20 Most Recent Sony KDL40EX520 Bravia KDL-40EX520 40 Inch LED TV 1080P Full HD Multi Questions & Answers
Sony led tv is not having picture why
there is a problem with common mode choke coils which is very near to lvds jack these coils are using for interface these coils are open so that's why some time abnormal picture & some time no picture please go to your nearest Sony service center & replace these coils
5/7/2016 9:49:42 AM • Sony KDL40EX520... • Answered on May 07, 2016
How do i set convergence of red,green ,blue through service mode
Most common cause for this on the Sony KDL 40EX520 is that the connections to the screen across the top edge of the panel become loose causing blurred picture, mis-aligned colors etc. The Fix requires dis-assembly (Removal of the entire case) and re-seating/resecuring the connection across the top of the LCD Panel. There is a pretty detailed video of the process (less the disassembly) here: https://www.youtube.com/watch?v=80PfZXFGDvQ
1/10/2015 3:40:36 PM • Sony KDL40EX520... • Answered on Jan 10, 2015
Horizontal lines on SONY TV
the ribbon flat connection tapes that connect the led panel driver to the panel have prob delaminated this cant be repaired easily and you would need to replace the panel
12/5/2014 12:51:54 PM • Sony KDL40EX520... • Answered on Dec 05, 2014
0answers
NO POWER
Be the first to answer 12/29/2013 6:51:02 PM • Sony KDL40EX520... • Posted on Dec 29, 2013Be the first to answer
Sony Bravia 46 XBR has the input bar stuck at the top of screen.
Unplug the TV for a while and hopefully, that should reset the circuity. If you're using the original remote control, check for the display button and press it. I would also suggest doing a factory reset if your TV has that feature and if the TV allows you to do it after unplugging it.
9/30/2022 3:10:56 AM • Sony BRAVIA... • Answered on Sep 30, 2022
I need to remove the back off a Sony Bravia KD-48X81J
The front and back pieces are like a clam shell and are compression fit with tabs into one another. You need to use something like a guitar pick or spudger to separate the pieces. Dont use metal objects due to damage that will happen to the plastic .
8/25/2022 5:14:39 AM • Sony BRAVIA... • Answered on Aug 25, 2022
Sony 65 inch TV, KD-65X750F not getting any power from stand-by pin on power board?
Do you get voltage with the main board unhooked?
3/27/2022 11:56:41 PM • Sony BRAVIA... • Answered on Mar 27, 2022
Sony 49 XBR 900 E power will not come on unless the plug is taken out from the set and reconnected. Can you tell me which board should be replaced?
what plug not told./PC is dead?no it is not a PC it is a television posted to wrong forumnow corrected.is TV set to sleep mode, RTM read the manual on TVare the clicker remote batteries fresh>?
3/24/2022 2:55:41 PM • Sony BRAVIA... • Answered on Mar 24, 2022
How can I watch Netflix on a tv Sony wega that isn’t hooked to the internet. It’s wirelessly connected to Vizio ( smart tv Netflix built in) but I want to be able to watch in a different room
netflix is a 100% internet web site , streaming site. thus the net in flix. what did you mean by hooked?\ do you have internet at home at all? do other things in home work to the internet, like PC or cell phones. what I can not under stand is (different room) this phase implies some rooms do work (netflex) and wifi gets weak if my move any TV farther from the home router and will fail past 25 feet or more. wifi is super weak through walls for sure brick, or 2 walls. if home is small one wifi access point is all you need if huge home more. distance matter, TV to router. no TV model # told. (tells me wifi spec) if you said my TV works in room 1 but not room 2, wifi;. it be super more easy to answer.. is this true? if true , get a tech to upgrade your wifi. or go wired, Ethernet.(a better home upgrade)
3/24/2022 2:24:22 PM • Sony BRAVIA... • Answered on Mar 24, 2022
I have a 85 inch Sony Bravia TV. I have sound but no picture
Hello !! what do you mean by you replaced the video card ? mainboard or t-con ? , we need more information
2/1/2022 12:21:49 AM • Sony BRAVIA... • Answered on Feb 01, 2022
Sony bravia 40" kdl-40v3000 stand screws
They are usually M6 or M8. You can get them from Home Depot or Sainsbury Homebase.. These are listed as the correct ones. https://www.ebay.com/itm/4-STAND-FIXING-SCREWS-FOR-SONY-KDL-40U3000-KDL-40V3000-KDL-40D3000-KDL40W3000-TV-/322578615461 and here as well, the same type https://www.ebay.co.uk/itm/272144950454?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338722076&customid=&toolid=10050 ..
11/30/2021 5:53:30 PM • Sony BRAVIA... • Answered on Nov 30, 2021
I have Sony Bravia 32r402a with demo loop running. Also the power light blinks many times thereafter input select tv/hdmi/video keeps flashing. Any action for remedy?
Sounds like a bad main board, or more specific the EEPROM is bad on the main
11/13/2021 8:41:51 PM • Sony BRAVIA... • Answered on Nov 13, 2021
Sony KDL40EX520 Bravia KDL-40EX520 40 Inch LED TV 1080P Full HD Multi Logo
13 questions posted
Top Sony Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
set convergence red green blue service
  • Televison & Video
