20 Most Recent Whirlpool LSQ8543J Questions & Answers
2answers
Fabric conditioner not draining from whirlpool washing machine
This video will show you how to keep your soap draw clear and how to service the parts Please remember to subscribe to our YouTube channel for all appliance tutorials a 4 THUMBS rating is appreciated for answering your FREE question.
7/30/2013 1:00:47 PM • Whirlpool... • Answered on Jul 30, 2013
0answers
Whirlpool washer blows fuse
the pump motor is starting to seize up. It is causing the motor to work harder which causes heating of electronics causing the fuse to blow
2/21/2012 7:08:15 PM • Whirlpool... • Answered on Feb 21, 2012
How can I replace the presure switch?
Take the two screws in the back of the control panel. pull the control panel foward then up. pull the knob off the pressure switch. pull the tab on the pressure switch and turn the pressure switch pull the hose off.
7/15/2011 12:58:10 AM • Whirlpool... • Answered on Jul 15, 2011
2answers
Agitates before water is full, almost immediately
So its agitating as soon as the water comes in? Try this put the washer into spin out cycle if it starts agitating while spinning you have a bad transmission. Also does this have a led light up control board or regular with a turn knob timer?
1/6/2011 2:50:52 AM • Whirlpool... • Answered on Jan 06, 2011
It spins during rinse cycle but the clothes don't
It may not be spinning fast enough. Is the agitator operating at normal speed?
Possible causes for slow spin are overloaded washer, slipping belt, bad bearings in the motor or clutch, or slipping clutch.
Another possibility is a problem with the pump, but I suppose you would also see some water left in the bottom of the machine in that case.
12/5/2010 5:11:32 AM • Whirlpool... • Answered on Dec 05, 2010
Clothes get caught under
Check the rubber gasket around the agitator is not worn. If it is get a replacement and insert it in snugy.
8/16/2010 11:37:14 PM • Whirlpool... • Answered on Aug 16, 2010
My washer wont spin
If this is a Whirlpool manufactured TOP LOADER washing machine, a no spin problem can have several causes. Most commonly, this is caused by either a lid switch malfunction or a broken motor coupling. The following link explains how you can diagnose the problem and repair:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
Read through the link provided and let me know if you have any questions. I have included parts sources and instructions on how to replace each part as well. If you have questions, please post back and let me know. I hope you find this information helpful.
4/2/2010 5:02:35 AM • Whirlpool... • Answered on Apr 02, 2010
What is the likely cause of the cold water
there is a sensor at the back of the washing machine drum that senses the water level and stops filling when water reaches it sounds like it needs to be replaced i would consult a local professionial the sensor itself should'nt be too expensive either .Hope this is helpful
10/31/2009 6:22:00 PM • Whirlpool... • Answered on Oct 31, 2009
Agitator not working
Agitator clutch dogs (#3366877) are probably worn out.
6/14/2009 4:17:26 PM • Whirlpool... • Answered on Jun 14, 2009
Putting cabnet back to gether on a whirlpool LSQ8543J
Open the lid and look down inside. Slip the lip of the cabinet under the base and sit it on the tabs. Gently let the canbinet go to the back being careful not to break the downspout or pinch the water level fill tube. Snap the S clips down and plug in the lid switch. Swing down the controls and screw it back into place so it won't rattle. Grab a beer and chill. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
5/17/2009 10:22:50 PM • Whirlpool... • Answered on May 17, 2009
The top agitator is not working, the bottom is fine.
A cheap and easily replaced set of agitator dogs is what you need Here is a link to the Fermented
Grand Master's own superb rendition of Dogs replacement ENJOY!
ec36d49.jpg If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
5/17/2009 2:37:41 AM • Whirlpool... • Answered on May 17, 2009
Suspect there is dirt in the cold water side of solenoid. Won't stop running. Need to remove back of washer so I can get new one. How do you remove back. A diagram of parts and numbers would be very h
Cabinet removal is quite simple. You flip the controls upward to expose the Sclips which hold the cabinet. You release the lid switch quick connect and tilt the cabinet forward. Lifting it out of the way.Then you can easily replace the water inlet valve. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
5/17/2009 2:12:10 AM • Whirlpool... • Answered on May 17, 2009
Water not pumping out before it starts to spin
your water level switch is telling the pump that the water is out. The switch is located in the control panel and has a clear tube attached to it which runs down to the tub and senses pressure usally caused by water or the lack of.
4/25/2009 12:43:52 PM • Whirlpool... • Answered on Apr 25, 2009
2answers
My Whirlpool LSQ8543J has started overflowing after rinse cycle
Replace the water valve where your hoses connect to the washer.
4/21/2009 5:17:42 AM • Whirlpool... • Answered on Apr 21, 2009
Washing machine isn't spinning to drain water
suggest that the drive belt is worn and slipping under exess load solution replace belt regards billnkaym
4/10/2009 7:17:27 PM • Whirlpool... • Answered on Apr 10, 2009
My washer stopped working, will not turn on
If no cycles work and there is no noise, replace your timer.
To remove water there are 2 options, bail with a pail or use a shop vac.
3/21/2009 2:58:48 PM • Whirlpool... • Answered on Mar 21, 2009
Washer Won't Agitate
It might be the agitator dogs. Try to replace those
2/6/2009 3:04:45 AM • Whirlpool... • Answered on Feb 06, 2009
Washing Machines Logo
28 questions posted
Marvin
Marvin
Mike
View Most Popular
  • Whirlpool Washing Machines
Most Popular Question
clothes get caught under
  • Washing Machines
