 26, 2011
Battery indicator light flashing
could be charging or indicating a bad battery
2/25/2011 11:41:34 PM • Dell Inspiron... • Answered on Feb 25, 2011
Dell Inspiron9300 The pointer on the
Install the Driver for Touch pad. from here Dell Inspiron9300 touchpad driver
best of luck
1/28/2011 1:06:27 PM • Dell Inspiron... • Answered on Jan 28, 2011
Have dell inspiron 9300 laptop that will not load
Are you the Administrator of the computer? You could have a infection of many types.
If your not the Administrator. Log in safe mode.
Restart or start the computer.
As soon as it starts to boot hit the F8 key - keep hitting the key till you see Safe mode options.
Start in Safe mode with networking
Now the log in screen should show a Administrator log in that you may not have seen before.
Log in to that Administrator. Shouldn't be Password protected.
Once inside you can change your account to administrator.
Click START< >Control panel> then look for User Accounts
Look at your User account and make sure or change it to Administrator control..
Hope this helps
Thank you for your visit to Fixya.com
12/6/2010 10:00:50 PM • Dell Inspiron... • Answered on Dec 06, 2010
Have dell inspiron 9300 with
battery is bad sounds like
11/3/2010 5:35:23 AM • Dell Inspiron... • Answered on Nov 03, 2010
My Dell 9300 screen is
You can follow the link below that would help you to replace the LCD . The only thing to keep in mind is to keep a track of all the screws that would be coming out rest is easy .
Service manual Link
You can purchase the LCD, by calling Dell directly or from various online stores
1. http://www.parts-people.com/index.php?action=category&id=141&subid=75&refine=lcd%20screen
2.http://www.laptoppartsexpert.com/c-43742-dell-inspiron.html
Thanks for using Fixya
Proton
10/14/2010 1:42:10 AM • Dell Inspiron... • Answered on Oct 14, 2010
Hello. I cannot start windows xp
TRY THIS TUTORIAL http://www.5starsupport.com/tutorial/xpinstall.htm
10/12/2010 6:13:54 AM • Dell Inspiron... • Answered on Oct 12, 2010
I have a dell inspirion a while back ithe sound
Audio ports are part of the motherboard
Motherboards run about $100
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=inspiron+9300+motherboard&_sacat=See-All-Categories
10/4/2010 2:47:08 AM • Dell Inspiron... • Answered on Oct 04, 2010
2answers
How do i take password off dell 9300 inspiron
If it is the administration password (password to log in as the computer's owner), you cannot remove the password because it is part of the computer's safety protocol. You can change the password only.
10/2/2010 1:31:14 AM • Dell Inspiron... • Answered on Oct 02, 2010
Dell Inspiron 9300 PC Notebook Logo
Popular Tags
105 questions posted
Mehandi Husain ...
Steve Sweetleaf
Steve Sweetleaf
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
icuin36 dll missing dell 9300 inspiron
  • Computers & Internet
