20 Most Recent
HP Compaq ProLiant DL380 G2 Server Questions & Answers
Server won't boot and nothing to even show on the
Are there lights on the front of it? If so, try to re-seat the memory as the first step; servers overheat and are subject to "chip creep". If you don't have any lights, it could be the power supply or system board.
8/24/2013 2:25:23 AM •
HP Compaq...
Answered
on Aug 24, 2013
Server with external HDD
The Maximum internal storage for a G2 is 880.8 GB
(6 x 146.8 GB Ultra320 1") so that's quite a bit more than you thought, Not sure about the USB 3.0 since the HP only has USB 1.1 and it's a PIII 1.4 GHz processor which will be your bottle neck in the end.You can definitely give it a try, but I would suggest to look at ebay where you often can find a newer model for very little money and often they are stacked with hard drives already.The PCI slots are only 64-bit, so don't expect a miracle, even with USB 3.0
4/22/2012 1:53:02 AM •
HP Compaq...
Answered
on Apr 22, 2012
How do i boot a compaq proliant dl380 with a usb
Make sure you have turned on the USB Boot in the BIOS of the os. Once this is done, select the order you would like for the server to locate boot files. (Hard Drive, USB, CD/DVD, etc.) Once complete, insert the USB and reboot the server.
Good Luck
C2S
7/7/2010 10:07:49 PM •
HP Compaq...
Answered
on Jul 07, 2010
Wont boot anything. all lights remain on on all
Try restarting the KVM and make sure the KVM works for other servers. If yes, then ensure the memory modules in the server are seated properly in the DIMM slots. Then power it own.
Please come back and rate my solution if it turns to be helpful for you.
Thnx
3/20/2010 9:29:02 PM •
HP Compaq...
Answered
on Mar 20, 2010
Ram Problem
RESOLUTION
To clear the RILOE NVRAM and eliminate the error message, reset the RILOE using one of the following methods:
On servers running Microsoft Windows :
- Reset RILOE through the Management Agents icon in the Control Panel:
- Click Start, Settings, Control Panel, Administrative Tools.
- Click on Services.
- Stop the HP Insight Server Agents.
- Click on Start, Settings, Control Panel.
- Click on the HP Management Agents icon.
- Click on the Remote Insight tab.
- Click on "Reset Remote Insight Board" (reset option will be grayed out if the Server Agents are still running).
Or
- Reset RILOE using the Remote Insight Setup Utility in the Control Panel (pink icon).
On servers running other operating systems and as an alternative method for servers running Microsoft Windows :
- Reset RILOE by powering off the server and unplugging the external
power connection to the RILOE board and the external power connection
to the server.
A permanent resolution is not planned as the Remote Insight Lights-Out Edition (RILOE) is end-of-life and out of production.
1/29/2010 4:34:29 PM •
HP Compaq...
Answered
on Jan 29, 2010
How do I fix window 10 to listen audio mp3 cd
NO PC told at all and posted to Proliant server forum
that is no PC and as such the OS is not allowed there w10 nor does it have sound chips, at all, its a server running in huge dark, no humans server farm..... so let me guess you posted to wrong forum
and never told PC model sure.
so windows sounds work in the test in control panel
yes !
the, MP3 is complex, it can be from high data rate, source
and will not play unless converted .
one thing to try is use this free app
called Audacity
https://www.audacityteam.org/
then play it or convert it
or buy a USB sound dac that can decode any sound file on earth
or learn to test you PC first
windows sounds work
then in google type
simple MP3 sound test
https://file-examples.com/index.php/sample-audio-files/sample-mp3-download/
works good above so your MP3 is no good or wrong bit rate.
if fails yours only , buy new DAC USB dongle now it plays them all
if windows sounds are dead the sound driver is missing
or on a server there is no sound chips oops. buy the DAC dongle.
if only 1 MP3 fails out of 100's find a better one or buy a DAC.
Reset bios putty
You need to be specific about the exact model of server that you're using. Features of the various generations of the HP iLO are accessed in different ways.
BE SPECIFIC.
Blinking red light and beep sound coming from the front blade Slot 1.
That drive has failed, is it set up with a RAID configuration? Do you have the Dell monitoring software installed? Is it set up with Hot Plug drives? If so replacing the drive with a new one will start the RAID rebuild. Otherwise one way to turn off the bleep is to reboot and go into the RAID controller configuration
Front blade Slot 1
It Indicating something Faulty, if you have something plugged in, remove, and reconnect, If unable to find, check device manager or event log for details, that should have some info.
No servers, cant get mail or send mail cp was
If you lost everything then you've obviously reloaded all your software for the server, now you need to load your daily backup tapes onto the server so you can have mail again. you will also need to know all of your DNS's and you MX records if you're running exchange and if you don't know how to do any of it, then my suggestion is to hire a network administrator and it'll cost between $1k - $1.5k by time he's done bringing your system back online.
