20 Most Recent Haier RWT350AW Top Load Washer, White, 3.0 cu. ft. Super Capacity, Stainless Steel Drum Material, 630 RPM Maximum Spin Speed, Steel Door/Lid, Electronic with Knob Control, Status LEDs, End-of-Cycle Signal, Bleach Dispenser, Fabric Softener Dispenser, Adjus Questions & Answers
Yes I have this type of washer and it has the water in a ring at the top of the drum to help balance it out during spin, not quite sure why but yes it should be there. The gargling sound you describe could also be the balancing hooks that attach the drum to the top of the washer which sometimes make strange noises but there fine.
Haier RWT350AW... | Answered on Mar 10, 2013
Take the 4 screws out of the top section, lift up the whole top. You will see a bar. You must lift the top so the bar raises above the drum. Take the screws out of the plastic cover and check the bar .it has 2 round ends that rest in two holes. If it came out of one simply place it back in the hole. You will hear it click when pressing it. Put back together. Problem solved.
Haier Washing... | Answered on Jun 08, 2020
under agitator check cogs and spline to drum if ok bad bearings
Haier Washing... | Answered on Apr 16, 2020
if motor works check belt if ok check under agitator for bad cogs or spline to drum
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed.
Read more: http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Haier Washing... | Answered on Mar 19, 2020
Drain hose is blocked or twisted. ... Ensure the highest part of the drain hose is nearest the washing machine. Check the waste water pipes in the building are clear of any obstructions and flow freely. If the error is still exist, please unplug the machine and close the water tap, then call for service.Mar 13, 2014
Error Code-control panel display "Err2" (Error 2, Error2 ... - Haier
https://www.haier.com > faq > washing_machine > front_loading > question
Videos
https://www.google.com/search?q=haier+washing+machine+error+code+e2
Haier Washing... | Answered on Dec 08, 2019
GOOGLE HAIER ERROR CODES
Haier Washing... | Answered on Nov 26, 2019
try running a minimum load with light clothes. If it still does it, look for something broken that holds the tub in place, maybe a spring.
Haier Washing... | Answered on Nov 07, 2019
Dismantle the pipe fixing. Clean and use a little washing up liquid when re fitting.
Haier Washing... | Answered on Nov 03, 2019
This could be anything from a faulty water valve , machine not draining , faulty electronic board , faulty timer unit ...For the machine to continue it must complete its last cycle . Any fault codes showing ?, was it filling , was it draining properly ??, please contact your registered whiteware technician for proper fault diagnosys , cheers .
Haier Washing... | Answered on Aug 08, 2019
If its a top loader, most machine s have a dispenser on the top panel or somewhere in the top of the splash guard of the tub. On a front loader.... I have never seen a bleach dispenser on any of them.
Haier Washing... | Answered on Jun 17, 2019
Haier RWT350AW Top Load Washer, White, 3.0 cu. ft. Super Capacity, Stainless Steel Drum Material, 630 RPM Maximum Spin Speed, Steel Door/Lid, Electronic with Knob Control, Status LEDs, End-of-Cycle Signal, Bleach Dispenser, Fabric Softener Dispenser, Adjus Logo
Popular Tags
3 questions posted
Top Haier Washing Machines Experts
Marvin
Marvin
Marc Taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Washing Machines
Most Popular Question
normal liquid present in top part drum
  • Washing Machines
