20 Most Recent HP LaserJet 600 M602DN Laser Printer - M Questions & Answers
Error: 52.XX.00 Error To continue turn off then on
Error Description: Laser/scanner error ? XX = 00 laser/scanner motor startup error ? XX = 20 Laser/scanner rotation error
check your printer scanner assy. need technician support.
HP LaserJet 600... | Answered on Jun 28, 2019
Go To Below official HP Printer Page For Your problem, HP Color LaserJet Enterprise 500 M551N Printer Error Codes and Support Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For HP Support
HP LaserJet 600... | Answered on Apr 30, 2018
HP LaserJet Enterprise 600 M601, M602, and M603 Series Printer - Restore factory settings:
HP LaserJet 600... | Answered on Mar 21, 2018
99.09.67 Disk is not bootable please download firmware
Description
The product has a non-secure disk (solid state disk) installed as the boot disk, and it has been replaced
with a new service part. A new firmware image needs to be downloaded to the device.
Recommended action
1. Press any key to continue to the main Preboot menu.
2. Press the Help button to see the help text for the error.
3. Select the Administrator menu.
4. Select the Download item.
5. The user can now download a new firmware bundle to the product.
HP LaserJet 600... | Answered on Mar 11, 2018
With something that expensive I would have an HP authorised service engineer do the job, then if it doesn't work, they bear the cost until they find what works to repair it. If it doesn't and they say you need a new machine, you only pay for the service call out.
HP LaserJet 600... | Answered on Jun 21, 2016
This indicates low fuser temperature. Likely the fuser has failed. Power off, reseat the fuser and then start again, if error repeats replace the fuser. Be sure to upgrade the firmware on the printer to the current revision as HP has made some adjustments to the DC controller on this printer to extend fuser life.
HP LaserJet 600... | Answered on Nov 09, 2014
Make sure that the inner tray that the paper rests on moves through its whole range of motion. The most common problem I have run into, is that on the left hand side of the tray, where the paper level indicator is located, there is a C shaped piece of plastic that is supposed to be on both sides of the metal tray becomes dislodged and sits either on top or on the bottom of the tray and blocks the tray from moving through the full range. You will just have to jimmy it back into position.
HP LaserJet 600... | Answered on Oct 19, 2014
When exactly did you get the error message 98.01.01? Was it while you was trying to do a firmware update? I found a forum support page regarding this error but so far it remains unresolved on many websites. I checked all of the LaserJet's error codes and, like in the forum link, it appears this is related to a bad firmware update or faulty connection during a firmware. I have heard of people just repeatedly trying the firmware update until it goes through. In fact, there is a firmware update for this printer.
To get to the firmware update, go towww.hp.com/supportand type in your product name under Software and Download and press enter. Next, you will have to select which printer you have (m551n, m551dn, or m551xh). Once you select that, it will take you to a Business Support Page and the firmware updates are located on the left hand side under Setup, Install, and Configure and then in the middle of the page you will see "Firmware Download and Install." I will need to know a bit more information before I can help you with any of those steps, however.
First of all, how is the printer connected to the computer? What is the Operating System and System Type of the computer (Windows 7 64 bit, Windows XP, Mac Version X.X, etc)? Are you able to print or do anything else with this printer? Answer those questions if you need any more help.16x16_smiley-happy.gif
HP Support
HP LaserJet 600... | Answered on Jun 25, 2014
please details which led is Amber
HP LaserJet 600... | Answered on Mar 21, 2013
Amber , light ,means attentions and some times alert
HP LaserJet 600 M602DN Laser Printer - M Logo
27 questions posted
Ekse
efs_perpends
efs_perpends
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
fuser error printer 50 92 11
  • Office Equipment & Supplies
