20 Most Recent LG 4775er2002a Door Hinges for Wm2277hb Tromm Front Load Washer Questions & Answers
Might be "tE" error code. Thermistor error. A $6 parts and pretty common and causes the symptoms you described.
LG 4775er2002a... | Answered on Mar 06, 2017
that is your water valve in the washer need replaceing
LG 4775er2002a... | Answered on Apr 06, 2013
if the machine fails to spin and makes noise there are thee things to check .if it fails to drain the water check if something is stuck on the drain pump no 2 turn the drum with your hand and check if the drum is moving freely if not something is stuck between the drum and the housing if the bearings are faulty the machine spins but makes alot of noise towards the end of the cycle i hope this will help you.
LG 4775er2002a... | Answered on Jan 26, 2013
It can't be done. You would need to remove the front panel.
LG 4775er2002a... | Answered on Nov 27, 2012
If you are referring to the PC not turning on as a total power failure then yes a faulty mother board could definitely be the problem. The other option is the power supply (easy fix for a desktop not nearly as easy on a laptop). Hope that helps :)
LG 4775er2002a... | Answered on Aug 25, 2012
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
LG WM Washing... | Answered on Oct 29, 2018
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
LG WM Washing... | Answered on Dec 27, 2017
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
LG WM Washing... | Answered on Apr 25, 2017
http://www.lg.com/au/support/support-product/lg-WT-H9556
LG WM Washing... | Answered on Mar 29, 2017
There is no need to raise the water level. all modern washers automatically add the amount of water needed to wash the amount of clothes that you put in, I could explain how, but it will put you to sleep. rest assured these machines pretty much look after themselves. I would be more interested to know why you think it needs more water, are you having rinsing issues? wash quality issues?
LG WM Washing... | Answered on Oct 18, 2016
Remove the screws that attach the top panel at the back of the machine, slide the top backwards and remove the top panel.
Run the machine as per normal, but be careful as the electrics will now be exposed, you will be able to see where the water is leaking from and be able to repair/replace defective part.
LG WM Washing... | Answered on Aug 15, 2016
If you wish to get some details; check the site linked here. Pull up older posts........
http://electro-medical.blogspot.com/
LG WM Washing... | Answered on Jun 12, 2016
LG 4775er2002a Door Hinges for Wm2277hb Tromm Front Load Washer Logo
17 questions posted
Top LG Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
annoying lg tromm wm2277hw le error
  • Washing Machines
